Topic "WinSCP executing script from command line"
Leo
Hi. I am trying to create a script to login and get a file using the command line tool. I don't think I am doing it right and what I see on WinSCP help is not helping much. Can someone paste a couple of lines of code to show me how this is done? No matter how I write the script, it's always asking me for username & password.
here's the last script:
option batch on
open user:password@express.com
option transfer binary
get testfile1.txt c:\Temp\
close
and the output:
batch on
confirm off
Initialisation...
Searching for host...
Connecting to host...
Authenticating...
Using username "user".
Access denied.
Authentication failed.
Access denied.
Unable to authenticate
transfer binary
No session.
No session.
any ides?
Thanks for your help
(if I posted this twice, my apologies)
Does none know the answer to this question?
Can such thing be done?
option batch on
close
and the output:
batch on
confirm off
Initialisation...
Authenticating...
Access denied.
Access denied.
transfer binary
No session.
No session.
any ides?
The script is ok. Are you able to login from GUI with the same username/password as you use in the script?
otaraka
Hi Prikryl,
I have the same problem and to anwer your question, YES I am able to login with same user id and pwd usinng interactive command line and GUI. But when running through a batch file I am getting same error.
Can you please reply.
Cheers
Srini
otaraka
Hi Prikryl,
Sorry for posting in a hurry.
I gave wrong user id. Now it is working.
Regards,
Srini
