Topic "Move works, Copy doesn't"
Nickalf
I'm trying to copy files back and forth from my Linux Server but, though I can use Move 'F6', Copy 'F5' doesn't apper to do anything. Neither does drag/drop.
Thanks for your help,
Nick. . .
What version of WinSCP are you using? What interface (norton commander or explorer)?
Guest1706
I'm experiencing the same problem - also drag and drop move works but not drag and drop copy. Using version 3.8.2 (build 330) with explorer interface
So what exactly happens if you press F5?
