Topic "folders invisible in local directory"
don
I don't see my folders in my local window using the Norton Commander view for any folder on drive c. If I view browse with explorer they are visible.
I'm sorry, but I have no idea what can be your problem. Have you any similar problems with other applications?
Alex Han Phong
I also have the same problem ..
After I log in I can see the host's files but the files in my local directory cannot be viewed.
When I tried to change directory , I got a message error 019 or something like that..I don't remember the exact number ..
What am I doing wrong ?
Thanks for your assistance..
I am really new to all this and have not a clue as to what to do..
What Windows version are you using?
Jerry
Hi.
Had invisible folders as well, although in the panel of the remote folder at the right.
Steps to follow:
1. Create a directory in the local folder (menu Commands, option Create Directory)
2. Same for the remote folder.
Hopes this helps for you, as it did for me.
Jerry.
= Ignorance is no excuse.=
