Topic "how to get /Command put work with Filenames having spaces"
CCR
hello,
i hope someone had that problem before or i am just to stupid.
i did escape everything i could, but i could't get this statement work properly. i must have it scripted since it is for automation
WinScp3.com /command "open me@myserver" "put "C:\Documents and Settings\SomePath\SomeFile.txt" "Projekte"" close exit
i though double escaping is necessary (i can't get it work without anyway).
help is highly appreciated
thanks in advance
I do not think it is possible due to limitations of Windows shell.
ccr
thanks martin,
i already gave up on this - an turned in to /script - now it works
RickB
CCR wrote:
hello,
thanks in advance
I know you have found a workaround but for the record here is a possible solution.
I had this problem and solved it by using the short (8dot3) version of the path. For example, you could do this instead:
WinScp3.com /command "open me@myserver" "put C:\DOCUME~1\SOMEPA~1\SOMEFI~1.txt Projekte"
The exact 8dot3 names of your directories and files may no be what I have typed above, but probably is. you can open a command prompt and type DIR /X and you will see the short 8dot3 names in the DIR listing.
