Topic "Files selection"
clientvoip
I want download the files from remote directory.
But I want download only the files with data previous the current data.
I explain, for example now is 12 Dec. The remote directory contains a lots of files/directories but I want download only the files with data previous the 12 Dec.
Can I obtain the system data (yymmdd and hhmmss)?
Can I compare the system data with the directory/file data?
I want write a file .scp for the download, but I don't know how
Do you want to do that with scripting or from GUI?
clientvoip
I want to write a file scp that:
1) open a connection to remote machine
2) create a remote directory (system current data_backup)
3) launch a specific remote command (I know the specific command)
The point 1 and 3 aren't problems, but the point 2 yes.
I don't know how obtain the system current data (yymmdd and hhmmss).
The commands time or data don't work correctly.
Could you help me?
You can try something like:
call mkdir `date +%Y%m%d%H%M%S`
clientvoip
thanks for your answer.
Sorry, but now I have other questions:
1) I want assign a value to a variable (for example BCK = backup)because I want create a variable directory (BCK_system time). The system time isn't the problem because I use "call date" command but I don't know how append the BCK value with the output of the command date.
2) I want send a specific remote command (./specific command) from the scp file, but I don't know how.
Could you help me, please?
Do you mean something like:
call mkdir `date +%Y%m%d%H%M%S"backup"`
[/quote]
or
call mkdir `date +%Y%m%d%H%M%S"$BCK"`
[/quote]
Thanks what "call" does: "call specific_command".
