Topic "Copy using text transfer mode"
tzak
I copied a large text file which has a .dat extension from a UNIX server to my local folder. It indicated that it was copying in text mode.
I edited the file and now want to copy it back to the UNIX server. I am selecting a transfer mode of text but the copy just hangs and I have to cancel out.
If I select automatic transfer mode and enter *.dat in the 'Transfer following files in text mode' box it still hangs.
If I select automatic transfer mode it transfers in binary mode and completes but then I cannot use the file on the UNIX server.
The file is large - 115Mb.
I am using version 3.8.2
Here is the log when the copy is hung:
. 2006-08-11 14:30:12.438 Session upkeep
. 2006-08-11 14:30:12.438 Select result is 0
. 2006-08-11 14:30:12.610 Session upkeep
. 2006-08-11 14:30:12.610 Select result is 0
. 2006-08-11 14:30:13.110 Session upkeep
. 2006-08-11 14:30:13.110 Select result is 0
. 2006-08-11 14:30:13.610 Session upkeep
. 2006-08-11 14:30:13.610 Select result is 0
. 2006-08-11 14:30:14.110 Session upkeep
. 2006-08-11 14:30:14.110 Select result is 0
. 2006-08-11 14:30:14.625 Session upkeep
. 2006-08-11 14:30:14.625 Select result is 0
. 2006-08-11 14:30:15.110 Session upkeep
. 2006-08-11 14:30:15.110 Select result is 0
. 2006-08-11 14:30:15.610 Session upkeep
. 2006-08-11 14:30:15.610 Select result is 0
. 2006-08-11 14:30:16.110 Session upkeep
. 2006-08-11 14:30:16.110 Select result is 0
. 2006-08-11 14:30:16.610 Session upkeep
. 2006-08-11 14:30:16.610 Select result is 0
. 2006-08-11 14:30:17.110 Session upkeep
. 2006-08-11 14:30:17.110 Select result is 0
. 2006-08-11 14:30:17.610 Session upkeep
. 2006-08-11 14:30:17.610 Select result is 0
. 2006-08-11 14:30:18.110 Session upkeep
. 2006-08-11 14:30:18.110 Select result is 0
. 2006-08-11 14:30:18.610 Session upkeep
. 2006-08-11 14:30:18.610 Select result is 0
. 2006-08-11 14:30:19.110 Session upkeep
. 2006-08-11 14:30:19.110 Select result is 0
. 2006-08-11 14:30:19.610 Session upkeep
. 2006-08-11 14:30:19.610 Select result is 0
. 2006-08-11 14:30:20.110 Session upkeep
. 2006-08-11 14:30:20.110 Select result is 0
. 2006-08-11 14:30:20.610 Session upkeep
. 2006-08-11 14:30:20.610 Select result is 0
. 2006-08-11 14:30:20.797 Copying 1 files/directories to remote directory "/net/lltmp/tmp/publ/document/"
. 2006-08-11 14:30:20.797 PrTime: No; PrRO: Yes; Rght: rw-r--r--; PrR: No (No); FnCs: N; RIC: 01; Resume: S (102400); CalcS: Yes; Mask: *.*
. 2006-08-11 14:30:20.797 TM: A; ClAr: No; ExclM(No):
. 2006-08-11 14:30:20.797 AscM: *.*html; *.htm; *.txt; *.php*; *.cgi; *.c; *.cpp; *.h; *.pas; *.bas; *.tex; *.pl; .htaccess; *.xtml; *.css; *.cfg; *.ini; *.sh; *.xml
. 2006-08-11 14:30:20.797 Sent 128 bytes
. 2006-08-11 14:30:20.797 There are 0 bytes remaining in the send buffer
. 2006-08-11 14:30:20.797 Sent 1 bytes
> 2006-08-11 14:30:20.797 echo "WinSCP: this is begin-of-file" ; scp -r -d -t "/net/lltmp/tmp/publ/document" ; echo "WinSCP: this is end-of-file:$status"
. 2006-08-11 14:30:20.797 Waiting for another 1 bytes
. 2006-08-11 14:30:20.797 Looking for incoming data
. 2006-08-11 14:30:20.829 Select result is 1
. 2006-08-11 14:30:20.829 Received 1 bytes
. 2006-08-11 14:30:20.829 Received 29 bytes
< 2006-08-11 14:30:20.829 WinSCP: this is begin-of-file
. 2006-08-11 14:30:20.829 Waiting for another 1 bytes
. 2006-08-11 14:30:20.829 Looking for incoming data
. 2006-08-11 14:30:21.016 Select result is 1
. 2006-08-11 14:30:21.016 Received 1 bytes
. 2006-08-11 14:30:21.016 SCP remote side confirmation (0)
. 2006-08-11 14:30:21.032 Asking user:
. 2006-08-11 14:30:21.032 Remote file 'tps_test4.dat' already exists. Overwrite?
. 2006-08-11 14:30:21.032 New: 115439165 bytes, 8/11/2006 11:28:33 AM
. 2006-08-11 14:30:21.032 Existing: 115439165 bytes, 8/11/2006 1:05:00 PM ()
. 2006-08-11 14:30:21.110 Session upkeep
. 2006-08-11 14:30:21.110 Select result is 0
. 2006-08-11 14:30:21.610 Session upkeep
. 2006-08-11 14:30:21.610 Select result is 0
. 2006-08-11 14:30:22.110 Session upkeep
. 2006-08-11 14:30:22.110 Select result is 0
. 2006-08-11 14:30:22.625 Session upkeep
. 2006-08-11 14:30:22.625 Select result is 0
. 2006-08-11 14:30:22.625 File: "U:\WS_FTP\sedna\pubs\tps_test4.dat"
. 2006-08-11 14:30:22.625 Copying "U:\WS_FTP\sedna\pubs\tps_test4.dat" to remote directory started.
. 2006-08-11 14:30:22.625 Ascii transfer mode selected.
. 2006-08-11 14:30:23.110 Session upkeep
. 2006-08-11 14:30:23.110 Select result is 0
. 2006-08-11 14:30:23.610 Session upkeep
. 2006-08-11 14:30:23.610 Select result is 0
. 2006-08-11 14:30:24.110 Session upkeep
. 2006-08-11 14:30:24.110 Select result is 0
. 2006-08-11 14:30:24.610 Session upkeep
. 2006-08-11 14:30:24.610 Select result is 0
. 2006-08-11 14:30:25.110 Session upkeep
. 2006-08-11 14:30:25.110 Select result is 0
. 2006-08-11 14:30:25.610 Session upkeep
. 2006-08-11 14:30:25.610 Select result is 0
. 2006-08-11 14:30:26.110 Session upkeep
. 2006-08-11 14:30:26.110 Select result is 0
. 2006-08-11 14:30:26.610 Session upkeep
. 2006-08-11 14:30:26.610 Select result is 0
. 2006-08-11 14:30:27.110 Session upkeep
. 2006-08-11 14:30:27.110 Select result is 0
. 2006-08-11 14:30:27.626 Session upkeep
. 2006-08-11 14:30:27.626 Select result is 0
. 2006-08-11 14:30:28.110 Session upkeep
. 2006-08-11 14:30:28.110 Select result is 0
. 2006-08-11 14:30:28.626 Session upkeep
. 2006-08-11 14:30:28.626 Select result is 0
. 2006-08-11 14:30:29.141 Session upkeep
. 2006-08-11 14:30:29.141 Select result is 0
. 2006-08-11 14:30:29.626 Session upkeep
. 2006-08-11 14:30:29.626 Select result is 0
. 2006-08-11 14:30:30.126 Session upkeep
. 2006-08-11 14:30:30.126 Select result is 0
. 2006-08-11 14:30:30.610 Session upkeep
. 2006-08-11 14:30:30.610 Select result is 0
. 2006-08-11 14:30:31.110 Session upkeep
. 2006-08-11 14:30:31.110 Select result is 0
. 2006-08-11 14:30:31.626 Session upkeep
. 2006-08-11 14:30:31.626 Select result is 0
. 2006-08-11 14:30:32.126 Session upkeep
. 2006-08-11 14:30:32.126 Select result is 0
. 2006-08-11 14:30:32.626 Session upkeep
. 2006-08-11 14:30:32.626 Select result is 0
. 2006-08-11 14:30:33.110 Session upkeep
. 2006-08-11 14:30:33.110 Select result is 0
. 2006-08-11 14:30:33.610 Session upkeep
. 2006-08-11 14:30:33.610 Select result is 0
. 2006-08-11 14:30:34.110 Session upkeep
. 2006-08-11 14:30:34.110 Select result is 0
. 2006-08-11 14:30:34.610 Session upkeep
. 2006-08-11 14:30:34.610 Select result is 0
. 2006-08-11 14:30:35.110 Session upkeep
. 2006-08-11 14:30:35.110 Select result is 0
. 2006-08-11 14:30:35.391 Sent 1 bytes
. 2006-08-11 14:30:35.391 There are 0 bytes remaining in the send buffer
> 2006-08-11 14:30:35.391 E
. 2006-08-11 14:30:35.391 Waiting for another 1 bytes
. 2006-08-11 14:30:35.391 Looking for incoming data
. 2006-08-11 14:30:35.438 Select result is 1
. 2006-08-11 14:30:35.438 Received 1 bytes
. 2006-08-11 14:30:35.438 SCP remote side confirmation (0)
. 2006-08-11 14:30:35.438 Waiting for another 1 bytes
. 2006-08-11 14:30:35.438 Looking for incoming data
. 2006-08-11 14:30:35.594 Select result is 1
. 2006-08-11 14:30:35.594 Received 1 bytes
. 2006-08-11 14:30:35.594 Received 29 bytes
< 2006-08-11 14:30:35.594 WinSCP: this is end-of-file:0
. 2006-08-11 14:30:35.594 Listing current directory.
. 2006-08-11 14:30:35.610 Sent 52 bytes
. 2006-08-11 14:30:35.610 There are 0 bytes remaining in the send buffer
. 2006-08-11 14:30:35.610 Sent 1 bytes
> 2006-08-11 14:30:35.610 ls -la ; echo "WinSCP: this is end-of-file:$status"
. 2006-08-11 14:30:35.610 Waiting for another 1 bytes
. 2006-08-11 14:30:35.610 Looking for incoming data
. 2006-08-11 14:30:35.657 Select result is 1
. 2006-08-11 14:30:35.657 Waiting for another 1 bytes
. 2006-08-11 14:30:35.657 Looking for incoming data
. 2006-08-11 14:30:35.657 Received 1 bytes
. 2006-08-11 14:30:35.657 Received 13 bytes
< 2006-08-11 14:30:35.657 total 1240972
. 2006-08-11 14:30:35.657 Received 56 bytes
< 2006-08-11 14:30:35.657 drwxrwxr-x 2 basis10 basis 1536 Aug 11 12:02 .
