Topic "Smart Card Authentication"
alexander
Thanks Martin for the great WinSCP. I have been using WinSCP & Putty now for years.
Under http://www.joebar.ch/puttysc/ I found a project that added Smart Card authentication to Putty according the OpenSC project (http://www.opensc-project.org/scb/).
Will there ever be a WinSCP that also supports smart card authentication? I would really appreciate.
Best Regards
Alexander
I'll consider that Smile
Best Regards
Alexander
pageant (PuTTY SC) allows you to use your smartcard with WinSCP - available at http://www.joebar.ch/puttysc/pageantsc.exe
dbabault
Best Regards
Alexander
Just done ...
https://code.google.com/p/puttywincrypt/wiki/README
