Topic "Unknown option error in script"
mikeyww
When I use console+scripting with echo or synchdelete, I get the following errors.
Unknown option 'echo'
Unknown option 'synchdelete'
Any ideas?
Mike
Can you post the script?
mikeyww
SCRIPT:
option batch on
option echo
synchdelete off
open PCIWG
synchronize local E:\mwbackups\PCIWGwiki\wiki.d /home/pciwwei3/pciwgwiki/wiki.d
close
COMMAND LINE:
"C:\Program Files\WinSCP3\WinSCP3.exe" /ini=K:\WinSCP3.ini /console /script=E:\mwconfigs\WinSCP\PCIWGwiki.txt /log=E:\mwlogs\PCIWGwiki.log
mikeyww
I realized I needed "option" before "synchdelete", but the echo is still not being accepted as an option. Would it have an effect if I am using the console?
There's no echo option. Why do you think so?
mikeyww
I see that I can see the commands as they are being executed, but then is there a difference between echo and console?
Sorry, I do not understand. The option "echo" is already implemented, but not part of any release yet.
mikeyww
OK, thank you. Sorry, I misunderstood. Great work with this program!