. 2006-08-11 14:30:35.657 Received 57 bytes
< 2006-08-11 14:30:35.657 drwxrwxr-x 3 basis10 basis 512 May 25 14:16 ..
. 2006-08-11 14:30:35.657 Received 63 bytes
< 2006-08-11 14:30:35.657 -rwxrwxr-x 1 basis10 basis 13780381 Aug 9 19:01 acq.dat
. 2006-08-11 14:30:35.657 Received 62 bytes
< 2006-08-11 14:30:35.657 -rwxrwxr-x 1 basis10 basis 10779 Aug 10 17:03 acq.rej
. 2006-08-11 14:30:35.657 Received 65 bytes
< 2006-08-11 14:30:35.657 -rwxrwxr-x 1 basis10 basis 5336924 Aug 9 19:04 active.dat
. 2006-08-11 14:30:35.657 Received 66 bytes
< 2006-08-11 14:30:35.657 -rwxrwxr-x 1 basis10 basis 75572194 Aug 9 19:04 anlptd.dat
< 2006-08-11 14:30:35.657 -rwxrwxr-x 1 basis10 basis 0 Jun 29 11:34 anlptd.rej
. 2006-08-11 14:30:35.657 Received 69 bytes
< 2006-08-11 14:30:35.657 -rwxrwxr-x 1 basis10 basis 3907 Aug 10 09:52 apec_mtype.dat
< 2006-08-11 14:30:35.657 -rwxrwxr-x 1 basis10 basis 82790440 Aug 9 19:01 cat.dat
< 2006-08-11 14:30:35.657 -rwxrwxr-x 1 basis10 basis 0 Jun 29 11:29 cat.rej
. 2006-08-11 14:30:35.657 Received 64 bytes
< 2006-08-11 14:30:35.657 -rwxrwxr-x 1 tzak users 21398 Aug 10 17:16 check.dat
. 2006-08-11 14:30:35.657 Received 70 bytes
< 2006-08-11 14:30:35.657 -rwxrwxr-x 1 basis10 basis 478 Aug 10 12:01 check_admin.dat
. 2006-08-11 14:30:35.657 Received 74 bytes
< 2006-08-11 14:30:35.657 -rwxrwxr-x 1 basis10 basis 160 Aug 9 19:00 collection_type.dat
< 2006-08-11 14:30:35.657 -rwxrwxr-x 1 basis10 basis 0 Jun 29 11:33 collection_type.rej
< 2006-08-11 14:30:35.657 -rwxrwxr-x 1 basis10 basis 878 Aug 9 19:01 copy.dat
< 2006-08-11 14:30:35.657 -rwxrwxr-x 1 basis10 basis 0 Jun 29 11:33 copy.rej
. 2006-08-11 14:30:35.657 Received 67 bytes
< 2006-08-11 14:30:35.657 -rwxrwxr-x 1 basis10 basis 36992 Aug 10 09:53 division.dat
. 2006-08-11 14:30:35.657 Received 72 bytes
< 2006-08-11 14:30:35.657 -rwxrwxr-x 1 basis10 basis 9281251 Aug 9 19:05 document_pubs.dat
. 2006-08-11 14:30:35.657 Received 68 bytes
< 2006-08-11 14:30:35.657 -rwxrwxr-x 1 basis10 basis 20773039 Aug 9 19:05 employee.dat
< 2006-08-11 14:30:35.657 -rwxrwxr-x 1 basis10 basis 3975 Aug 9 19:01 exchange.dat
< 2006-08-11 14:30:35.657 -rwxrwxr-x 1 basis10 basis 0 Jun 29 11:33 exchange.rej
< 2006-08-11 14:30:35.657 -rwxrwxr-x 1 basis10 basis 12254 Aug 10 09:55 funding.dat
< 2006-08-11 14:30:35.657 -rwxrwxr-x 1 basis10 basis 20693165 Aug 9 19:05 inactive.dat
< 2006-08-11 14:30:35.657 -rwxrwxr-x 1 basis10 basis 27957417 Aug 9 19:04 index.dat
< 2006-08-11 14:30:35.657 -rwxrwxr-x 1 basis10 basis 0 Jun 29 11:43 index.rej
< 2006-08-11 14:30:35.657 -rwxrwxr-x 1 basis10 basis 3385646 Aug 9 19:01 invoice.dat
< 2006-08-11 14:30:35.657 -rwxrwxr-x 1 basis10 basis 0 Jun 29 11:33 invoice.rej
< 2006-08-11 14:30:35.657 -rwxrwxr-x 1 basis10 basis 10926 Aug 10 09:55 journal.dat
< 2006-08-11 14:30:35.657 -rwxrwxr-x 1 basis10 basis 1424 Aug 9 19:00 libr.dat
< 2006-08-11 14:30:35.657 -rwxrwxr-x 1 basis10 basis 0 Jun 29 11:33 libr.rej
< 2006-08-11 14:30:35.657 -rwxrwxr-x 1 basis10 basis 0 Aug 9 19:00 libr_addr.dat
< 2006-08-11 14:30:35.657 -rwxrwxr-x 1 basis10 basis 0 Jun 29 11:33 libr_addr.rej
< 2006-08-11 14:30:35.657 -rwxrwxr-x 1 basis10 basis 93906 Aug 9 19:00 marc_map.dat
< 2006-08-11 14:30:35.657 -rwxrwxr-x 1 basis10 basis 0 Jun 29 11:33 marc_map.rej
< 2006-08-11 14:30:35.657 -rwxrwxr-x 1 basis10 basis 3779 Aug 9 19:00 marc_parm.dat
< 2006-08-11 14:30:35.657 -rwxrwxr-x 1 basis10 basis 0 Jun 29 11:33 marc_parm.rej
< 2006-08-11 14:30:35.657 -rwxrwxr-x 1 basis10 basis 3405 Aug 9 19:00 material_type.dat
< 2006-08-11 14:30:35.657 -rwxrwxr-x 1 basis10 basis 0 Jun 29 11:33 material_type.rej
< 2006-08-11 14:30:35.657 -rwxrwxr-x 1 basis10 basis 22241627 Aug 9 19:00 patron.dat
< 2006-08-11 14:30:35.657 -rwxrwxr-x 1 basis10 basis 0 Jun 29 11:33 patron.rej
< 2006-08-11 14:30:35.657 -rwxrwxr-x 1 basis10 basis 15797 Aug 9 19:00 patron_type.dat
< 2006-08-11 14:30:35.657 -rwxrwxr-x 1 basis10 basis 0 Jun 29 11:33 patron_type.rej
. 2006-08-11 14:30:35.657 Received 61 bytes
< 2006-08-11 14:30:35.657 -rwxrwxr-x 1 basis10 basis 3533400 Aug 9 19:01 po.dat
< 2006-08-11 14:30:35.657 -rwxrwxr-x 1 basis10 basis 0 Jun 29 11:33 po.rej
< 2006-08-11 14:30:35.657 -rwxrwxr-x 1 basis10 basis 102149 Aug 9 19:00 profile.dat
< 2006-08-11 14:30:35.657 -rwxrwxr-x 1 basis10 basis 0 Jun 29 11:34 profile.rej
< 2006-08-11 14:30:35.657 -rwxrwxr-x 1 basis10 basis 4665969 Aug 9 19:05 request.dat
< 2006-08-11 14:30:35.657 -rwxrwxr-x 1 basis10 basis 215816 Aug 9 19:05 schedule.dat
. 2006-08-11 14:30:35.657 Received 73 bytes
< 2006-08-11 14:30:35.657 -rwxrwxr-x 1 basis10 basis 20877 Jun 28 16:39 staff_security.dat
< 2006-08-11 14:30:35.657 -rwxrwxr-x 1 basis10 basis 800 Aug 9 19:00 sys_parm.dat
< 2006-08-11 14:30:35.657 -rwxrwxr-x 1 basis10 basis 0 Jun 29 11:34 sys_parm.rej
< 2006-08-11 14:30:35.657 -rwxrwxr-x 1 basis10 basis 2289690 Aug 9 19:05 technb.dat
< 2006-08-11 14:30:35.657 -rwxrwxr-x 1 basis10 basis 0 Jun 29 11:38 technb.rej
< 2006-08-11 14:30:35.657 -rwxrwxr-x 1 basis10 basis 111083 Aug 9 19:00 template.dat
< 2006-08-11 14:30:35.657 -rwxrwxr-x 1 basis10 basis 0 Jun 29 11:34 template.rej
< 2006-08-11 14:30:35.657 -rwxrwxr-x 1 basis10 basis 23547 Aug 9 19:00 text.dat
< 2006-08-11 14:30:35.657 -rwxrwxr-x 1 basis10 basis 0 Jun 29 11:34 text.rej
< 2006-08-11 14:30:35.657 -rwxrwxr-x 1 basis10 basis 115439165 Aug 10 17:32 tps.dat
< 2006-08-11 14:30:35.657 -rwxrwxr-x 1 basis10 basis 110896530 Aug 10 11:51 tps_orig.dat
< 2006-08-11 14:30:35.657 -rw-rw-r-- 1 basis10 basis 3227 Aug 11 10:35 tps_test.dat
< 2006-08-11 14:30:35.657 -rw-rw-r-- 1 basis10 basis 3227 Aug 11 11:10 tps_test2.dat
< 2006-08-11 14:30:35.657 -rw-r--r-- 1 tzak users 3226 Aug 11 11:22 tps_test3.dat
< 2006-08-11 14:30:35.657 -rw-rw-r-- 1 basis10 basis 115439165 Aug 11 12:05 tps_test4.dat
< 2006-08-11 14:30:35.657 -rwxrwxr-x 1 basis10 basis 20877 Aug 9 19:02 user_security.dat
. 2006-08-11 14:30:35.797 Select result is 1
. 2006-08-11 14:30:35.797 Received 1 bytes
. 2006-08-11 14:30:35.797 Received 29 bytes
< 2006-08-11 14:30:35.797 WinSCP: this is end-of-file:0
* 2006-08-11 14:30:35.860 (ECommand) Copying files to remote side failed.
* 2006-08-11 14:30:35.860 Terminated by user.
