Topic "How do I access my login script?"
Cosmin
I don't know how to find my login script? What is a login script? I have no files that start with a "." like ".profile" in c:/program files/winscp3... Isn't that my home directory?
Sorry for dumb questions.
Why do you look for login script? Login scripts are located on your server, in your home directory. Typically /home/<username>.
Cosmin
I'm trying to follow the instructions in your FAQ to fix the "received too large packet size error." But I'm running windows.. other than the "Run" command line, I don't know where to find that script that you suggest might be .profile.
The easiest way would be to login to your server using SSH terminal (such as PuTTY) and edit the files there.
wyim
i have the same error. i got to the .profile file, but i don't know what to edit.
Can you post a complete error message?
