Topic "No VMS Support :-("
akephalos
Is there any way to properly use a OpenVMS sftp server?
I can't seem to find any free sftp clients that work with VMS.
Any help is appreciated.
Forgive my vague request:
I am using the newest version 3.8.2(330), attempting to connect to an OpenVMS SFTP server, using the Norton style view.
When I use standard FTP, everything looks fine, but when I use SFTP,
- the dates all show 12/30/1899 12:00:00 AM;
- the permissions show a portion of the filename.. for example, if the file's name is 'MAILFILE_TEMP.LOG;9' , the rights column shows 'AILFILE_T'
- all the files have a 0 size
- directories do not work (quick info: VMS directories are 'name.DIR;#' where 'name' is the actually directory, and the ';#' is a version number of the directory (mostly always 1)
If anyone can shed some light I would be very.. thankful. Smile
Also, I am not sure if WinSCP does this, but it would be a great feature to be able to remove the trailing version number (the semicolon and the numbers after it..)
Glad to donate if we can resolve these issues, otherwise I will have to spend over $2,000 on licensing for a different program.
Thanks again,
- Brad
Are you sure you use SFTP? If you do, then what you describer is definitely a server-side bug. In case you use SCP, try SFTP instead.
Yes, it is SFTP I am using... when I use text based sftp it works fine, with output looking like this:
drwxr-x--x 2 4194322 64 512 Aug 17 23:05 MYFTP
-rw------- 1 4194322 64 10 Aug 17 13:07 NEW.JOU;3
-rw------- 1 4194322 64 10 Aug 17 13:07 NEW.JOU;2
-rw------- 1 4194322 64 10 Aug 17 13:07 NEW.JOU;1
drwx------ 2 4194322 64 512 Aug 11 12:22 SSH2
-rwxr-x--- 1 4194322 64 694 Aug 17 16:36 TCPIP$FTP_SERVER.LOG;223
-rw------- 1 4194322 64 106 Aug 15 13:39 USER.JOU;3
-rw------- 1 4194322 64 22 Aug 10 11:45 USER.JOU;2
-rw------- 1 4194322 64 122 Aug 09 15:32 USER.JOU;1
Perhaps if there were a way to do a directory definition, like in 'Attachmate Reflection SFTP Client'... ?
Please post a log file on (at least) Debug 1 level.
Doc
Here is a log file of a session to gein.vistech.net, including the upload of one file. The username and password used are publically known, user: DEMO password: USER.
Here's the log:
. 2007-03-18 17:16:56.501 --------------------------------------------------------------------------
. 2007-03-18 17:16:56.501 WinSCP Version 3.8.2 (Build 330) (OS 5.1.2600 Service Pack 2)
. 2007-03-18 17:16:56.501 Login time: 18 March 2007 17:16:56
. 2007-03-18 17:16:56.501 Session name: demo@gein.vistech.net
. 2007-03-18 17:16:56.501 Host name: gein.vistech.net (Port: 22)
. 2007-03-18 17:16:56.501 User name: demo (Password: Yes, Key file: No)
. 2007-03-18 17:16:56.516 Transfer Protocol: SFTP (SCP)
. 2007-03-18 17:16:56.516 SSH protocol version: 2; Compression: No
. 2007-03-18 17:16:56.516 Agent forwarding: No; TIS/CryptoCard: No; KI: Yes; GSSAPI: No
. 2007-03-18 17:16:56.516 Ciphers: aes,blowfish,3des,WARN,des; Ssh2DES: No
. 2007-03-18 17:16:56.516 Ping type: -, Ping interval: 30 sec; Timeout: 15 sec
. 2007-03-18 17:16:56.516 SSH Bugs: -,-,-,-,-,-,-,-
. 2007-03-18 17:16:56.516 SFTP Bugs: -,-,-
. 2007-03-18 17:16:56.516 Proxy: none
. 2007-03-18 17:16:56.516 Return code variable: Autodetect; Lookup user groups: Yes
. 2007-03-18 17:16:56.516 Shell: default, EOL: 0
. 2007-03-18 17:16:56.516 Local directory: default, Remote directory: home, Update: No, Cache: Yes
. 2007-03-18 17:16:56.516 Cache directory changes: Yes, Permanent: Yes
. 2007-03-18 17:16:56.516 Clear aliases: Yes, Unset nat.vars: Yes, Resolve symlinks: Yes
. 2007-03-18 17:16:56.516 Alias LS: No, Ign LS warn: Yes, Scp1 Comp: No
. 2007-03-18 17:16:56.516 --------------------------------------------------------------------------
. 2007-03-18 17:16:56.563 Looking up host "gein.vistech.net"
. 2007-03-18 17:16:56.579 Connecting to 66.0.156.249 port 22
. 2007-03-18 17:16:56.735 Waiting for the server to continue with the initialisation
. 2007-03-18 17:16:56.876 Server version: SSH-1.99-3.2.9 F-SECURE SSH 5.0.1 - Process Software MultiNet
. 2007-03-18 17:16:56.876 We claim version: SSH-2.0-WinSCP_release_3.8.2
. 2007-03-18 17:16:56.876 Using SSH protocol version 2
. 2007-03-18 17:16:56.891 Waiting for the server to continue with the initialisation
. 2007-03-18 17:16:58.766 Using Diffie-Hellman with standard group "group1"
. 2007-03-18 17:16:58.766 Doing Diffie-Hellman key exchange
. 2007-03-18 17:16:58.813 Waiting for the server to continue with the initialisation
. 2007-03-18 17:16:59.469 Host key fingerprint is:
. 2007-03-18 17:16:59.469 ssh-dss 1024 8a:8e:3c:6a:2b:47:ce:87:9f:e0:86:60:d2:94:e4:47
. 2007-03-18 17:16:59.485 Initialised AES-256 client->server encryption
. 2007-03-18 17:16:59.485 Initialised HMAC-SHA1 client->server MAC algorithm
. 2007-03-18 17:16:59.501 Waiting for the server to continue with the initialisation
. 2007-03-18 17:16:59.626 Initialised AES-256 server->client encryption
. 2007-03-18 17:16:59.641 Initialised HMAC-SHA1 server->client MAC algorithm
. 2007-03-18 17:16:59.641 Waiting for the server to continue with the initialisation
! 2007-03-18 17:16:59.782 Using username "demo".
