Topic "Simple download from linux webserver to windows client"
adrian_vg
Just want to do a simple log-download from a linux webserver to a windows client and rename the local file to include a YYYY-MM-DD date.
So far I have a script file containing (script.txt):
rem get /var/log/httpd/webserver_access_log C:\logs\*_%date%.log
rem get /var/log/httpd/webserver_access_log C:\logs\*_'date +%F%'.log
get /var/log/httpd/webserver_access_log C:\logs\*+%F.log
and a scheduled task in windows, running the cmd-file containing the below line:
winscp3.exe user@webserver.domain.local /console /script=C:\logs\script.txt
The file downloads properly, but the rename fails on the windowss side, it just adds some weird looking thing, something like "webserver_access_log_%25date%25.log.
I don't have php or any scripting languange installed in windows, and would prefer leaving it that way. A simple download and rename is all I want - When the log is there in windows, I'm passing it to Analog to create some nice stats, again in windows.
It's rather obvious I'm missing something somewhere, so pls, if anybody could hint me or so, I'd be very grateful!
TIA.
WinSCP does not support this natively. You may use remote-side scripting, as shown in examples.
adrian_vg
Ok, thx. Will look into that.
adrian_vg
Worked like a charm! Turns out it was simpler than anticipated... 8-]
I used the below for script.txt:
call cp /var/log/httpd/webserver_access_log /tmp/webserver_access_log.`date +%F`.unique
get /tmp/*.unique *.log
In windows it produces a file "webserver_access_log.2006-08-22.log". Paired with a proper association for the .log-extension eg Notepad will be used to open it.
Thx for a great piece of software!
nightguy
My scheduled task in windows is not able to run and giving me the Last Result is 0x1
RUN: "C:\Program Files (x86)\WinSCP3\WinSCP3.exe" /console /script=MoveBackup.txt
Start in: "C:\Program Files (x86)\WinSCP3"
However, I successfullu ran this command on Command Prompt but not Window Schedule Task.
Please advice.
Have you read FAQ?