. 2006-08-11 14:30:35.938 Session upkeep
. 2006-08-11 14:30:35.938 Select result is 0
. 2006-08-11 14:30:36.110 Session upkeep
. 2006-08-11 14:30:36.110 Select result is 0
. 2006-08-11 14:30:36.610 Session upkeep
. 2006-08-11 14:30:36.610 Select result is 0
. 2006-08-11 14:30:36.797 Session upkeep
. 2006-08-11 14:30:36.797 Select result is 0
. 2006-08-11 14:30:37.110 Session upkeep
. 2006-08-11 14:30:37.110 Select result is 0
. 2006-08-11 14:30:37.610 Session upkeep
. 2006-08-11 14:30:37.610 Select result is 0
. 2006-08-11 14:30:38.110 Session upkeep
. 2006-08-11 14:30:38.110 Select result is 0
. 2006-08-11 14:30:38.610 Session upkeep
. 2006-08-11 14:30:38.610 Select result is 0
. 2006-08-11 14:30:39.110 Session upkeep
. 2006-08-11 14:30:39.110 Select result is 0
. 2006-08-11 14:30:39.610 Session upkeep
. 2006-08-11 14:30:39.610 Select result is 0
. 2006-08-11 14:30:40.110 Session upkeep
. 2006-08-11 14:30:40.110 Select result is 0
. 2006-08-11 14:30:40.610 Session upkeep
. 2006-08-11 14:30:40.610 Select result is 0
. 2006-08-11 14:30:41.110 Session upkeep
. 2006-08-11 14:30:41.110 Select result is 0
. 2006-08-11 14:30:41.610 Session upkeep
. 2006-08-11 14:30:41.610 Select result is 0
. 2006-08-11 14:30:42.110 Session upkeep
. 2006-08-11 14:30:42.110 Select result is 0
. 2006-08-11 14:30:42.610 Session upkeep
. 2006-08-11 14:30:42.610 Select result is 0
. 2006-08-11 14:30:43.110 Session upkeep
. 2006-08-11 14:30:43.110 Select result is 0
. 2006-08-11 14:30:43.610 Session upkeep
. 2006-08-11 14:30:43.610 Select result is 0
. 2006-08-11 14:30:44.110 Session upkeep
. 2006-08-11 14:30:44.110 Select result is 0
. 2006-08-11 14:30:44.610 Session upkeep
. 2006-08-11 14:30:44.610 Select result is 0
. 2006-08-11 14:30:45.110 Session upkeep
. 2006-08-11 14:30:45.110 Select result is 0
. 2006-08-11 14:30:45.610 Session upkeep
. 2006-08-11 14:30:45.610 Select result is 0
. 2006-08-11 14:30:46.110 Session upkeep
. 2006-08-11 14:30:46.110 Select result is 0
. 2006-08-11 14:30:46.610 Session upkeep
. 2006-08-11 14:30:46.610 Select result is 0
. 2006-08-11 14:30:47.110 Session upkeep
. 2006-08-11 14:30:47.110 Select result is 0
. 2006-08-11 14:30:47.610 Session upkeep
. 2006-08-11 14:30:47.610 Select result is 0
. 2006-08-11 14:30:48.110 Session upkeep
. 2006-08-11 14:30:48.110 Select result is 0
. 2006-08-11 14:30:48.610 Session upkeep
. 2006-08-11 14:30:48.610 Select result is 0
. 2006-08-11 14:30:49.110 Session upkeep
. 2006-08-11 14:30:49.110 Select result is 0
. 2006-08-11 14:30:49.610 Session upkeep
. 2006-08-11 14:30:49.610 Select result is 0
. 2006-08-11 14:30:50.110 Session upkeep
. 2006-08-11 14:30:50.110 Select result is 0
. 2006-08-11 14:30:50.610 Session upkeep
. 2006-08-11 14:30:50.610 Select result is 0
. 2006-08-11 14:30:51.110 Session upkeep
. 2006-08-11 14:30:51.110 Select result is 0
. 2006-08-11 14:30:51.610 Session upkeep
. 2006-08-11 14:30:51.610 Select result is 0
. 2006-08-11 14:30:52.110 Session upkeep
. 2006-08-11 14:30:52.110 Select result is 0
. 2006-08-11 14:30:52.610 Session upkeep
. 2006-08-11 14:30:52.610 Select result is 0
. 2006-08-11 14:30:53.110 Session upkeep
. 2006-08-11 14:30:53.110 Select result is 0
. 2006-08-11 14:30:53.610 Session upkeep
. 2006-08-11 14:30:53.610 Select result is 0
. 2006-08-11 14:30:54.110 Session upkeep
. 2006-08-11 14:30:54.110 Select result is 0
. 2006-08-11 14:30:54.610 Session upkeep
. 2006-08-11 14:30:54.610 Select result is 0
. 2006-08-11 14:30:55.110 Session upkeep
. 2006-08-11 14:30:55.110 Select result is 0
. 2006-08-11 14:30:55.610 Session upkeep
. 2006-08-11 14:30:55.610 Select result is 0
. 2006-08-11 14:30:56.110 Session upkeep
. 2006-08-11 14:30:56.110 Select result is 0
. 2006-08-11 14:30:56.610 Session upkeep
. 2006-08-11 14:30:56.610 Select result is 0
. 2006-08-11 14:30:57.110 Session upkeep
. 2006-08-11 14:30:57.110 Select result is 0
. 2006-08-11 14:30:57.610 Session upkeep
. 2006-08-11 14:30:57.610 Select result is 0
. 2006-08-11 14:30:58.110 Session upkeep
. 2006-08-11 14:30:58.110 Select result is 0
. 2006-08-11 14:30:58.610 Session upkeep
. 2006-08-11 14:30:58.610 Select result is 0
. 2006-08-11 14:30:59.110 Session upkeep
. 2006-08-11 14:30:59.110 Select result is 0
. 2006-08-11 14:30:59.610 Session upkeep
. 2006-08-11 14:30:59.610 Select result is 0
. 2006-08-11 14:31:00.110 Session upkeep
. 2006-08-11 14:31:00.110 Select result is 0
. 2006-08-11 14:31:00.610 Session upkeep
. 2006-08-11 14:31:00.610 Select result is 0
. 2006-08-11 14:31:01.110 Session upkeep
. 2006-08-11 14:31:01.110 Select result is 0
. 2006-08-11 14:31:01.610 Session upkeep
. 2006-08-11 14:31:01.610 Select result is 0
. 2006-08-11 14:31:02.110 Session upkeep
. 2006-08-11 14:31:02.110 Select result is 0
. 2006-08-11 14:31:02.610 Session upkeep
. 2006-08-11 14:31:02.610 Select result is 0
. 2006-08-11 14:31:03.110 Session upkeep
. 2006-08-11 14:31:03.110 Select result is 0
. 2006-08-11 14:31:03.610 Session upkeep
. 2006-08-11 14:31:03.610 Select result is 0
. 2006-08-11 14:31:04.110 Session upkeep
. 2006-08-11 14:31:04.110 Select result is 0
. 2006-08-11 14:31:04.610 Session upkeep
. 2006-08-11 14:31:04.610 Select result is 0
. 2006-08-11 14:31:05.110 Session upkeep
. 2006-08-11 14:31:05.110 Select result is 0
. 2006-08-11 14:31:05.610 Session upkeep
. 2006-08-11 14:31:05.610 Select result is 0
. 2006-08-11 14:31:06.110 Session upkeep
. 2006-08-11 14:31:06.110 Select result is 0
. 2006-08-11 14:31:06.610 Session upkeep
. 2006-08-11 14:31:06.610 Select result is 0
. 2006-08-11 14:31:07.110 Session upkeep
. 2006-08-11 14:31:07.110 Select result is 0
. 2006-08-11 14:31:07.610 Session upkeep
. 2006-08-11 14:31:07.610 Select result is 0
. 2006-08-11 14:31:08.110 Session upkeep
. 2006-08-11 14:31:08.110 Select result is 0
. 2006-08-11 14:31:08.610 Session upkeep
. 2006-08-11 14:31:08.610 Select result is 0
. 2006-08-11 14:31:09.110 Session upkeep
. 2006-08-11 14:31:09.110 Select result is 0
. 2006-08-11 14:31:09.610 Session upkeep
. 2006-08-11 14:31:09.610 Select result is 0
. 2006-08-11 14:31:10.110 Session upkeep
. 2006-08-11 14:31:10.110 Select result is 0
. 2006-08-11 14:31:10.610 Session upkeep
. 2006-08-11 14:31:10.610 Select result is 0
. 2006-08-11 14:31:11.110 Session upkeep
. 2006-08-11 14:31:11.110 Select result is 0
. 2006-08-11 14:31:11.610 Session upkeep
. 2006-08-11 14:31:11.610 Select result is 0
. 2006-08-11 14:31:12.110 Session upkeep
. 2006-08-11 14:31:12.110 Select result is 0
. 2006-08-11 14:31:12.610 Session upkeep
. 2006-08-11 14:31:12.610 Select result is 0
. 2006-08-11 14:31:13.110 Session upkeep
. 2006-08-11 14:31:13.110 Select result is 0
. 2006-08-11 14:31:13.610 Session upkeep
. 2006-08-11 14:31:13.610 Select result is 0
. 2006-08-11 14:31:14.110 Session upkeep
. 2006-08-11 14:31:14.110 Select result is 0
. 2006-08-11 14:31:14.610 Session upkeep
. 2006-08-11 14:31:14.610 Select result is 0
. 2006-08-11 14:31:15.110 Session upkeep
. 2006-08-11 14:31:15.110 Select result is 0
. 2006-08-11 14:31:15.610 Session upkeep
. 2006-08-11 14:31:15.610 Select result is 0
. 2006-08-11 14:31:16.110 Session upkeep
. 2006-08-11 14:31:16.110 Select result is 0
. 2006-08-11 14:31:16.610 Session upkeep
. 2006-08-11 14:31:16.610 Select result is 0
. 2006-08-11 14:31:17.110 Session upkeep
. 2006-08-11 14:31:17.110 Select result is 0
. 2006-08-11 14:31:17.610 Session upkeep
. 2006-08-11 14:31:17.610 Select result is 0
. 2006-08-11 14:31:18.110 Session upkeep
. 2006-08-11 14:31:18.110 Select result is 0
. 2006-08-11 14:31:18.610 Session upkeep
. 2006-08-11 14:31:18.610 Select result is 0
. 2006-08-11 14:31:19.110 Session upkeep
. 2006-08-11 14:31:19.110 Select result is 0
. 2006-08-11 14:31:19.610 Session upkeep
. 2006-08-11 14:31:19.610 Select result is 0