. 2007-03-18 17:16:59.798 Waiting for the server to continue with the initialisation
! 2007-03-18 17:16:59.969            Welcome to Gein.vistech.net [Alpha DS10L Under OpenVMS 7.3]
! 2007-03-18 17:16:59.985                           .aMMMMP  dMMMMMP dMP  dMMMMb
! 2007-03-18 17:17:00.001                          dMP"     dMP     dMP  dMP dMP
! 2007-03-18 17:17:00.016                         dMP MMP" dMMMP   dMP  dMP dMP
! 2007-03-18 17:17:00.016                        dMP.DMP  dMP     dMP  dMP dMP
! 2007-03-18 17:17:00.032                        VMMMp"  dMMMMMP dMP  dMP dMP
! 2007-03-18 17:17:00.048                     Public Access DEC Alpha/OpenVMS 7.3
! 2007-03-18 17:17:00.063             For more information about how to get a account here,
! 2007-03-18 17:17:00.079                 Please check out http://deathrow.vistech.net!
! 2007-03-18 17:17:00.094                 IRC Server: irc.2600.net / IRC Channel: #vms
! 2007-03-18 17:17:00.110          (Select "Deathrow Chat" @ http://deathrow.vistech.net)
! 2007-03-18 17:17:00.126 ------------------------------------------------------------------------------
! 2007-03-18 17:17:00.141 Want a account?  New users.....    Login under -> "NEWUSER"/Password="NEWUSER"
! 2007-03-18 17:17:00.157 For "Guest" access to a DCL prompt Login under -> "DEMO"/Password="USER"
! 2007-03-18 17:17:00.157 To play the online GAMES.......    Login under -> "GAMES/Password="PRESSPLAY"
! 2007-03-18 17:17:00.173 ------------------------------------------------------------------------------
! 2007-03-18 17:17:00.188 This Node was graciously donated by http://www.islandco.com [Island Computers]
! 2007-03-18 17:17:00.204 ** README ** README ** README ** README ** README ** README ** README ** README
! 2007-03-18 17:17:00.235 The Deathrow cluster has experienced yet another hardware failure.   Shortly
! 2007-03-18 17:17:00.251 after repairing the system disk in MANSON,  DAHMER's power supply (PSU) died.
! 2007-03-18 17:17:00.266 DAHMER is offline until we can either fix orr replace that system.  If you
! 2007-03-18 17:17:00.266 are having password problems,  please e-mail admin@deathrow.vistech.net.
! 2007-03-18 17:17:00.298 NEWUSER login is re-enabled.  On node MANSON,  NEWUSER has not been re-enabled.
! 2007-03-18 17:17:00.329 ** README ** README ** README ** README ** README ** README ** README ** README
. 2007-03-18 17:17:02.016 Waiting for the server to continue with the initialisation
. 2007-03-18 17:17:02.032 Session password prompt (demo@gein.vistech.net's password: )
. 2007-03-18 17:17:02.048 Using stored password.
! 2007-03-18 17:17:02.063 Authenticating with pre-entered password.
. 2007-03-18 17:17:02.079 Sent password
. 2007-03-18 17:17:02.094 Waiting for the server to continue with the initialisation
. 2007-03-18 17:17:02.235 Access granted
. 2007-03-18 17:17:02.266 Waiting for the server to continue with the initialisation
. 2007-03-18 17:17:02.407 Opened channel for session
. 2007-03-18 17:17:02.423 Waiting for the server to continue with the initialisation
. 2007-03-18 17:17:03.063 Started a shell/command
. 2007-03-18 17:17:03.094 --------------------------------------------------------------------------
. 2007-03-18 17:17:03.110 Using SFTP protocol.
. 2007-03-18 17:17:03.126 Doing startup conversation with host.
