Topic "Scripting synchronize with filesize criteria"
gina
Hi Martin:
How are you?
Here is my question:
When scripting /synchronize, does it check the filesize criteria (as in de GUI)?
I have a problem where a sync to remote from a Win XP to a Redhat Fedora 5 is not synchronizing, alltough even filesizes differ.
Thanks for your support.
Do you actually mean scripting or /synchronize command-line option?
gina
Yes, sorry, I mean scripting:
winscp3.com /command "synchronize remote ..."
I'm using a ini file with /ini=<file>. In the ini file I defined CompareByTime=1, but it seems not to work.
Any advice?
In scripting you cannot synchronize by time. Moreover CompareByTime option is for "compare directories" function.
gina
Oops...And can I use "CompareBySize=1" when scripting?
Does it have any effect?
IMO, it is very usefull to force a sync when file size differs.
At least, when synchronizing in one way.
Could you add this feature in a next release?
As said before, I have two machines. When I edit a file in the machine 1 and do a sync from machine 1 to 2, the file is not uplodad, so I have to connect via SSH and remove the file first in order to get it uploaded. This is very annoying.
Thanks.
I can add this in the next release.
Great. I hope it will not be difficult.
Thank you very much.
Is this working now?
Yes. Please read documentation. If that does not help, come back.
