Topic "Where are the cache options located (per help info)?"
uploader
Hello.
Where do I find:
http://winscp.net/eng/docs/ui_login_directories
to set the 'clear cache' options? I have v.3.8.2 Build 330.
I'm still trying to find out why WinSCP is the only SFTP client out of about 4 I've tried that doesn't update the web server immediately. Not sure if it's a cache, resume, or a design issue. Totally disappointing.
Thanks.
uploader wrote:
Where do I find:
You need to tick Advanced options checkbox.
The above options will not help you Sad
chrroe
Hi!
How can I change the caching parameters for sessions wich I have already saved?
When I start WinSCP and select a session (with only one click), and then change to the Directories tab, I can disable the checkbox. But when I try to save the session again under the same name, all other settings like server-name, login, etc are lost.
With an opened session I was unable to find a possibility to change the login parameters for the opend session.
Or am I totaly blind?
Bye
Christoph
To edit existing stored session, first load it, modify your options and than save it back (under the same or different name).
a-nony-mous
That's really, really confusing. Is there a way to just CLEAR THE CACHE?
Please read documentation.