. 2006-08-11 14:31:20.110 Session upkeep
. 2006-08-11 14:31:20.110 Select result is 0
. 2006-08-11 14:31:20.610 Session upkeep
. 2006-08-11 14:31:20.610 Select result is 0
. 2006-08-11 14:31:21.110 Session upkeep
. 2006-08-11 14:31:21.110 Select result is 0
. 2006-08-11 14:31:21.610 Session upkeep
. 2006-08-11 14:31:21.610 Select result is 0
. 2006-08-11 14:31:22.110 Session upkeep
. 2006-08-11 14:31:22.110 Select result is 0
. 2006-08-11 14:31:22.610 Session upkeep
. 2006-08-11 14:31:22.610 Select result is 0
. 2006-08-11 14:31:23.110 Session upkeep
. 2006-08-11 14:31:23.110 Select result is 0
. 2006-08-11 14:31:23.610 Session upkeep
. 2006-08-11 14:31:23.610 Select result is 0
. 2006-08-11 14:31:24.110 Session upkeep
. 2006-08-11 14:31:24.110 Select result is 0
. 2006-08-11 14:31:24.610 Session upkeep
. 2006-08-11 14:31:24.610 Select result is 0
. 2006-08-11 14:31:25.110 Session upkeep
. 2006-08-11 14:31:25.110 Select result is 0
. 2006-08-11 14:31:25.610 Session upkeep
. 2006-08-11 14:31:25.610 Select result is 0
. 2006-08-11 14:31:26.110 Session upkeep
. 2006-08-11 14:31:26.110 Select result is 0
. 2006-08-11 14:31:26.610 Session upkeep
. 2006-08-11 14:31:26.610 Select result is 0
. 2006-08-11 14:31:27.110 Session upkeep
. 2006-08-11 14:31:27.110 Select result is 0
. 2006-08-11 14:31:27.610 Session upkeep
. 2006-08-11 14:31:27.610 Select result is 0
. 2006-08-11 14:31:28.110 Session upkeep
. 2006-08-11 14:31:28.110 Select result is 0
. 2006-08-11 14:31:28.610 Session upkeep
. 2006-08-11 14:31:28.610 Select result is 0
. 2006-08-11 14:31:29.110 Session upkeep
. 2006-08-11 14:31:29.110 Select result is 0
. 2006-08-11 14:31:29.610 Session upkeep
. 2006-08-11 14:31:29.610 Select result is 0
. 2006-08-11 14:31:30.110 Session upkeep
. 2006-08-11 14:31:30.110 Select result is 0
. 2006-08-11 14:31:30.610 Session upkeep
. 2006-08-11 14:31:30.610 Select result is 0
. 2006-08-11 14:31:31.110 Session upkeep
. 2006-08-11 14:31:31.110 Select result is 0
. 2006-08-11 14:31:31.610 Session upkeep
. 2006-08-11 14:31:31.610 Select result is 0
. 2006-08-11 14:31:32.110 Session upkeep
. 2006-08-11 14:31:32.110 Select result is 0
. 2006-08-11 14:31:32.610 Session upkeep
. 2006-08-11 14:31:32.610 Select result is 0
. 2006-08-11 14:31:33.110 Session upkeep
. 2006-08-11 14:31:33.110 Select result is 0
. 2006-08-11 14:31:33.610 Session upkeep
. 2006-08-11 14:31:33.610 Select result is 0
. 2006-08-11 14:31:34.110 Session upkeep
. 2006-08-11 14:31:34.110 Select result is 0
. 2006-08-11 14:31:34.610 Session upkeep
. 2006-08-11 14:31:34.610 Select result is 0
. 2006-08-11 14:31:35.110 Session upkeep
. 2006-08-11 14:31:35.110 Select result is 0
. 2006-08-11 14:31:35.610 Session upkeep
. 2006-08-11 14:31:35.610 Select result is 0
. 2006-08-11 14:31:36.110 Session upkeep
. 2006-08-11 14:31:36.110 Select result is 0
. 2006-08-11 14:31:36.610 Session upkeep
. 2006-08-11 14:31:36.610 Select result is 0
. 2006-08-11 14:31:37.110 Session upkeep
. 2006-08-11 14:31:37.110 Select result is 0
. 2006-08-11 14:31:37.610 Session upkeep
. 2006-08-11 14:31:37.610 Select result is 0
. 2006-08-11 14:31:38.110 Session upkeep
. 2006-08-11 14:31:38.110 Select result is 0
. 2006-08-11 14:31:38.610 Session upkeep
. 2006-08-11 14:31:38.610 Select result is 0
. 2006-08-11 14:31:39.110 Session upkeep
. 2006-08-11 14:31:39.110 Select result is 0
. 2006-08-11 14:31:39.610 Session upkeep
. 2006-08-11 14:31:39.610 Select result is 0
. 2006-08-11 14:31:40.110 Session upkeep
. 2006-08-11 14:31:40.110 Select result is 0
. 2006-08-11 14:31:40.610 Session upkeep
. 2006-08-11 14:31:40.610 Select result is 0
. 2006-08-11 14:31:41.110 Session upkeep
. 2006-08-11 14:31:41.110 Select result is 0
. 2006-08-11 14:31:41.610 Session upkeep
. 2006-08-11 14:31:41.610 Select result is 0
. 2006-08-11 14:31:42.110 Session upkeep
. 2006-08-11 14:31:42.110 Select result is 0
. 2006-08-11 14:31:42.610 Session upkeep
. 2006-08-11 14:31:42.610 Select result is 0
. 2006-08-11 14:31:43.110 Session upkeep
. 2006-08-11 14:31:43.110 Select result is 0
. 2006-08-11 14:31:43.610 Session upkeep
. 2006-08-11 14:31:43.610 Select result is 0
. 2006-08-11 14:31:44.110 Session upkeep
. 2006-08-11 14:31:44.110 Select result is 0
. 2006-08-11 14:31:44.610 Session upkeep
. 2006-08-11 14:31:44.610 Select result is 0
. 2006-08-11 14:31:45.110 Session upkeep
. 2006-08-11 14:31:45.110 Select result is 0
. 2006-08-11 14:31:45.610 Session upkeep
. 2006-08-11 14:31:45.610 Select result is 0
. 2006-08-11 14:31:46.110 Session upkeep
. 2006-08-11 14:31:46.110 Select result is 0
. 2006-08-11 14:31:46.610 Session upkeep
. 2006-08-11 14:31:46.610 Select result is 0
. 2006-08-11 14:31:47.110 Session upkeep
. 2006-08-11 14:31:47.110 Select result is 0
. 2006-08-11 14:31:47.610 Session upkeep
. 2006-08-11 14:31:47.610 Select result is 0
. 2006-08-11 14:31:48.110 Session upkeep
. 2006-08-11 14:31:48.110 Select result is 0
. 2006-08-11 14:31:48.610 Session upkeep
. 2006-08-11 14:31:48.610 Select result is 0
. 2006-08-11 14:31:49.110 Session upkeep
. 2006-08-11 14:31:49.110 Select result is 0
. 2006-08-11 14:31:49.610 Session upkeep
. 2006-08-11 14:31:49.610 Select result is 0
. 2006-08-11 14:31:50.110 Session upkeep
. 2006-08-11 14:31:50.110 Select result is 0
. 2006-08-11 14:31:50.610 Session upkeep
. 2006-08-11 14:31:50.610 Select result is 0
. 2006-08-11 14:31:51.110 Session upkeep
. 2006-08-11 14:31:51.110 Select result is 0
. 2006-08-11 14:31:51.610 Session upkeep
. 2006-08-11 14:31:51.610 Select result is 0
. 2006-08-11 14:31:52.110 Session upkeep
. 2006-08-11 14:31:52.110 Select result is 0
. 2006-08-11 14:31:52.610 Session upkeep
. 2006-08-11 14:31:52.610 Select result is 0
. 2006-08-11 14:31:53.110 Session upkeep
. 2006-08-11 14:31:53.110 Select result is 0
. 2006-08-11 14:31:53.610 Session upkeep
. 2006-08-11 14:31:53.610 Select result is 0
. 2006-08-11 14:31:54.110 Session upkeep
. 2006-08-11 14:31:54.110 Select result is 0
. 2006-08-11 14:31:54.610 Session upkeep
. 2006-08-11 14:31:54.610 Select result is 0
. 2006-08-11 14:31:55.110 Session upkeep
. 2006-08-11 14:31:55.110 Select result is 0
. 2006-08-11 14:31:55.610 Session upkeep
. 2006-08-11 14:31:55.610 Select result is 0
. 2006-08-11 14:31:56.110 Session upkeep
. 2006-08-11 14:31:56.110 Select result is 0
. 2006-08-11 14:31:56.610 Session upkeep
. 2006-08-11 14:31:56.610 Select result is 0
. 2006-08-11 14:31:57.110 Session upkeep
. 2006-08-11 14:31:57.110 Select result is 0
. 2006-08-11 14:31:57.610 Session upkeep
. 2006-08-11 14:31:57.610 Select result is 0
. 2006-08-11 14:31:58.110 Session upkeep
. 2006-08-11 14:31:58.110 Select result is 0
. 2006-08-11 14:31:58.610 Session upkeep
. 2006-08-11 14:31:58.610 Select result is 0
. 2006-08-11 14:31:59.110 Session upkeep
. 2006-08-11 14:31:59.110 Select result is 0
. 2006-08-11 14:31:59.610 Session upkeep
. 2006-08-11 14:31:59.610 Select result is 0
. 2006-08-11 14:32:00.110 Session upkeep
. 2006-08-11 14:32:00.110 Select result is 0
. 2006-08-11 14:32:00.610 Session upkeep
. 2006-08-11 14:32:00.610 Select result is 0
. 2006-08-11 14:32:01.110 Session upkeep
. 2006-08-11 14:32:01.110 Select result is 0
. 2006-08-11 14:32:01.611 Session upkeep
. 2006-08-11 14:32:01.611 Select result is 0
. 2006-08-11 14:32:02.111 Session upkeep
. 2006-08-11 14:32:02.111 Select result is 0
. 2006-08-11 14:32:02.611 Session upkeep
. 2006-08-11 14:32:02.611 Select result is 0
. 2006-08-11 14:32:03.111 Session upkeep
. 2006-08-11 14:32:03.111 Select result is 0
. 2006-08-11 14:32:03.611 Session upkeep
. 2006-08-11 14:32:03.611 Select result is 0
. 2006-08-11 14:32:04.111 Session upkeep
. 2006-08-11 14:32:04.111 Select result is 0
. 2006-08-11 14:32:04.611 Session upkeep
. 2006-08-11 14:32:04.611 Select result is 0
. 2006-08-11 14:32:05.111 Session upkeep
