Topic "Problem when opening files"
afernandeza
Every time I try to open a .xls file in WinSCP, either a remote file or a local file, the program doesn't open the file with the appropriate application (Excel). I thought that the problem could be that Excel isn't set up as the default application for .xls files in Windows, but it is. Is there any way to choose the applications that WinSCP should open files with? Any ideas of what the problem is and how can I fix it?
Thank you,
Alfredo
Do you use Open or Edit command? You need to use Open.
afernandeza
I was using the Edit Command. Problem solved, thank you.
