Topic "Local directory not accessible"
marc
the connecttion to the remote server works fine and files are displayed. The local directory is empty, and no drives are available. It does not matter, if I choose a local directory or if I use the default. Version is 2.3.0 (Build 146).
Marc
Have you any hint, in which your system might differ? Meanwhile you may use drag&drop do upload/download files. Also explorer-like interface may work well for you.
marc
I found the problem in my configuration. The drive was unchecked in TweakUI / My Computer, so Winscp could not see it.
Thanks anyway
Marc
