Topic "password is not saved."
bossie
since i've upgraded from v2.0.0 to v2.3.0 I've noticed that although I've entered a password in the savedsession-login screen, I have to enter the password every time I start a new session. Sad
Is there a methode to save the password permanently?
regards
Piet.
askocc
At opening screen select (don't doubleclick) the connection you want to use and load it.
Change your password.
Go to stored session and save.
Decription above is correct. But it have not changed since 2.0 beta, so I wonder what is bossie's problem. Does it work now?
For bossie: Your email p.bos@klm.com is invalid, please correct it. Otherwise I would have to cancel your account.
bossie
Hello prikryl and Askocc,
Martin I've changed my profile.
The e-mailadress was changed lately, and I mistakenly submitted my old adress.
No it doesn't work, Ive used the procedure Askocc advised and tried it at 2 separate systems.
Both the same result, I have to give the password in a separate password box.
Bye Piet.
bossie
Bye Piet.
Additional Info:
Both mentioned servers use ssh2 and I've found a server using ssh1 ahd then the methode works fine!
So it seems to be a problem concentrating to ssh2? I guess.
Bye Piet.
bossie
Are you out of suggestions?
Hey, give me some time, I cannot be on-line 24-hours a day, 7-days in week Smile
What does password input box ask you for? (label of password field). It's possible that your SSH2 servers do not ask you for a password, but for other mean of authentication (so called keyboard-interactive authentication, see 'authentication' tab of login dialog).
Please post a log file, it should be clear from it.
bossie
Hi Martin,
don't mean to rush you!
The question is "Enter password"
I've tried both with and without the keyboard-interactive authentication.
you've asked for a logfile, well here it is. Laughing
. Closing connection.
. WinSCP Version 2.3.0 (Build 146)
. Login time: Thursday, June 12, 2003 8:30:57 AM
. Session name: vaartips
. Host name: www.vaartips.nl (Port: 22)
. User name: kees (Password: No, Key file: No)
. SSH Bugs: A,A,A,A,A,A,A,
. Proxy: none
. Shell: default, EOL: 0
. Clear aliases: Yes, Unset nat.vars: Yes
. Looking up host "www.vaartips.nl"
. Connecting to 62.177.200.212 port 22
. Server version: SSH-2.0-OpenSSH_3.6.1p2
. We claim version: SSH-2.0-PuTTY-Local: Apr 23 2003 11:38:40
. Host key fingerprint is:
. ssh-rsa 1024 c6:8e:ce:75:8f:25:f5:c8:e1:71:a5:67:53:5b:64:e8
! Using username "kees".
. Access granted
. Opened channel for session
. Started a shell/command
> echo "WinSCP: this is end-of-file:0"
< WinSCP: this is end-of-file:0
. Detecting variable containing return code of last command.
. Trying "$status".
> echo "$status" ; echo "WinSCP: this is end-of-file:0"
. Trying "$?".
> echo "$?" ; echo "WinSCP: this is end-of-file:0"
< 0
. Return code variable "$?" selected.
. Clearing all aliases.
> unalias "echo" ; echo "WinSCP: this is end-of-file:$?"
! -bash: line 4: unalias: echo: not found
< WinSCP: this is end-of-file:1
> unalias "pwd" ; echo "WinSCP: this is end-of-file:$?"
! -bash: line 5: unalias: pwd: not found
> unalias "cd" ; echo "WinSCP: this is end-of-file:$?"
! -bash: line 6: unalias: cd: not found
> unalias "ls" ; echo "WinSCP: this is end-of-file:$?"
! -bash: line 7: unalias: ls: not found
> unalias "groups" ; echo "WinSCP: this is end-of-file:$?"
! -bash: line 8: unalias: groups: not found
> unalias "scp" ; echo "WinSCP: this is end-of-file:$?"
! -bash: line 9: unalias: scp: not found
> unalias "rm" ; echo "WinSCP: this is end-of-file:$?"
! -bash: line 10: unalias: rm: not found
> unalias "mv" ; echo "WinSCP: this is end-of-file:$?"
! -bash: line 11: unalias: mv: not found
> unalias "mkdir" ; echo "WinSCP: this is end-of-file:$?"
! -bash: line 12: unalias: mkdir: not found
> unalias "chmod" ; echo "WinSCP: this is end-of-file:$?"
