Topic "want to use the plugin"
sarguna
hi prikryl
I want to use u r made winscp.dll in my program
As such i want to make an SCP connection and transfer a file.
I don't know where to start with it and which are the functions exported from the dll.
I gone throught the previous message which said that it can be done by
TTerminal class
but still i m facing some problem as i am not getting the function i have to call for the establishing the connection
Plz take some time and help me out.
Thank you in advance for the solution.
winscp.dll is a plugin to FAR file manager. It is not a generic purpose SFTP library.
sarguna
Thank you very much for replying
I saw some previous msg in the far plugin forum which says that we can use the source code of winscp for this purpose
http://winscp.net/forum/viewtopic.php?t=983
Can u tell which are the classes i have to use or check out from winscp so that it would be easy for me to work out.
Regards
Please read FAQ.