> 2007-03-18 17:17:03.141 Type: SSH_FXP_INIT, Size: 5, Number: -1
. 2007-03-18 17:17:03.157 Sent 9 bytes
. 2007-03-18 17:17:03.173 There are 0 bytes remaining in the send buffer
. 2007-03-18 17:17:03.188 Waiting for another 4 bytes
. 2007-03-18 17:17:05.391 Received 4 bytes
. 2007-03-18 17:17:05.407 Received 461 bytes
< 2007-03-18 17:17:05.423 Type: SSH_FXP_VERSION, Size: 461, Number: -1
. 2007-03-18 17:17:05.454 SFTP version 4 negotiated.
. 2007-03-18 17:17:05.469 Unknown server extension SRI_ON_ODS5@PROCESS.COM=FALSE
. 2007-03-18 17:17:05.485 Server requests EOL sequence 0x0D0A.
. 2007-03-18 17:17:05.501 Server software: MultiNet V5.1 (10837698) by PROCESS.COM
. 2007-03-18 17:17:05.532 Server support information:
. 2007-03-18 17:17:05.532   Attribute mask: 800001FF, Attribute bits: 0, Open flags: 7F
. 2007-03-18 17:17:05.532   Access mask: 0, Open block masks: 0, Block masks: 0, Max read size: 32256
. 2007-03-18 17:17:05.563   Attribute extensions (0)
. 2007-03-18 17:17:05.579   Extensions (9)
. 2007-03-18 17:17:05.594     text-seek
. 2007-03-18 17:17:05.626     space-available
. 2007-03-18 17:17:05.641     OVMS@PROCESS.COM
. 2007-03-18 17:17:05.673     TRANSLATE_VMS@PROCESS.COM
. 2007-03-18 17:17:05.688     BINARY@PROCESS.COM
. 2007-03-18 17:17:05.704     SRI_ON_ODS5@PROCESS.COM
. 2007-03-18 17:17:05.735     GETDVI_ODS@PROCESS.COM
. 2007-03-18 17:17:05.751     ALL_VERSIONS@PROCESS.COM
. 2007-03-18 17:17:05.782     open_record@process.com
. 2007-03-18 17:17:05.798 SFTP versions supported by the server: 2,3,4
. 2007-03-18 17:17:05.829 Unknown server extension OVMS@PROCESS.COM=1.2
. 2007-03-18 17:17:05.844 Unknown server extension TRANSLATE_VMS@PROCESS.COM=7
. 2007-03-18 17:17:05.876 We will use UTF-8 strings when appropriate
. 2007-03-18 17:17:05.891 Getting current directory name.
. 2007-03-18 17:17:05.923 Getting real path for '.'
> 2007-03-18 17:17:05.938 Type: SSH_FXP_REALPATH, Size: 10, Number: 1296
. 2007-03-18 17:17:05.969 Sent 14 bytes
. 2007-03-18 17:17:05.985 There are 0 bytes remaining in the send buffer
. 2007-03-18 17:17:06.016 Waiting for another 4 bytes
. 2007-03-18 17:17:06.360 Received 4 bytes
. 2007-03-18 17:17:06.391 Received 40 bytes
< 2007-03-18 17:17:06.407 Type: SSH_FXP_NAME, Size: 40, Number: 1296
. 2007-03-18 17:17:06.438 Real path is '/disk$users/users/demo'
. 2007-03-18 17:17:06.454 Listing directory "/disk$users/users/demo".
> 2007-03-18 17:17:06.469 Type: SSH_FXP_OPENDIR, Size: 31, Number: 1547
. 2007-03-18 17:17:06.501 Sent 35 bytes
. 2007-03-18 17:17:06.516 There are 0 bytes remaining in the send buffer
. 2007-03-18 17:17:06.548 Waiting for another 4 bytes
. 2007-03-18 17:17:06.641 Received 4 bytes
. 2007-03-18 17:17:06.673 Received 17 bytes
< 2007-03-18 17:17:06.688 Type: SSH_FXP_HANDLE, Size: 17, Number: 1547
> 2007-03-18 17:17:06.704 Type: SSH_FXP_READDIR, Size: 17, Number: 1804
. 2007-03-18 17:17:06.735 Sent 21 bytes
. 2007-03-18 17:17:06.751 There are 0 bytes remaining in the send buffer
. 2007-03-18 17:17:06.782 Waiting for another 4 bytes
. 2007-03-18 17:17:12.251 Waiting for another 4 bytes
. 2007-03-18 17:17:12.407 Received 4 bytes
. 2007-03-18 17:17:12.438 Received 5344 bytes
< 2007-03-18 17:17:12.454 Type: SSH_FXP_NAME, Size: 5344, Number: 1804
> 2007-03-18 17:17:12.485 Type: SSH_FXP_READDIR, Size: 17, Number: 2060
. 2007-03-18 17:17:12.501 Sent 21 bytes
. 2007-03-18 17:17:12.516 There are 0 bytes remaining in the send buffer
. 2007-03-18 17:17:12.548 Waiting for another 4 bytes
. 2007-03-18 17:17:12.641 Received 4 bytes
. 2007-03-18 17:17:12.673 Received 22 bytes
< 2007-03-18 17:17:12.688 Type: SSH_FXP_STATUS, Size: 22, Number: 2060
< 2007-03-18 17:17:12.719 Status/error code: 1
> 2007-03-18 17:17:12.735 Type: SSH_FXP_CLOSE, Size: 17, Number: 2308
. 2007-03-18 17:17:12.766 Sent 21 bytes
. 2007-03-18 17:17:12.782 There are 0 bytes remaining in the send buffer
. 2007-03-18 17:17:12.798 Startup conversation with host finished.
