Topic "Group Policy & UNC paths are not supported"
doublem
i am searching now for hours and found nothing. I installed winscp 3.8.2 on a citrix PS4 with R02 with a group policy. Without group policy the connection is o.k. When i rebrowse the private key-file (ssh1 or ssh2) and save the connection - the first connection is also o.k., but the second failed with "UNC paths are not supported". On a second Server the connection with the same software/policy is o.k. Question
Any ideas before i start a new installation ? Crying or Very sad
Regards,
doublem
At what point do you get the error?
After the logline: 2006-12-08 10:50:10.663 Startup conversation with host finished.2006-12-08 10:50:12.600 Closing connection. The Connection finished unexpect with the Error message. I write the password and klick o.k. That is directly after the login process. The winscp-Gui is not come up.
Maybe a right problem ?
Regards,
doublem
I'll contact you soon.
thank you for your support. I solved the problem now with new Installation. Why this error occurs is strangely.
Regards,
Michael.