. 2006-08-11 14:32:05.111 Select result is 0
. 2006-08-11 14:32:05.611 Session upkeep
. 2006-08-11 14:32:05.611 Select result is 0
. 2006-08-11 14:32:06.111 Session upkeep
. 2006-08-11 14:32:06.111 Select result is 0
. 2006-08-11 14:32:06.611 Session upkeep
. 2006-08-11 14:32:06.611 Select result is 0
. 2006-08-11 14:32:07.111 Session upkeep
. 2006-08-11 14:32:07.111 Select result is 0
. 2006-08-11 14:32:07.611 Session upkeep
. 2006-08-11 14:32:07.611 Select result is 0
. 2006-08-11 14:32:08.111 Session upkeep
. 2006-08-11 14:32:08.111 Select result is 0
. 2006-08-11 14:32:08.611 Session upkeep
. 2006-08-11 14:32:08.611 Select result is 0
. 2006-08-11 14:32:09.111 Session upkeep
. 2006-08-11 14:32:09.111 Select result is 0
. 2006-08-11 14:32:09.611 Session upkeep
. 2006-08-11 14:32:09.611 Select result is 0
. 2006-08-11 14:32:10.111 Session upkeep
. 2006-08-11 14:32:10.111 Select result is 0
. 2006-08-11 14:32:10.611 Session upkeep
. 2006-08-11 14:32:10.611 Select result is 0
. 2006-08-11 14:32:11.111 Session upkeep
. 2006-08-11 14:32:11.111 Select result is 0
. 2006-08-11 14:32:11.611 Session upkeep
. 2006-08-11 14:32:11.611 Select result is 0
. 2006-08-11 14:32:12.111 Session upkeep
. 2006-08-11 14:32:12.111 Select result is 0
. 2006-08-11 14:32:12.611 Session upkeep
. 2006-08-11 14:32:12.611 Select result is 0
. 2006-08-11 14:32:13.111 Session upkeep
. 2006-08-11 14:32:13.111 Select result is 0
. 2006-08-11 14:32:13.611 Session upkeep
. 2006-08-11 14:32:13.611 Select result is 0
. 2006-08-11 14:32:14.111 Session upkeep
. 2006-08-11 14:32:14.111 Select result is 0
. 2006-08-11 14:32:14.611 Session upkeep
. 2006-08-11 14:32:14.611 Select result is 0
. 2006-08-11 14:32:15.111 Session upkeep
. 2006-08-11 14:32:15.111 Select result is 0
. 2006-08-11 14:32:15.611 Session upkeep
. 2006-08-11 14:32:15.611 Select result is 0
. 2006-08-11 14:32:16.111 Session upkeep
. 2006-08-11 14:32:16.111 Select result is 0
. 2006-08-11 14:32:16.611 Session upkeep
. 2006-08-11 14:32:16.611 Select result is 0
. 2006-08-11 14:32:17.111 Session upkeep
. 2006-08-11 14:32:17.111 Select result is 0
. 2006-08-11 14:32:17.611 Session upkeep
. 2006-08-11 14:32:17.611 Select result is 0
. 2006-08-11 14:32:18.111 Session upkeep
. 2006-08-11 14:32:18.111 Select result is 0
. 2006-08-11 14:32:18.611 Session upkeep
. 2006-08-11 14:32:18.611 Select result is 0
. 2006-08-11 14:32:19.111 Session upkeep
. 2006-08-11 14:32:19.111 Select result is 0
. 2006-08-11 14:32:19.611 Session upkeep
. 2006-08-11 14:32:19.611 Select result is 0
. 2006-08-11 14:32:20.111 Session upkeep
. 2006-08-11 14:32:20.111 Select result is 0
. 2006-08-11 14:32:20.611 Session upkeep
. 2006-08-11 14:32:20.611 Select result is 0
. 2006-08-11 14:32:21.111 Session upkeep
. 2006-08-11 14:32:21.111 Select result is 0
. 2006-08-11 14:32:21.611 Session upkeep
. 2006-08-11 14:32:21.611 Select result is 0
. 2006-08-11 14:32:22.111 Session upkeep
. 2006-08-11 14:32:22.111 Select result is 0
. 2006-08-11 14:32:22.611 Session upkeep
. 2006-08-11 14:32:22.611 Select result is 0
. 2006-08-11 14:32:23.111 Session upkeep
. 2006-08-11 14:32:23.111 Select result is 0
. 2006-08-11 14:32:23.611 Session upkeep
. 2006-08-11 14:32:23.611 Select result is 0
. 2006-08-11 14:32:24.111 Session upkeep
. 2006-08-11 14:32:24.111 Select result is 0
. 2006-08-11 14:32:24.611 Session upkeep
. 2006-08-11 14:32:24.611 Select result is 0
. 2006-08-11 14:32:25.111 Session upkeep
. 2006-08-11 14:32:25.111 Select result is 0
. 2006-08-11 14:32:25.611 Session upkeep
. 2006-08-11 14:32:25.611 Select result is 0
. 2006-08-11 14:32:26.111 Session upkeep
. 2006-08-11 14:32:26.111 Select result is 0
. 2006-08-11 14:32:26.611 Session upkeep
. 2006-08-11 14:32:26.611 Select result is 0
. 2006-08-11 14:32:27.111 Session upkeep
. 2006-08-11 14:32:27.111 Select result is 0
. 2006-08-11 14:32:27.611 Session upkeep
. 2006-08-11 14:32:27.611 Select result is 0
. 2006-08-11 14:32:28.111 Session upkeep
. 2006-08-11 14:32:28.111 Select result is 0
. 2006-08-11 14:32:28.611 Session upkeep
. 2006-08-11 14:32:28.611 Select result is 0
. 2006-08-11 14:32:29.111 Session upkeep
. 2006-08-11 14:32:29.111 Select result is 0
. 2006-08-11 14:32:29.611 Session upkeep
. 2006-08-11 14:32:29.611 Select result is 0
. 2006-08-11 14:32:30.111 Session upkeep
. 2006-08-11 14:32:30.111 Select result is 0
. 2006-08-11 14:32:30.611 Session upkeep
. 2006-08-11 14:32:30.611 Select result is 0
. 2006-08-11 14:32:31.111 Session upkeep
. 2006-08-11 14:32:31.111 Select result is 0
. 2006-08-11 14:32:31.611 Session upkeep
. 2006-08-11 14:32:31.611 Select result is 0
. 2006-08-11 14:32:32.111 Session upkeep
. 2006-08-11 14:32:32.111 Select result is 0
. 2006-08-11 14:32:32.611 Session upkeep
. 2006-08-11 14:32:32.611 Select result is 0
. 2006-08-11 14:32:33.111 Session upkeep
. 2006-08-11 14:32:33.111 Select result is 0
. 2006-08-11 14:32:33.611 Session upkeep
. 2006-08-11 14:32:33.611 Select result is 0
. 2006-08-11 14:32:34.111 Session upkeep
. 2006-08-11 14:32:34.111 Select result is 0
. 2006-08-11 14:32:34.611 Session upkeep
. 2006-08-11 14:32:34.611 Select result is 0
. 2006-08-11 14:32:35.111 Session upkeep
. 2006-08-11 14:32:35.111 Select result is 0
. 2006-08-11 14:32:35.611 Session upkeep
. 2006-08-11 14:32:35.611 Select result is 0
. 2006-08-11 14:32:36.111 Session upkeep
. 2006-08-11 14:32:36.111 Select result is 0
. 2006-08-11 14:32:36.611 Session upkeep
. 2006-08-11 14:32:36.611 Select result is 0
. 2006-08-11 14:32:37.111 Session upkeep
. 2006-08-11 14:32:37.111 Select result is 0
. 2006-08-11 14:32:37.611 Session upkeep
. 2006-08-11 14:32:37.611 Select result is 0
. 2006-08-11 14:32:38.111 Session upkeep
. 2006-08-11 14:32:38.111 Select result is 0
. 2006-08-11 14:32:38.611 Session upkeep
. 2006-08-11 14:32:38.611 Select result is 0
. 2006-08-11 14:32:39.111 Session upkeep
. 2006-08-11 14:32:39.111 Select result is 0
. 2006-08-11 14:32:39.611 Session upkeep
. 2006-08-11 14:32:39.611 Select result is 0
. 2006-08-11 14:32:40.111 Session upkeep
. 2006-08-11 14:32:40.111 Select result is 0
. 2006-08-11 14:32:40.611 Session upkeep
. 2006-08-11 14:32:40.611 Select result is 0
. 2006-08-11 14:32:41.111 Session upkeep
. 2006-08-11 14:32:41.111 Select result is 0
. 2006-08-11 14:32:41.611 Session upkeep
. 2006-08-11 14:32:41.611 Select result is 0
. 2006-08-11 14:32:42.111 Session upkeep
. 2006-08-11 14:32:42.111 Select result is 0
. 2006-08-11 14:32:42.611 Session upkeep
. 2006-08-11 14:32:42.611 Select result is 0
. 2006-08-11 14:32:43.111 Session upkeep
. 2006-08-11 14:32:43.111 Select result is 0
. 2006-08-11 14:32:43.611 Session upkeep
. 2006-08-11 14:32:43.611 Select result is 0
. 2006-08-11 14:32:44.111 Session upkeep
. 2006-08-11 14:32:44.111 Select result is 0
. 2006-08-11 14:32:44.611 Session upkeep
. 2006-08-11 14:32:44.611 Select result is 0
. 2006-08-11 14:32:45.111 Session upkeep
. 2006-08-11 14:32:45.111 Select result is 0
. 2006-08-11 14:32:45.611 Session upkeep
. 2006-08-11 14:32:45.611 Select result is 0
. 2006-08-11 14:32:46.111 Session upkeep
. 2006-08-11 14:32:46.111 Select result is 0
. 2006-08-11 14:32:46.611 Session upkeep
. 2006-08-11 14:32:46.611 Select result is 0
. 2006-08-11 14:32:47.111 Session upkeep
. 2006-08-11 14:32:47.111 Select result is 0
. 2006-08-11 14:32:47.611 Session upkeep
. 2006-08-11 14:32:47.611 Select result is 0
. 2006-08-11 14:32:48.111 Session upkeep
. 2006-08-11 14:32:48.111 Select result is 0
. 2006-08-11 14:32:48.611 Session upkeep
. 2006-08-11 14:32:48.611 Select result is 0
. 2006-08-11 14:32:49.111 Session upkeep
. 2006-08-11 14:32:49.111 Select result is 0
. 2006-08-11 14:32:49.611 Session upkeep
. 2006-08-11 14:32:49.611 Select result is 0
. 2006-08-11 14:32:50.111 Session upkeep