. 2007-03-18 17:17:12.876 Session upkeep
. 2007-03-18 17:17:13.141 Session upkeep
. 2007-03-18 17:17:13.157 Detected incoming data while idle
. 2007-03-18 17:17:13.641 Session upkeep
. 2007-03-18 17:17:14.141 Session upkeep
. 2007-03-18 17:17:14.641 Session upkeep
. 2007-03-18 17:17:15.141 Session upkeep
. 2007-03-18 17:17:15.641 Session upkeep
. 2007-03-18 17:17:16.141 Session upkeep
. 2007-03-18 17:17:16.641 Session upkeep
. 2007-03-18 17:17:17.141 Session upkeep
. 2007-03-18 17:17:17.641 Session upkeep
. 2007-03-18 17:17:18.141 Session upkeep
. 2007-03-18 17:17:18.641 Session upkeep
. 2007-03-18 17:17:19.141 Session upkeep
. 2007-03-18 17:17:19.641 Session upkeep
. 2007-03-18 17:17:20.141 Session upkeep
. 2007-03-18 17:17:20.641 Session upkeep
. 2007-03-18 17:17:21.141 Session upkeep
. 2007-03-18 17:17:21.641 Session upkeep
. 2007-03-18 17:17:22.141 Session upkeep
. 2007-03-18 17:17:22.641 Session upkeep
. 2007-03-18 17:17:23.141 Session upkeep
. 2007-03-18 17:17:23.641 Session upkeep
. 2007-03-18 17:17:24.141 Session upkeep
. 2007-03-18 17:17:24.641 Session upkeep
. 2007-03-18 17:17:25.141 Session upkeep
. 2007-03-18 17:17:25.641 Session upkeep
. 2007-03-18 17:17:26.141 Session upkeep
. 2007-03-18 17:17:26.641 Session upkeep
. 2007-03-18 17:17:27.141 Session upkeep
. 2007-03-18 17:17:27.641 Session upkeep
. 2007-03-18 17:17:28.141 Session upkeep
. 2007-03-18 17:17:28.641 Session upkeep
. 2007-03-18 17:17:29.141 Session upkeep
. 2007-03-18 17:17:29.641 Session upkeep
. 2007-03-18 17:17:30.141 Session upkeep
. 2007-03-18 17:17:30.173 Session upkeep
. 2007-03-18 17:17:30.641 Session upkeep
. 2007-03-18 17:17:31.141 Session upkeep
. 2007-03-18 17:17:31.641 Session upkeep
. 2007-03-18 17:17:32.141 Session upkeep
. 2007-03-18 17:17:32.641 Session upkeep
. 2007-03-18 17:17:33.141 Session upkeep
. 2007-03-18 17:17:33.641 Session upkeep
. 2007-03-18 17:17:34.141 Session upkeep
. 2007-03-18 17:17:34.641 Session upkeep
. 2007-03-18 17:17:35.141 Session upkeep
. 2007-03-18 17:17:35.641 Session upkeep
. 2007-03-18 17:17:36.141 Session upkeep
. 2007-03-18 17:17:36.641 Session upkeep
. 2007-03-18 17:17:37.141 Session upkeep
. 2007-03-18 17:17:37.641 Session upkeep
. 2007-03-18 17:17:38.141 Session upkeep
. 2007-03-18 17:17:38.641 Session upkeep
. 2007-03-18 17:17:39.141 Session upkeep
. 2007-03-18 17:17:39.641 Session upkeep
. 2007-03-18 17:17:40.141 Session upkeep
. 2007-03-18 17:17:40.641 Session upkeep
. 2007-03-18 17:17:41.141 Session upkeep
. 2007-03-18 17:17:41.641 Session upkeep
. 2007-03-18 17:17:42.141 Session upkeep
. 2007-03-18 17:17:42.641 Session upkeep
. 2007-03-18 17:17:43.141 Session upkeep
. 2007-03-18 17:17:43.641 Session upkeep
. 2007-03-18 17:17:44.141 Session upkeep
. 2007-03-18 17:17:44.641 Session upkeep
. 2007-03-18 17:17:45.141 Session upkeep
. 2007-03-18 17:17:45.641 Session upkeep
. 2007-03-18 17:17:46.141 Session upkeep
. 2007-03-18 17:17:46.641 Session upkeep
. 2007-03-18 17:17:47.141 Session upkeep
. 2007-03-18 17:17:47.641 Session upkeep
. 2007-03-18 17:17:48.141 Session upkeep
. 2007-03-18 17:17:48.657 Session upkeep
. 2007-03-18 17:17:49.141 Session upkeep
. 2007-03-18 17:17:49.641 Session upkeep
. 2007-03-18 17:17:50.141 Session upkeep
. 2007-03-18 17:17:50.641 Session upkeep
. 2007-03-18 17:17:51.141 Session upkeep
. 2007-03-18 17:17:51.641 Session upkeep
. 2007-03-18 17:17:52.141 Session upkeep
. 2007-03-18 17:17:52.641 Session upkeep
. 2007-03-18 17:17:53.141 Session upkeep
. 2007-03-18 17:17:53.641 Session upkeep
. 2007-03-18 17:17:54.141 Session upkeep
. 2007-03-18 17:17:54.641 Session upkeep
