Topic "Synchronized Browsing - Create Folders"
Steve
When using synchronized browsing, if you enter a folder that doesn't exist in the other window, it complains and disables the synch. Would it be possible to change this so it instead displays a dialog asking whether you'd like to disable sync or create the directory in question?
Not only would this half the number of dialogs you normally have to go through, but would mean I don't need to manually type in directory names.
And while i'm here, why is normal non-secure FTP not supported? I want to use WinSCP for everything, but unfortunately alot of servers I use aren't secure.
Many thanks.
-Steve
This have been asked already, so I give it now bit higher priority Smile