. 2006-08-11 14:32:50.111 Select result is 0
. 2006-08-11 14:32:50.611 Session upkeep
. 2006-08-11 14:32:50.611 Select result is 0
. 2006-08-11 14:32:51.111 Session upkeep
. 2006-08-11 14:32:51.111 Select result is 0
. 2006-08-11 14:32:51.611 Session upkeep
. 2006-08-11 14:32:51.611 Select result is 0
. 2006-08-11 14:32:52.111 Session upkeep
. 2006-08-11 14:32:52.111 Select result is 0
. 2006-08-11 14:32:52.611 Session upkeep
. 2006-08-11 14:32:52.611 Select result is 0
. 2006-08-11 14:32:53.111 Session upkeep
. 2006-08-11 14:32:53.111 Select result is 0
. 2006-08-11 14:32:53.611 Session upkeep
. 2006-08-11 14:32:53.611 Select result is 0
. 2006-08-11 14:32:54.111 Session upkeep
. 2006-08-11 14:32:54.111 Select result is 0
. 2006-08-11 14:32:54.611 Session upkeep
. 2006-08-11 14:32:54.611 Select result is 0
. 2006-08-11 14:32:55.111 Session upkeep
. 2006-08-11 14:32:55.111 Select result is 0
. 2006-08-11 14:32:55.611 Session upkeep
. 2006-08-11 14:32:55.611 Select result is 0
. 2006-08-11 14:32:56.111 Session upkeep
. 2006-08-11 14:32:56.111 Select result is 0
. 2006-08-11 14:32:56.611 Session upkeep
. 2006-08-11 14:32:56.611 Select result is 0
. 2006-08-11 14:32:57.111 Session upkeep
. 2006-08-11 14:32:57.111 Select result is 0
. 2006-08-11 14:32:57.611 Session upkeep
. 2006-08-11 14:32:57.611 Select result is 0
. 2006-08-11 14:32:58.111 Session upkeep
. 2006-08-11 14:32:58.111 Select result is 0
. 2006-08-11 14:32:58.611 Session upkeep
. 2006-08-11 14:32:58.611 Select result is 0
. 2006-08-11 14:32:59.111 Session upkeep
. 2006-08-11 14:32:59.111 Select result is 0
. 2006-08-11 14:32:59.611 Session upkeep
. 2006-08-11 14:32:59.611 Select result is 0
. 2006-08-11 14:33:00.111 Session upkeep
. 2006-08-11 14:33:00.111 Select result is 0
. 2006-08-11 14:33:00.611 Session upkeep
. 2006-08-11 14:33:00.611 Select result is 0
. 2006-08-11 14:33:01.111 Session upkeep
. 2006-08-11 14:33:01.111 Select result is 0
. 2006-08-11 14:33:01.611 Session upkeep
. 2006-08-11 14:33:01.611 Select result is 0
. 2006-08-11 14:33:02.111 Session upkeep
. 2006-08-11 14:33:02.111 Select result is 0
. 2006-08-11 14:33:02.611 Session upkeep
. 2006-08-11 14:33:02.611 Select result is 0
. 2006-08-11 14:33:03.111 Session upkeep
. 2006-08-11 14:33:03.111 Select result is 0
. 2006-08-11 14:33:03.611 Session upkeep
. 2006-08-11 14:33:03.611 Select result is 0
. 2006-08-11 14:33:04.111 Session upkeep
. 2006-08-11 14:33:04.111 Select result is 0
. 2006-08-11 14:33:04.611 Session upkeep
. 2006-08-11 14:33:04.611 Select result is 0
. 2006-08-11 14:33:05.111 Session upkeep
. 2006-08-11 14:33:05.111 Select result is 0
. 2006-08-11 14:33:05.611 Session upkeep
. 2006-08-11 14:33:05.611 Select result is 0
. 2006-08-11 14:33:06.111 Session upkeep
. 2006-08-11 14:33:06.111 Select result is 0
. 2006-08-11 14:33:06.611 Session upkeep
. 2006-08-11 14:33:06.611 Select result is 0
. 2006-08-11 14:33:07.111 Session upkeep
. 2006-08-11 14:33:07.111 Select result is 0
. 2006-08-11 14:33:07.611 Session upkeep
. 2006-08-11 14:33:07.611 Select result is 0
. 2006-08-11 14:33:08.111 Session upkeep
. 2006-08-11 14:33:08.111 Select result is 0
. 2006-08-11 14:33:08.611 Session upkeep
. 2006-08-11 14:33:08.611 Select result is 0
. 2006-08-11 14:33:09.111 Session upkeep
. 2006-08-11 14:33:09.111 Select result is 0
. 2006-08-11 14:33:09.611 Session upkeep
. 2006-08-11 14:33:09.611 Select result is 0
. 2006-08-11 14:33:10.111 Session upkeep
. 2006-08-11 14:33:10.111 Select result is 0
. 2006-08-11 14:33:10.611 Session upkeep
. 2006-08-11 14:33:10.611 Select result is 0
. 2006-08-11 14:33:11.111 Session upkeep
. 2006-08-11 14:33:11.111 Select result is 0
. 2006-08-11 14:33:11.611 Session upkeep
. 2006-08-11 14:33:11.611 Select result is 0
. 2006-08-11 14:33:12.111 Session upkeep
. 2006-08-11 14:33:12.111 Select result is 0
. 2006-08-11 14:33:12.611 Session upkeep
. 2006-08-11 14:33:12.611 Select result is 0
. 2006-08-11 14:33:13.111 Session upkeep
. 2006-08-11 14:33:13.111 Select result is 0
. 2006-08-11 14:33:13.611 Session upkeep
. 2006-08-11 14:33:13.611 Select result is 0
. 2006-08-11 14:33:14.111 Session upkeep
. 2006-08-11 14:33:14.111 Select result is 0
. 2006-08-11 14:33:14.611 Session upkeep
. 2006-08-11 14:33:14.611 Select result is 0
. 2006-08-11 14:33:15.111 Session upkeep
. 2006-08-11 14:33:15.111 Select result is 0
. 2006-08-11 14:33:15.611 Session upkeep
. 2006-08-11 14:33:15.611 Select result is 0
. 2006-08-11 14:33:16.111 Session upkeep
. 2006-08-11 14:33:16.111 Select result is 0
. 2006-08-11 14:33:16.611 Session upkeep
. 2006-08-11 14:33:16.611 Select result is 0
. 2006-08-11 14:33:17.111 Session upkeep
. 2006-08-11 14:33:17.111 Select result is 0
. 2006-08-11 14:33:17.611 Session upkeep
. 2006-08-11 14:33:17.611 Select result is 0
. 2006-08-11 14:33:18.111 Session upkeep
. 2006-08-11 14:33:18.111 Select result is 0
. 2006-08-11 14:33:18.611 Session upkeep
. 2006-08-11 14:33:18.611 Select result is 0
. 2006-08-11 14:33:19.111 Session upkeep
. 2006-08-11 14:33:19.111 Select result is 0
. 2006-08-11 14:33:19.611 Session upkeep
. 2006-08-11 14:33:19.611 Select result is 0
. 2006-08-11 14:33:20.111 Session upkeep
. 2006-08-11 14:33:20.111 Select result is 0
. 2006-08-11 14:33:20.611 Session upkeep
. 2006-08-11 14:33:20.611 Select result is 0
. 2006-08-11 14:33:21.111 Session upkeep
. 2006-08-11 14:33:21.111 Select result is 0
. 2006-08-11 14:33:21.611 Session upkeep
. 2006-08-11 14:33:21.611 Select result is 0
. 2006-08-11 14:33:22.111 Session upkeep
. 2006-08-11 14:33:22.111 Select result is 0
. 2006-08-11 14:33:22.611 Session upkeep
. 2006-08-11 14:33:22.611 Select result is 0
. 2006-08-11 14:33:23.111 Session upkeep
. 2006-08-11 14:33:23.111 Select result is 0
. 2006-08-11 14:33:23.611 Session upkeep
. 2006-08-11 14:33:23.611 Select result is 0
. 2006-08-11 14:33:24.111 Session upkeep
. 2006-08-11 14:33:24.111 Select result is 0
. 2006-08-11 14:33:24.611 Session upkeep
. 2006-08-11 14:33:24.611 Select result is 0
. 2006-08-11 14:33:25.111 Session upkeep
. 2006-08-11 14:33:25.111 Select result is 0
. 2006-08-11 14:33:25.611 Session upkeep
. 2006-08-11 14:33:25.611 Select result is 0
. 2006-08-11 14:33:26.111 Session upkeep
. 2006-08-11 14:33:26.111 Select result is 0
. 2006-08-11 14:33:26.611 Session upkeep
. 2006-08-11 14:33:26.611 Select result is 0
. 2006-08-11 14:33:27.111 Session upkeep
. 2006-08-11 14:33:27.111 Select result is 0
. 2006-08-11 14:33:27.611 Session upkeep
. 2006-08-11 14:33:27.611 Select result is 0
. 2006-08-11 14:33:28.111 Session upkeep
. 2006-08-11 14:33:28.111 Select result is 0
. 2006-08-11 14:33:28.611 Session upkeep
. 2006-08-11 14:33:28.611 Select result is 0
. 2006-08-11 14:33:29.111 Session upkeep
. 2006-08-11 14:33:29.111 Select result is 0
. 2006-08-11 14:33:29.611 Session upkeep
. 2006-08-11 14:33:29.611 Select result is 0
. 2006-08-11 14:33:30.111 Session upkeep
. 2006-08-11 14:33:30.111 Select result is 0
. 2006-08-11 14:33:30.611 Session upkeep
. 2006-08-11 14:33:30.611 Select result is 0
. 2006-08-11 14:33:31.111 Session upkeep
. 2006-08-11 14:33:31.111 Select result is 0
. 2006-08-11 14:33:31.611 Session upkeep
. 2006-08-11 14:33:31.611 Select result is 0
. 2006-08-11 14:33:32.111 Session upkeep
. 2006-08-11 14:33:32.111 Select result is 0
. 2006-08-11 14:33:32.611 Session upkeep
. 2006-08-11 14:33:32.611 Select result is 0
. 2006-08-11 14:33:33.111 Session upkeep
. 2006-08-11 14:33:33.111 Select result is 0
. 2006-08-11 14:33:33.611 Session upkeep
. 2006-08-11 14:33:33.611 Select result is 0
. 2006-08-11 14:33:34.111 Session upkeep
. 2006-08-11 14:33:34.111 Select result is 0
. 2006-08-11 14:33:34.611 Session upkeep
. 2006-08-11 14:33:34.611 Select result is 0
. 2006-08-11 14:33:35.111 Session upkeep
. 2006-08-11 14:33:35.111 Select result is 0