. 2007-03-18 17:17:55.141 Session upkeep
. 2007-03-18 17:17:55.813 Session upkeep
. 2007-03-18 17:17:55.860 Session upkeep
. 2007-03-18 17:17:56.141 Session upkeep
. 2007-03-18 17:17:56.641 Session upkeep
. 2007-03-18 17:17:57.141 Session upkeep
. 2007-03-18 17:17:57.641 Session upkeep
. 2007-03-18 17:17:58.141 Session upkeep
. 2007-03-18 17:17:58.641 Session upkeep
. 2007-03-18 17:17:59.141 Session upkeep
. 2007-03-18 17:17:59.641 Session upkeep
. 2007-03-18 17:18:00.141 Session upkeep
. 2007-03-18 17:18:00.641 Session upkeep
. 2007-03-18 17:18:01.141 Session upkeep
. 2007-03-18 17:18:01.641 Session upkeep
. 2007-03-18 17:18:02.141 Session upkeep
. 2007-03-18 17:18:02.641 Session upkeep
. 2007-03-18 17:18:03.141 Session upkeep
. 2007-03-18 17:18:03.641 Session upkeep
. 2007-03-18 17:18:04.141 Session upkeep
. 2007-03-18 17:18:04.641 Session upkeep
. 2007-03-18 17:18:05.141 Session upkeep
. 2007-03-18 17:18:05.641 Session upkeep
. 2007-03-18 17:18:06.141 Session upkeep
. 2007-03-18 17:18:06.641 Session upkeep
. 2007-03-18 17:18:07.141 Session upkeep
. 2007-03-18 17:18:07.641 Session upkeep
. 2007-03-18 17:18:08.141 Session upkeep
. 2007-03-18 17:18:08.641 Session upkeep
. 2007-03-18 17:18:08.876 Session upkeep
. 2007-03-18 17:18:09.141 Session upkeep
. 2007-03-18 17:18:09.719 Session upkeep
. 2007-03-18 17:18:10.141 Session upkeep
. 2007-03-18 17:18:11.329 Session upkeep
. 2007-03-18 17:18:11.641 Session upkeep
. 2007-03-18 17:18:12.141 Session upkeep
. 2007-03-18 17:18:12.641 Session upkeep
. 2007-03-18 17:18:13.141 Session upkeep
. 2007-03-18 17:18:13.641 Session upkeep
. 2007-03-18 17:18:14.141 Session upkeep
. 2007-03-18 17:18:14.641 Session upkeep
. 2007-03-18 17:18:15.141 Session upkeep
. 2007-03-18 17:18:15.641 Session upkeep
. 2007-03-18 17:18:16.141 Session upkeep
. 2007-03-18 17:18:16.641 Session upkeep
. 2007-03-18 17:18:17.141 Session upkeep
. 2007-03-18 17:18:17.641 Session upkeep
. 2007-03-18 17:18:18.141 Session upkeep
. 2007-03-18 17:18:18.641 Session upkeep
. 2007-03-18 17:18:19.141 Session upkeep
. 2007-03-18 17:18:19.641 Session upkeep
. 2007-03-18 17:18:20.141 Session upkeep
. 2007-03-18 17:18:20.641 Session upkeep
. 2007-03-18 17:18:21.141 Session upkeep
. 2007-03-18 17:18:21.641 Session upkeep
. 2007-03-18 17:18:22.141 Session upkeep
. 2007-03-18 17:18:22.641 Session upkeep
. 2007-03-18 17:18:23.141 Session upkeep
. 2007-03-18 17:18:23.641 Session upkeep
. 2007-03-18 17:18:24.141 Session upkeep
. 2007-03-18 17:18:24.641 Session upkeep
. 2007-03-18 17:18:25.141 Session upkeep
. 2007-03-18 17:18:25.641 Session upkeep
. 2007-03-18 17:18:26.141 Session upkeep
. 2007-03-18 17:18:26.641 Session upkeep
. 2007-03-18 17:18:27.141 Session upkeep
. 2007-03-18 17:18:27.641 Session upkeep
. 2007-03-18 17:18:28.141 Session upkeep
. 2007-03-18 17:18:28.641 Session upkeep
. 2007-03-18 17:18:29.141 Session upkeep
. 2007-03-18 17:18:29.469 Copying 1 files/directories to remote directory "/disk$users/users/demo/i_like_basic_more/"
. 2007-03-18 17:18:29.501   PrTime: Yes; PrRO: Yes; Rght: rw-r--r--; PrR: No (No); FnCs: N; RIC: 01; Resume: S (102400); CalcS: Yes; Mask: *.*
. 2007-03-18 17:18:29.501   TM: M; ClAr: No; ExclM(No):
. 2007-03-18 17:18:29.501   AscM: *.*html; *.htm; *.txt; *.php*; *.cgi; *.c; *.cpp; *.h; *.pas; *.bas; *.tex; *.pl; .htaccess; *.xtml; *.css; *.cfg; *.ini; *.sh; *.xml
. 2007-03-18 17:18:29.532 File: "C:\Documents and Settings\Brian McNeil\My Documents\BA_halts_flights.jpg"
. 2007-03-18 17:18:29.579 Copying "C:\Documents and Settings\Brian McNeil\My Documents\BA_halts_flights.jpg" to remote directory started.
