Topic "integration with putty - default settings"
raldred
Hey, I use the icon in winscp to open putty and automatically log me into the shell.
but I cant find where the session settings are stored for the instance of putty that winscp opens.
Basically I would like to increase the default line scrollback... I have changed the default settings in putty, but this doesn't effect the instances opened by winscp.
Any ideas?
Rob
WinSCP stores the settings into "WinSCP temporary session" session in Putty session list. You may try to alter that. In the next version, I may improve that to load the defaults from default putty session.
raldred
Ok, that would be great because i guess there is no way to edit the temporary settings that are created?
Cheers
You can alter the settings from PuTTY. But only those that WinSCP does not create (most terminal/appearance settings).
driftingprogrammer
I am able to change the WinSCP created settings by starting putty, so i am able to get custom colors on my putty session started by winscp. And these stay as defaults Very Happy
