Topic "Request Error code after runnning script"
steppi
Try to run bat-file : winscp3.com / script=test.txt
Is it possible to request a error-code after performing the script ?
Transfer ok or not ok ?
example script:
option batch on
option confirm on
open **********************
put c:\data\
close
Ben
I'm also interested by the response.
More generally, how is it possible to manage error codes generated by WinScp???
Is there any error message table in the Documentation?
Thank you for your response.
Ben
steppi
sorry currently find nothing
Please read FAQ.
steppi
prikryl wrote:
Please read FAQ.
What is the exact name of the reurn code ?
Can you plesae provide any example ?
steppi
What is the exact name of the return code variable ? Example ?
I have extended the mentioned FAQ. Please reload Smile
steppi
Sorry but the request for the erroelevel not working ... Example:
bat-file:
set errorlevel=0
C:\programm\WinSCP3\WinSCP3.exe /console /script=testscript.txt/log=testscript.log
if errorlevel 0 goto ok
:error
echo error
goto end
Surprisedk
echo ok
goto end
:end
script:
option batch abort
open sftp://******************************
cd /home/
put D:\test*.txt
close
Which return code I get for example not connection or wrong command ?
Always getting status ok ....
How ca I us a windows command in the script ? e.g del ?
"if errorlevel 0" is matched always as "if errorlevel x" means "if errorlevel is 0 or greater". Check documentation for "if". Please follow the example in FAQ.