. 2007-03-18 17:18:29.610 Binary transfer mode selected.
. 2007-03-18 17:18:29.626 Opening remote file.
. 2007-03-18 17:18:29.641 Session upkeep
> 2007-03-18 17:18:29.673 Type: SSH_FXP_OPEN, Size: 87, Number: 2563
. 2007-03-18 17:18:29.688 Sent 91 bytes
. 2007-03-18 17:18:29.719 There are 0 bytes remaining in the send buffer
. 2007-03-18 17:18:29.735 Received 4 bytes
. 2007-03-18 17:18:29.766 Received 21 bytes
< 2007-03-18 17:18:29.782 Type: SSH_FXP_STATUS, Size: 21, Number: 2308
. 2007-03-18 17:18:29.813 Discarding reserved response
. 2007-03-18 17:18:29.844 Waiting for another 4 bytes
. 2007-03-18 17:18:29.923 Received 4 bytes
. 2007-03-18 17:18:29.938 Received 17 bytes
< 2007-03-18 17:18:29.969 Type: SSH_FXP_HANDLE, Size: 17, Number: 2563
> 2007-03-18 17:18:29.985 Type: SSH_FXP_WRITE, Size: 4125, Number: 3078
. 2007-03-18 17:18:30.016 Sent 4129 bytes
. 2007-03-18 17:18:30.048 There are 0 bytes remaining in the send buffer
> 2007-03-18 17:18:30.063 Type: SSH_FXP_WRITE, Size: 6754, Number: 3334
. 2007-03-18 17:18:30.266 Sent 6758 bytes
. 2007-03-18 17:18:30.282 Session upkeep
. 2007-03-18 17:18:30.313 There are 0 bytes remaining in the send buffer
> 2007-03-18 17:18:30.344 Type: SSH_FXP_WRITE, Size: 12187, Number: 3590
. 2007-03-18 17:18:30.673 Sent 12191 bytes
. 2007-03-18 17:18:30.673 Session upkeep
. 2007-03-18 17:18:30.704 Detected incoming data while idle
. 2007-03-18 17:18:30.735 There are 0 bytes remaining in the send buffer
> 2007-03-18 17:18:30.766 Type: SSH_FXP_WRITE, Size: 16380, Number: 3846
. 2007-03-18 17:18:31.313 Sent 16384 bytes
. 2007-03-18 17:18:31.329 Session upkeep
. 2007-03-18 17:18:31.360 Detected incoming data while idle
. 2007-03-18 17:18:31.391 There are 0 bytes remaining in the send buffer
. 2007-03-18 17:18:31.407 Received 4 bytes
. 2007-03-18 17:18:31.438 Received 21 bytes
< 2007-03-18 17:18:31.454 Type: SSH_FXP_STATUS, Size: 21, Number: 3078
< 2007-03-18 17:18:31.485 Status/error code: 0
> 2007-03-18 17:18:31.501 Type: SSH_FXP_WRITE, Size: 11054, Number: 4102
. 2007-03-18 17:18:31.782 Sent 11058 bytes
. 2007-03-18 17:18:31.782 Session upkeep
. 2007-03-18 17:18:31.813 Detected incoming data while idle
. 2007-03-18 17:18:31.860 There are 0 bytes remaining in the send buffer
. 2007-03-18 17:18:31.876 Received 4 bytes
. 2007-03-18 17:18:31.907 Received 21 bytes
< 2007-03-18 17:18:31.923 Type: SSH_FXP_STATUS, Size: 21, Number: 3334
< 2007-03-18 17:18:31.954 Status/error code: 0
. 2007-03-18 17:18:31.969 Received 4 bytes
. 2007-03-18 17:18:32.001 Received 21 bytes
< 2007-03-18 17:18:32.016 Type: SSH_FXP_STATUS, Size: 21, Number: 3590
< 2007-03-18 17:18:32.048 Status/error code: 0
> 2007-03-18 17:18:32.063 Type: SSH_FXP_CLOSE, Size: 17, Number: 4356
. 2007-03-18 17:18:32.094 Sent 21 bytes
. 2007-03-18 17:18:32.110 There are 0 bytes remaining in the send buffer
> 2007-03-18 17:18:32.141 Type: SSH_FXP_SETSTAT, Size: 91, Number: 2825
