Topic "Is it possible to execute local mv?"
dmalesd
I have written a script and would like to perform a mv of files on the local PC. After looking at the commands list there seems to be only lpwd and lcd available.
Is there a way to execute other local commands for example mv?
David
It is not supported.
HermannSwiss
hm... so i cant do the following?!
1. Upload file from local to remote (script exists and works fine)
2. Move the uploaded file, from the original local directory to another local directory, so that the original directory is now empty (for saving purposes)
greets
Hermann
I've made some example for you.
HermannSwiss
thx alot, going to test it
greets
Hermann
HermannSwiss
so, after some Testing, Coffee and Cigs, I made it Very Happy
the Batch File looks like the following:
start C:\Programme\WinSCP3\WinSCP3.com /privatekey=C:\packpri2.ppk /script=C:\EDIScript\uploadbreuninger.txt
if errorlevel 1 goto error
echo Upload succeeded, moving local files
move C:\breuningertestup\*.* C:\Archivtest\
:error
echo Upload failed, keeping local files
again thx for the great help, keep on
greets
Hermann
