Topic "drag and drop fails"
I have succesfully installed winscp on many computer with success.
today i tried on a dell with win XP home edition, usinf McAffee security center.
It is just impossible using drag and drop on the desktop or on a window of the explorer using the usual configuration.
It only create a scp**** (* are numbers) folder on the destination and say drag and drop plugin is not enabled but it is....
it on ly works with option to write in a temp dir. (But where is this temp dir is this temp dir erased after transfer?) .
What may cause that?
Have you restarted your computer after installation?
NO i have not Smile
after the reboot...
it works thanks