. 2007-03-18 17:18:32.141 Session upkeep
. 2007-03-18 17:18:32.173 Detected incoming data while idle
. 2007-03-18 17:18:32.204 Sent 95 bytes
. 2007-03-18 17:18:32.235 There are 0 bytes remaining in the send buffer
. 2007-03-18 17:18:32.251 Received 4 bytes
. 2007-03-18 17:18:32.266 Received 21 bytes
< 2007-03-18 17:18:32.298 Type: SSH_FXP_STATUS, Size: 21, Number: 3846
. 2007-03-18 17:18:32.313 Received 4 bytes
. 2007-03-18 17:18:32.344 Received 21 bytes
< 2007-03-18 17:18:32.360 Type: SSH_FXP_STATUS, Size: 21, Number: 4102
. 2007-03-18 17:18:32.391 Waiting for another 4 bytes
. 2007-03-18 17:18:32.407 Received 4 bytes
. 2007-03-18 17:18:32.438 Received 21 bytes
< 2007-03-18 17:18:32.454 Type: SSH_FXP_STATUS, Size: 21, Number: 4356
< 2007-03-18 17:18:32.485 Status/error code: 0
. 2007-03-18 17:18:32.501 Waiting for another 4 bytes
. 2007-03-18 17:18:32.673 Received 4 bytes
. 2007-03-18 17:18:32.673 Session upkeep
. 2007-03-18 17:18:32.719 Received 107 bytes
< 2007-03-18 17:18:32.735 Type: SSH_FXP_STATUS, Size: 107, Number: 2825
< 2007-03-18 17:18:32.766 Status/error code: 3, Message: 2825, Server: syserr: not owner, file: DISK$USERS:[USERS.DEMO.I_LIKE_BASIC_MORE]$BA_$HALTS_FLIGHTS.JPG, Language: en
* 2007-03-18 17:18:32.782 (ETerminal) Permission denied.
* 2007-03-18 17:18:32.782 Error code: 3
* 2007-03-18 17:18:32.782 Error message from server (en): syserr: not owner, file: DISK$USERS:[USERS.DEMO.I_LIKE_BASIC_MORE]$BA_$HALTS_FLIGHTS.JPG
* 2007-03-18 17:18:32.782 Request code: 9
. 2007-03-18 17:18:32.844 Asking user:
. 2007-03-18 17:18:32.844 Upload of file 'BA_halts_flights.jpg' was successful, but error occurred while setting the permissions and/or timestamp. If the problem persists, turn on 'Ignore permission errors' option. ("Permission denied.
. 2007-03-18 17:18:32.844 Error code: 3
. 2007-03-18 17:18:32.844 Error message from server (en): syserr: not owner, file: DISK$USERS:[USERS.DEMO.I_LIKE_BASIC_MORE]$BA_$HALTS_FLIGHTS.JPG
. 2007-03-18 17:18:32.844 Request code: 9")
. 2007-03-18 17:18:33.141 Session upkeep
. 2007-03-18 17:18:33.641 Session upkeep
. 2007-03-18 17:18:34.141 Session upkeep
. 2007-03-18 17:18:34.641 Session upkeep
. 2007-03-18 17:18:35.141 Session upkeep
. 2007-03-18 17:18:35.641 Session upkeep
. 2007-03-18 17:18:36.141 Session upkeep
* 2007-03-18 17:18:36.391 (EScpSkipFile) Upload of file 'BA_halts_flights.jpg' was successful, but error occurred while setting the permissions and/or timestamp. If the problem persists, turn on 'Ignore permission errors' option.
* 2007-03-18 17:18:36.391 Permission denied.
* 2007-03-18 17:18:36.391 Error code: 3
* 2007-03-18 17:18:36.391 Error message from server (en): syserr: not owner, file: DISK$USERS:[USERS.DEMO.I_LIKE_BASIC_MORE]$BA_$HALTS_FLIGHTS.JPG
* 2007-03-18 17:18:36.391 Request code: 9
. 2007-03-18 17:18:36.454 Cached directory not reloaded.
. 2007-03-18 17:18:36.469 Listing directory "/disk$users/users/demo".