. 2006-08-11 14:33:35.611 Session upkeep
. 2006-08-11 14:33:35.611 Select result is 0
. 2006-08-11 14:33:36.111 Session upkeep
. 2006-08-11 14:33:36.111 Select result is 0
. 2006-08-11 14:33:36.611 Session upkeep
. 2006-08-11 14:33:36.611 Select result is 0
. 2006-08-11 14:33:37.111 Session upkeep
. 2006-08-11 14:33:37.111 Select result is 0
. 2006-08-11 14:33:37.611 Session upkeep
. 2006-08-11 14:33:37.611 Select result is 0
. 2006-08-11 14:33:38.111 Session upkeep
. 2006-08-11 14:33:38.111 Select result is 0
. 2006-08-11 14:33:38.611 Session upkeep
. 2006-08-11 14:33:38.611 Select result is 0
. 2006-08-11 14:33:39.111 Session upkeep
. 2006-08-11 14:33:39.111 Select result is 0
. 2006-08-11 14:33:39.611 Session upkeep
. 2006-08-11 14:33:39.611 Select result is 0
. 2006-08-11 14:33:40.111 Session upkeep
. 2006-08-11 14:33:40.111 Select result is 0
. 2006-08-11 14:33:40.611 Session upkeep
. 2006-08-11 14:33:40.611 Select result is 0
. 2006-08-11 14:33:41.111 Session upkeep
. 2006-08-11 14:33:41.111 Select result is 0
. 2006-08-11 14:33:41.611 Session upkeep
. 2006-08-11 14:33:41.611 Select result is 0
. 2006-08-11 14:33:42.111 Session upkeep
. 2006-08-11 14:33:42.111 Select result is 0
. 2006-08-11 14:33:42.611 Session upkeep
. 2006-08-11 14:33:42.611 Select result is 0
. 2006-08-11 14:33:43.111 Session upkeep
. 2006-08-11 14:33:43.111 Select result is 0
. 2006-08-11 14:33:43.611 Session upkeep
. 2006-08-11 14:33:43.611 Select result is 0
. 2006-08-11 14:33:44.111 Session upkeep
. 2006-08-11 14:33:44.111 Select result is 0
. 2006-08-11 14:33:44.611 Session upkeep
. 2006-08-11 14:33:44.611 Select result is 0
. 2006-08-11 14:33:45.111 Session upkeep
. 2006-08-11 14:33:45.111 Select result is 0
. 2006-08-11 14:33:45.611 Session upkeep
. 2006-08-11 14:33:45.611 Select result is 0
. 2006-08-11 14:33:46.111 Session upkeep
. 2006-08-11 14:33:46.111 Select result is 0
. 2006-08-11 14:33:46.611 Session upkeep
. 2006-08-11 14:33:46.611 Select result is 0
. 2006-08-11 14:33:47.111 Session upkeep
. 2006-08-11 14:33:47.111 Select result is 0
. 2006-08-11 14:33:47.611 Session upkeep
. 2006-08-11 14:33:47.611 Select result is 0
. 2006-08-11 14:33:48.111 Session upkeep
. 2006-08-11 14:33:48.111 Select result is 0
. 2006-08-11 14:33:48.611 Session upkeep
. 2006-08-11 14:33:48.611 Select result is 0
. 2006-08-11 14:33:49.111 Session upkeep
. 2006-08-11 14:33:49.111 Select result is 0
. 2006-08-11 14:33:49.611 Session upkeep
. 2006-08-11 14:33:49.611 Select result is 0
. 2006-08-11 14:33:50.111 Session upkeep
. 2006-08-11 14:33:50.111 Select result is 0
. 2006-08-11 14:33:50.611 Session upkeep
. 2006-08-11 14:33:50.611 Select result is 0
. 2006-08-11 14:33:51.111 Session upkeep
. 2006-08-11 14:33:51.111 Select result is 0
. 2006-08-11 14:33:51.611 Session upkeep
. 2006-08-11 14:33:51.611 Select result is 0
. 2006-08-11 14:33:52.111 Session upkeep
. 2006-08-11 14:33:52.111 Select result is 0
. 2006-08-11 14:33:52.611 Session upkeep
. 2006-08-11 14:33:52.611 Select result is 0
. 2006-08-11 14:33:53.111 Session upkeep
. 2006-08-11 14:33:53.111 Select result is 0
. 2006-08-11 14:33:53.611 Session upkeep
. 2006-08-11 14:33:53.611 Select result is 0
. 2006-08-11 14:33:54.111 Session upkeep
. 2006-08-11 14:33:54.111 Select result is 0
. 2006-08-11 14:33:54.611 Session upkeep
. 2006-08-11 14:33:54.611 Select result is 0
. 2006-08-11 14:33:55.111 Session upkeep
. 2006-08-11 14:33:55.111 Select result is 0
. 2006-08-11 14:33:55.611 Session upkeep
. 2006-08-11 14:33:55.611 Select result is 0
. 2006-08-11 14:33:56.111 Session upkeep
. 2006-08-11 14:33:56.111 Select result is 0
. 2006-08-11 14:33:56.611 Session upkeep
. 2006-08-11 14:33:56.611 Select result is 0
. 2006-08-11 14:33:57.111 Session upkeep
. 2006-08-11 14:33:57.111 Select result is 0
. 2006-08-11 14:33:57.611 Session upkeep
. 2006-08-11 14:33:57.611 Select result is 0
. 2006-08-11 14:33:58.111 Session upkeep
. 2006-08-11 14:33:58.111 Select result is 0
. 2006-08-11 14:33:58.611 Session upkeep
. 2006-08-11 14:33:58.611 Select result is 0
. 2006-08-11 14:33:59.111 Session upkeep
. 2006-08-11 14:33:59.111 Select result is 0
. 2006-08-11 14:33:59.611 Session upkeep
. 2006-08-11 14:33:59.611 Select result is 0
. 2006-08-11 14:34:00.111 Session upkeep
. 2006-08-11 14:34:00.111 Select result is 0
. 2006-08-11 14:34:00.611 Session upkeep
. 2006-08-11 14:34:00.611 Select result is 0
. 2006-08-11 14:34:01.111 Session upkeep
. 2006-08-11 14:34:01.111 Select result is 0
. 2006-08-11 14:34:01.611 Session upkeep
. 2006-08-11 14:34:01.611 Select result is 0
. 2006-08-11 14:34:02.111 Session upkeep
. 2006-08-11 14:34:02.111 Select result is 0
. 2006-08-11 14:34:02.611 Session upkeep
. 2006-08-11 14:34:02.611 Select result is 0
. 2006-08-11 14:34:03.111 Session upkeep
. 2006-08-11 14:34:03.111 Select result is 0
. 2006-08-11 14:34:03.611 Session upkeep
. 2006-08-11 14:34:03.611 Select result is 0
. 2006-08-11 14:34:04.111 Session upkeep
. 2006-08-11 14:34:04.111 Select result is 0
. 2006-08-11 14:34:04.611 Session upkeep
. 2006-08-11 14:34:04.611 Select result is 0
. 2006-08-11 14:34:05.111 Session upkeep
. 2006-08-11 14:34:05.111 Select result is 0
. 2006-08-11 14:34:05.611 Session upkeep
. 2006-08-11 14:34:05.611 Select result is 0
. 2006-08-11 14:34:06.111 Session upkeep
. 2006-08-11 14:34:06.111 Select result is 0
. 2006-08-11 14:34:06.611 Session upkeep
. 2006-08-11 14:34:06.611 Select result is 0
. 2006-08-11 14:34:07.111 Session upkeep
. 2006-08-11 14:34:07.111 Select result is 0
. 2006-08-11 14:34:07.611 Session upkeep
. 2006-08-11 14:34:07.611 Select result is 0
. 2006-08-11 14:34:08.111 Session upkeep
. 2006-08-11 14:34:08.111 Select result is 0
. 2006-08-11 14:34:08.611 Session upkeep
. 2006-08-11 14:34:08.611 Select result is 0
. 2006-08-11 14:34:09.111 Session upkeep
. 2006-08-11 14:34:09.111 Select result is 0
. 2006-08-11 14:34:09.611 Session upkeep
. 2006-08-11 14:34:09.611 Select result is 0
. 2006-08-11 14:34:10.111 Session upkeep
. 2006-08-11 14:34:10.111 Select result is 0
. 2006-08-11 14:34:10.611 Session upkeep
. 2006-08-11 14:34:10.611 Select result is 0
. 2006-08-11 14:34:11.111 Session upkeep
. 2006-08-11 14:34:11.111 Select result is 0
. 2006-08-11 14:34:11.611 Session upkeep
. 2006-08-11 14:34:11.611 Select result is 0
. 2006-08-11 14:34:12.111 Session upkeep
. 2006-08-11 14:34:12.111 Select result is 0
. 2006-08-11 14:34:12.611 Session upkeep
. 2006-08-11 14:34:12.611 Select result is 0
. 2006-08-11 14:34:13.111 Session upkeep
. 2006-08-11 14:34:13.111 Select result is 0
. 2006-08-11 14:34:13.611 Session upkeep
. 2006-08-11 14:34:13.611 Select result is 0
. 2006-08-11 14:34:14.111 Session upkeep
. 2006-08-11 14:34:14.111 Select result is 0
. 2006-08-11 14:34:14.611 Session upkeep
. 2006-08-11 14:34:14.611 Select result is 0
. 2006-08-11 14:34:15.111 Session upkeep
. 2006-08-11 14:34:15.111 Select result is 0
. 2006-08-11 14:34:15.611 Session upkeep
. 2006-08-11 14:34:15.611 Select result is 0
. 2006-08-11 14:34:16.111 Session upkeep
. 2006-08-11 14:34:16.111 Select result is 0
. 2006-08-11 14:34:16.611 Session upkeep
. 2006-08-11 14:34:16.611 Select result is 0
. 2006-08-11 14:34:17.111 Session upkeep
. 2006-08-11 14:34:17.111 Select result is 0
. 2006-08-11 14:34:17.611 Session upkeep
. 2006-08-11 14:34:17.611 Select result is 0
. 2006-08-11 14:34:18.111 Session upkeep
. 2006-08-11 14:34:18.111 Select result is 0
. 2006-08-11 14:34:18.611 Session upkeep
. 2006-08-11 14:34:18.611 Select result is 0
. 2006-08-11 14:34:19.111 Session upkeep
. 2006-08-11 14:34:19.111 Select result is 0
. 2006-08-11 14:34:19.611 Session upkeep
. 2006-08-11 14:34:19.611 Select result is 0
. 2006-08-11 14:34:20.111 Session upkeep
. 2006-08-11 14:34:20.111 Select result is 0