! -bash: line 13: unalias: chmod: not found
> unalias "chgrp" ; echo "WinSCP: this is end-of-file:$?"
! -bash: line 14: unalias: chgrp: not found
> unalias "chown" ; echo "WinSCP: this is end-of-file:$?"
! -bash: line 15: unalias: chown: not found
> unalias "unset" ; echo "WinSCP: this is end-of-file:$?"
! -bash: line 16: unalias: unset: not found
> unalias "unalias" ; echo "WinSCP: this is end-of-file:$?"
! -bash: line 17: unalias: unalias: not found
> unalias "alias" ; echo "WinSCP: this is end-of-file:$?"
! -bash: line 18: unalias: alias: not found
> unalias "%s" ; echo "WinSCP: this is end-of-file:$?"
! -bash: line 19: unalias: %s: not found
. Clearing national user variables.
> unset "LANG" ; echo "WinSCP: this is end-of-file:$?"
> unset "LANGUAGE" ; echo "WinSCP: this is end-of-file:$?"
> unset "LC_CTYPE" ; echo "WinSCP: this is end-of-file:$?"
> unset "LC_COLLATE" ; echo "WinSCP: this is end-of-file:$?"
> unset "LC_MONETARY" ; echo "WinSCP: this is end-of-file:$?"
> unset "LC_NUMERIC" ; echo "WinSCP: this is end-of-file:$?"
> unset "LC_TIME" ; echo "WinSCP: this is end-of-file:$?"
> unset "LC_MESSAGES" ; echo "WinSCP: this is end-of-file:$?"
> unset "LC_ALL" ; echo "WinSCP: this is end-of-file:$?"
> unset "HUMAN_BLOCKS" ; echo "WinSCP: this is end-of-file:$?"
. Looking up current user groups.
> groups ; echo "WinSCP: this is end-of-file:$?"
< kees
. Following groups found:
. kees
> pwd ; echo "WinSCP: this is end-of-file:$?"
< /usr/home/kees
. Listing current directory.
> ls -la ; echo "WinSCP: this is end-of-file:$?"
< total 32
< drwxr-xr-x 5 kees kees 512 Apr 5 11:44 .
< drwxr-xr-x 24 root wheel 512 May 26 09:06 ..
< -rw------- 1 kees kees 3251 Jun 9 20:55 .bash_history
< -rw------- 1 kees kees 111 Nov 14 2002 .bash_profile
< drwx------ 2 kees kees 512 Apr 5 11:44 .cedit
< -rw-r--r-- 1 kees kees 771 Nov 14 2002 .cshrc
< -rw-r--r-- 1 kees kees 255 Nov 14 2002 .login
< -rw-r--r-- 1 kees kees 165 Nov 14 2002 .login_conf
< -rw------- 1 kees kees 371 Nov 14 2002 .mail_aliases
< -rw-r--r-- 1 kees kees 331 Nov 14 2002 .mailrc
< drwxr-xr-x 2 kees kees 512 May 2 13:46 .mc
< -rw-r--r-- 1 kees kees 801 Nov 14 2002 .profile
< -rw------- 1 kees kees 276 Nov 14 2002 .rhosts
< -rw-r--r-- 1 kees kees 852 Nov 14 2002 .shrc
< drwxr-xr-x 4 kees kees 512 Dec 6 2002 vaartips.nl
. Startup conversation with host finished.
Bye Piet.
From the log file I can see that you have NOT stored your password! Please make sure that you follow suggestion of 'askocc' correctly.
bossie
I did, but no result.
See the log from the latest attempt.
. Login time: Monday, June 16, 2003 9:02:16 AM
. Session name: kees@www.vaartips.nl
. User name: kees (Password: Yes, Key file: No)
. Proxy: none
. Unable to authenticate
. Attempt to close connection due to fatal exception:
* Unable to authenticate
* (ESshFatal) Authentication failed.
This is starting to be mysterious Smile
  • First, make sure that you've spelled your pasword correctly (I believe you did).
  • Are there any special characters in your password (aparts from characters a-z and numbers)? Only thing I can imagine now, is that WinSCP spoils such characters when saving to registry. But nobody ever reported this before.
  • No other idea yet Sad
