Topic "Schedule a session as a task"
natzol
Hello
I am trying to create a script to be executable via batch file on NT schedule. Found following samples for a command line:
:: winscp3.exe stored_session
:: winscp3.exe [(scp|sftp)://][user[:password]@]host[:port][/path/[file]] [/privatekey=key_file] [/script=script_file]
Is there a way to create a session with all of those parameters so Task will only execute the line like:
winscp3.com SessionName1
You can preconfigure the session from GUI. Please read this FAQ to avoid common mistakes.
natzol
Great! Thank you for pointing in the right direction.
I exported settings from registry and found session record:
[HKEY_CURRENT_USER\Software\Martin Prikryl\WinSCP 2\Sessions\MySite]
"HostName"="www.mySite.com"
"PingType"=dword:00000000
"LocalDirectory"="C:%5CBatch"
"UpdateDirectories"=dword:00000001
"Password"="A35C....21"
"UserName"="username"
"PublicKeyFile"="C:%5CBatch%5CprivateKey.ppk"
It also took a while to find how to switch from Registry settings to INI settings (Panel\Preferences\Other General Options\Storage\Configuration Storage..) Once I changed it - I also found INI file and my session settings in it:
[Sessions\MySite]
PingType=0
HostName=www.mySite.com
Password=A35C....21
UserName=username
PublicKeyFile=C:%5CBatch%5CprivateKey.ppk
Plus I changed
[Configuration\Interface]
RandomSeedFile=.\winscp.rnd
DDTemporaryDirectory=.\
So do you recommend use INI file over Registry? Or overwise export/import registry file each time I need to switch the session so program wont get tied to a current user settings?
INI file is probably easier to use for your task.