. 2006-08-11 14:34:20.611 Session upkeep
. 2006-08-11 14:34:20.611 Select result is 0
. 2006-08-11 14:34:21.111 Session upkeep
. 2006-08-11 14:34:21.111 Select result is 0
. 2006-08-11 14:34:21.611 Session upkeep
. 2006-08-11 14:34:21.611 Select result is 0
. 2006-08-11 14:34:22.111 Session upkeep
. 2006-08-11 14:34:22.111 Select result is 0
. 2006-08-11 14:34:22.611 Session upkeep
. 2006-08-11 14:34:22.611 Select result is 0
. 2006-08-11 14:34:23.111 Session upkeep
. 2006-08-11 14:34:23.111 Select result is 0
. 2006-08-11 14:34:23.611 Session upkeep
. 2006-08-11 14:34:23.611 Select result is 0
. 2006-08-11 14:34:24.111 Session upkeep
. 2006-08-11 14:34:24.111 Select result is 0
. 2006-08-11 14:34:24.611 Session upkeep
. 2006-08-11 14:34:24.611 Select result is 0
. 2006-08-11 14:34:25.111 Session upkeep
. 2006-08-11 14:34:25.111 Select result is 0
. 2006-08-11 14:34:25.611 Session upkeep
. 2006-08-11 14:34:25.611 Select result is 0
. 2006-08-11 14:34:26.111 Session upkeep
. 2006-08-11 14:34:26.111 Select result is 0
. 2006-08-11 14:34:26.611 Session upkeep
. 2006-08-11 14:34:26.611 Select result is 0
. 2006-08-11 14:34:27.111 Session upkeep
. 2006-08-11 14:34:27.111 Select result is 0
. 2006-08-11 14:34:27.611 Session upkeep
. 2006-08-11 14:34:27.611 Select result is 0
. 2006-08-11 14:34:28.111 Session upkeep
. 2006-08-11 14:34:28.111 Select result is 0
. 2006-08-11 14:34:28.611 Session upkeep
. 2006-08-11 14:34:28.611 Select result is 0
. 2006-08-11 14:34:29.111 Session upkeep
. 2006-08-11 14:34:29.111 Select result is 0
. 2006-08-11 14:34:29.611 Session upkeep
. 2006-08-11 14:34:29.611 Select result is 0
. 2006-08-11 14:34:30.111 Session upkeep
. 2006-08-11 14:34:30.111 Select result is 0
. 2006-08-11 14:34:30.611 Session upkeep
. 2006-08-11 14:34:30.611 Select result is 0
. 2006-08-11 14:34:31.111 Session upkeep
. 2006-08-11 14:34:31.111 Select result is 0
. 2006-08-11 14:34:31.611 Session upkeep
. 2006-08-11 14:34:31.611 Select result is 0
. 2006-08-11 14:34:32.111 Session upkeep
. 2006-08-11 14:34:32.111 Select result is 0
. 2006-08-11 14:34:32.611 Session upkeep
. 2006-08-11 14:34:32.611 Select result is 0
. 2006-08-11 14:34:33.111 Session upkeep
. 2006-08-11 14:34:33.111 Select result is 0
. 2006-08-11 14:34:33.611 Session upkeep
. 2006-08-11 14:34:33.611 Select result is 0
. 2006-08-11 14:34:34.111 Session upkeep
. 2006-08-11 14:34:34.111 Select result is 0
. 2006-08-11 14:34:34.611 Session upkeep
. 2006-08-11 14:34:34.611 Select result is 0
. 2006-08-11 14:34:35.111 Session upkeep
. 2006-08-11 14:34:35.111 Select result is 0
. 2006-08-11 14:34:35.611 Session upkeep
. 2006-08-11 14:34:35.611 Select result is 0
. 2006-08-11 14:34:36.111 Session upkeep
. 2006-08-11 14:34:36.111 Select result is 0
. 2006-08-11 14:34:36.611 Session upkeep
. 2006-08-11 14:34:36.611 Select result is 0
. 2006-08-11 14:34:37.111 Session upkeep
. 2006-08-11 14:34:37.111 Select result is 0
. 2006-08-11 14:34:37.612 Session upkeep
. 2006-08-11 14:34:37.612 Select result is 0
. 2006-08-11 14:34:38.112 Session upkeep
. 2006-08-11 14:34:38.112 Select result is 0
. 2006-08-11 14:34:38.612 Session upkeep
. 2006-08-11 14:34:38.612 Select result is 0
. 2006-08-11 14:34:39.112 Session upkeep
. 2006-08-11 14:34:39.112 Select result is 0
. 2006-08-11 14:34:39.612 Session upkeep
. 2006-08-11 14:34:39.612 Select result is 0
. 2006-08-11 14:34:40.112 Session upkeep
. 2006-08-11 14:34:40.112 Select result is 0
. 2006-08-11 14:34:40.612 Session upkeep
. 2006-08-11 14:34:40.612 Select result is 0
. 2006-08-11 14:34:41.112 Session upkeep
. 2006-08-11 14:34:41.112 Select result is 0
. 2006-08-11 14:34:41.612 Session upkeep
. 2006-08-11 14:34:41.612 Select result is 0
. 2006-08-11 14:34:42.112 Session upkeep
. 2006-08-11 14:34:42.112 Select result is 0
. 2006-08-11 14:34:42.612 Session upkeep
. 2006-08-11 14:34:42.612 Select result is 0
. 2006-08-11 14:34:43.112 Session upkeep
. 2006-08-11 14:34:43.112 Select result is 0
. 2006-08-11 14:34:43.612 Session upkeep
. 2006-08-11 14:34:43.612 Select result is 0
. 2006-08-11 14:34:44.112 Session upkeep
. 2006-08-11 14:34:44.112 Select result is 0
. 2006-08-11 14:34:44.612 Session upkeep
. 2006-08-11 14:34:44.612 Select result is 0
. 2006-08-11 14:34:45.112 Session upkeep
. 2006-08-11 14:34:45.112 Select result is 0
. 2006-08-11 14:34:45.612 Session upkeep
. 2006-08-11 14:34:45.612 Select result is 0
. 2006-08-11 14:34:46.112 Session upkeep
. 2006-08-11 14:34:46.112 Select result is 0
. 2006-08-11 14:34:46.612 Session upkeep
. 2006-08-11 14:34:46.612 Select result is 0
. 2006-08-11 14:34:47.112 Session upkeep
. 2006-08-11 14:34:47.112 Select result is 0
. 2006-08-11 14:34:47.612 Session upkeep
. 2006-08-11 14:34:47.612 Select result is 0
. 2006-08-11 14:34:48.112 Session upkeep
. 2006-08-11 14:34:48.112 Select result is 0
. 2006-08-11 14:34:48.612 Session upkeep
. 2006-08-11 14:34:48.612 Select result is 0
. 2006-08-11 14:34:49.112 Session upkeep
. 2006-08-11 14:34:49.112 Select result is 0
. 2006-08-11 14:34:49.612 Session upkeep
. 2006-08-11 14:34:49.612 Select result is 0
. 2006-08-11 14:34:50.112 Session upkeep
. 2006-08-11 14:34:50.112 Select result is 0
. 2006-08-11 14:34:50.612 Session upkeep
. 2006-08-11 14:34:50.612 Select result is 0
. 2006-08-11 14:34:51.112 Session upkeep
. 2006-08-11 14:34:51.112 Select result is 0
. 2006-08-11 14:34:51.612 Session upkeep
. 2006-08-11 14:34:51.612 Select result is 0
. 2006-08-11 14:34:52.112 Session upkeep
. 2006-08-11 14:34:52.112 Select result is 0
. 2006-08-11 14:34:52.612 Session upkeep
. 2006-08-11 14:34:52.612 Select result is 0
. 2006-08-11 14:34:53.112 Session upkeep
. 2006-08-11 14:34:53.112 Select result is 0
. 2006-08-11 14:34:53.612 Session upkeep
. 2006-08-11 14:34:53.612 Select result is 0
. 2006-08-11 14:34:54.112 Session upkeep
. 2006-08-11 14:34:54.112 Select result is 0
. 2006-08-11 14:34:54.612 Session upkeep
. 2006-08-11 14:34:54.612 Select result is 0
. 2006-08-11 14:34:55.112 Session upkeep
. 2006-08-11 14:34:55.112 Select result is 0
. 2006-08-11 14:34:55.612 Session upkeep
. 2006-08-11 14:34:55.612 Select result is 0
. 2006-08-11 14:34:56.112 Session upkeep
. 2006-08-11 14:34:56.112 Select result is 0
. 2006-08-11 14:34:56.612 Session upkeep
. 2006-08-11 14:34:56.612 Select result is 0
. 2006-08-11 14:34:57.112 Session upkeep
. 2006-08-11 14:34:57.112 Select result is 0
. 2006-08-11 14:34:57.612 Session upkeep
. 2006-08-11 14:34:57.612 Select result is 0
. 2006-08-11 14:34:58.112 Session upkeep
. 2006-08-11 14:34:58.112 Select result is 0
. 2006-08-11 14:34:58.612 Session upkeep
. 2006-08-11 14:34:58.612 Select result is 0
. 2006-08-11 14:34:59.112 Session upkeep
. 2006-08-11 14:34:59.112 Select result is 0
. 2006-08-11 14:34:59.612 Session upkeep
. 2006-08-11 14:34:59.612 Select result is 0
. 2006-08-11 14:35:00.112 Session upkeep
. 2006-08-11 14:35:00.112 Select result is 0
. 2006-08-11 14:35:00.612 Session upkeep
. 2006-08-11 14:35:00.612 Select result is 0
. 2006-08-11 14:35:01.112 Session upkeep
. 2006-08-11 14:35:01.112 Select result is 0
. 2006-08-11 14:35:01.612 Session upkeep
. 2006-08-11 14:35:01.612 Select result is 0
. 2006-08-11 14:35:02.112 Session upkeep
. 2006-08-11 14:35:02.112 Select result is 0
. 2006-08-11 14:35:02.612 Session upkeep
. 2006-08-11 14:35:02.612 Select result is 0
. 2006-08-11 14:35:03.112 Session upkeep
. 2006-08-11 14:35:03.112 Select result is 0
. 2006-08-11 14:35:03.612 Session upkeep
. 2006-08-11 14:35:03.612 Select result is 0
. 2006-08-11 14:35:04.112 Session upkeep
. 2006-08-11 14:35:04.112 Select result is 0
. 2006-08-11 14:35:04.612 Session upkeep
. 2006-08-11 14:35:04.612 Select result is 0
. 2006-08-11 14:35:05.112 Session upkeep
. 2006-08-11 14:35:05.112 Select result is 0
. 2
Please read documentation.