> 2007-03-18 17:18:36.501 Type: SSH_FXP_OPENDIR, Size: 31, Number: 4619
. 2007-03-18 17:18:36.516 Sent 35 bytes
. 2007-03-18 17:18:36.548 There are 0 bytes remaining in the send buffer
. 2007-03-18 17:18:36.563 Waiting for another 4 bytes
. 2007-03-18 17:18:36.673 Received 4 bytes
. 2007-03-18 17:18:36.673 Session upkeep
. 2007-03-18 17:18:36.719 Received 17 bytes
< 2007-03-18 17:18:36.735 Type: SSH_FXP_HANDLE, Size: 17, Number: 4619
> 2007-03-18 17:18:36.751 Type: SSH_FXP_READDIR, Size: 17, Number: 4876
. 2007-03-18 17:18:36.782 Sent 21 bytes
. 2007-03-18 17:18:36.798 There are 0 bytes remaining in the send buffer
. 2007-03-18 17:18:36.829 Waiting for another 4 bytes
. 2007-03-18 17:18:42.360 Waiting for another 4 bytes
. 2007-03-18 17:18:42.360 Session upkeep
. 2007-03-18 17:18:42.516 Received 4 bytes
. 2007-03-18 17:18:42.532 Received 5344 bytes
< 2007-03-18 17:18:42.563 Type: SSH_FXP_NAME, Size: 5344, Number: 4876
> 2007-03-18 17:18:42.579 Type: SSH_FXP_READDIR, Size: 17, Number: 5132
. 2007-03-18 17:18:42.610 Sent 21 bytes
. 2007-03-18 17:18:42.626 There are 0 bytes remaining in the send buffer
. 2007-03-18 17:18:42.641 Session upkeep
. 2007-03-18 17:18:42.688 Waiting for another 4 bytes
. 2007-03-18 17:18:42.751 Received 4 bytes
. 2007-03-18 17:18:42.782 Received 22 bytes
< 2007-03-18 17:18:42.798 Type: SSH_FXP_STATUS, Size: 22, Number: 5132
< 2007-03-18 17:18:42.829 Status/error code: 1
> 2007-03-18 17:18:42.860 Type: SSH_FXP_CLOSE, Size: 17, Number: 5380
. 2007-03-18 17:18:42.876 Sent 21 bytes
. 2007-03-18 17:18:42.907 There are 0 bytes remaining in the send buffer
. 2007-03-18 17:18:43.141 Session upkeep
. 2007-03-18 17:18:43.157 Detected incoming data while idle
. 2007-03-18 17:18:43.641 Session upkeep
. 2007-03-18 17:18:44.204 Session upkeep
. 2007-03-18 17:18:44.641 Session upkeep
. 2007-03-18 17:18:45.141 Session upkeep
. 2007-03-18 17:18:45.641 Session upkeep
. 2007-03-18 17:18:46.141 Session upkeep
. 2007-03-18 17:18:46.641 Session upkeep
. 2007-03-18 17:18:47.141 Session upkeep
. 2007-03-18 17:18:47.641 Session upkeep
. 2007-03-18 17:18:48.141 Session upkeep
. 2007-03-18 17:18:48.641 Session upkeep
. 2007-03-18 17:18:49.141 Session upkeep
. 2007-03-18 17:18:49.641 Session upkeep
. 2007-03-18 17:18:50.141 Session upkeep
. 2007-03-18 17:18:50.641 Session upkeep
. 2007-03-18 17:18:51.141 Session upkeep
. 2007-03-18 17:18:51.641 Session upkeep
. 2007-03-18 17:18:52.141 Session upkeep
. 2007-03-18 17:18:52.641 Session upkeep
. 2007-03-18 17:18:53.141 Session upkeep
. 2007-03-18 17:18:53.641 Session upkeep
. 2007-03-18 17:18:54.141 Session upkeep
. 2007-03-18 17:18:54.641 Session upkeep
. 2007-03-18 17:18:55.016 Closing connection.
Here is what a full directory listing of the file looks like:
Directory USER_MANSON:[DEMO.I_LIKE_BASIC_MORE]
$BA_$HALTS_FLIGHTS.JPG;1                  File ID:  (81419,49,0)
Size:           99/99         Owner:    [DEMO_GROUP,DEMO]
Created:    18-MAR-2007 16:18:27.75
Revised:    18-MAR-2007 16:18:30.29 (2)
Expires:    <None specified>
Backup:     <No backup recorded>
Effective:  <None specified>
Recording:  <None specified>
Accessed:   <None specified>
Attributes: <None specified>
Modified:   <None specified>
Linkcount:  1
File organization:  Sequential
Shelved state:      Online
Caching attribute:  Writethrough
File attributes:    Allocation: 99, Extend: 0, Global buffer count: 0
                    No version limit
Record format:      Stream_LF, maximum 0 bytes, longest 32767 bytes
Record attributes:  Carriage return carriage control
RMS attributes:     None
Journaling enabled: None
File protection:    System:, Owner:, Group:, World:
Access Cntrl List:  (IDENTIFIER=[INMATE,DC],ACCESS=READ)
Client attributes:  None
Total of 1 file, 99/99 blocks.
Note the file protection says nobody has write permission to do anything.
Doc
If you require any help on the server side, please email admin@openvms-rocks.com, you can also find documentation on the server at http://www.openvms-rocks.com, my email address is doc@openvms-rocks and yes, I am one of the administrators, I was trying to set up instructions for using SFTP or SCP to upload web files to the system.
Thanks. I'll going to try it soon.
