Topic "activate an exe file using winscp3 on another server?"
pelegk2
can i using the winscp connect to another server of mine and activate an exe file or maybe a bacth files?
hnaks in advane
peleg
Manually (from GUI) or automatically (e.g. from script)?
pelegk2
which means you run command from a command line (dos)
how can i do it ibnn tis way?
thanks i nadvance
peleg
I do not understand.
But this documentation chapter may help you.
pelegk2
i need to check if it workd on win2003 server
