Topic "Directory Listing Timing Out on a Specific Directory"
eques
Greetings:
I've got a directory on my linuxbox that consistently times out when the directory listing is requested. I can access the directory fine on the shell, via samba, and via sftp on the linux command line, but psftp exhibits the same behavior.
I attempted to increase the timeout from 15 to 60 seconds, but as psftp shows, no duration is sufficient.
It appears that the client receives SSH_FXP_HANDLE and never receives a response after sending SSH_FXP_READDIR.
I've downloaded the latest version of PuTTY (0.59 at the time of this writing) and it exhibits the same behavior, so this may well be a PuTTY problem, but, truth be told, I'm not sure how to report it.
Following is the relevant log excerpt. The directory that doesn't seem to work is /site/web/hopfrog.pyrich.com/htdocs/Lilly. There's nothing abnormal about the directory that I can see.
Quote:
. 2007-02-14 10:34:05.988 Cached directory change via "drawings" to "/site/web/hopfrog.pyrich.com/htdocs/drawings".
. 2007-02-14 10:34:05.988 Getting current directory name.
. 2007-02-14 10:34:05.988 Listing directory "/site/web/hopfrog.pyrich.com/htdocs/drawings".
> 2007-02-14 10:34:05.988 Type: SSH_FXP_OPENDIR, Size: 53, Number: 5643
. 2007-02-14 10:34:05.998 Sent 57 bytes
. 2007-02-14 10:34:05.998 There are 0 bytes remaining in the send buffer
. 2007-02-14 10:34:05.998 Received 4 bytes
. 2007-02-14 10:34:05.998 Received 24 bytes
< 2007-02-14 10:34:05.998 Type: SSH_FXP_STATUS, Size: 24, Number: 5380
. 2007-02-14 10:34:05.998 Discarding reserved response
. 2007-02-14 10:34:05.998 Waiting for another 4 bytes
. 2007-02-14 10:34:05.998 Received 13 bytes
< 2007-02-14 10:34:05.998 Type: SSH_FXP_HANDLE, Size: 13, Number: 5643
> 2007-02-14 10:34:05.998 Type: SSH_FXP_READDIR, Size: 13, Number: 5900
. 2007-02-14 10:34:05.998 Sent 17 bytes
. 2007-02-14 10:34:06.008 Received 4 bytes
. 2007-02-14 10:34:06.008 Received 4471 bytes
< 2007-02-14 10:34:06.008 Type: SSH_FXP_NAME, Size: 4471, Number: 5900
> 2007-02-14 10:34:06.008 Type: SSH_FXP_READDIR, Size: 13, Number: 6156
. 2007-02-14 10:34:06.008 Sent 17 bytes
. 2007-02-14 10:34:06.008 There are 0 bytes remaining in the send buffer
. 2007-02-14 10:34:06.008 Waiting for another 4 bytes
. 2007-02-14 10:34:06.008 Received 28 bytes
< 2007-02-14 10:34:06.008 Type: SSH_FXP_STATUS, Size: 28, Number: 6156
< 2007-02-14 10:34:06.008 Status/error code: 1
> 2007-02-14 10:34:06.008 Type: SSH_FXP_CLOSE, Size: 13, Number: 6404
. 2007-02-14 10:34:06.388 Session upkeep
. 2007-02-14 10:34:06.388 Detected incoming data while idle
. 2007-02-14 10:34:06.889 Session upkeep
. 2007-02-14 10:34:07.390 Session upkeep
. 2007-02-14 10:34:07.740 Cached directory change via "/site/web/hopfrog.pyrich.com/htdocs/Lilly" to "/site/web/hopfrog.pyrich.com/htdocs/Lilly".
. 2007-02-14 10:34:07.740 Getting current directory name.
. 2007-02-14 10:34:07.740 Listing directory "/site/web/hopfrog.pyrich.com/htdocs/Lilly".
> 2007-02-14 10:34:07.740 Type: SSH_FXP_OPENDIR, Size: 50, Number: 6667
. 2007-02-14 10:34:07.740 Sent 54 bytes
. 2007-02-14 10:34:07.740 There are 0 bytes remaining in the send buffer
. 2007-02-14 10:34:07.740 Received 4 bytes
. 2007-02-14 10:34:07.740 Received 24 bytes
< 2007-02-14 10:34:07.740 Type: SSH_FXP_STATUS, Size: 24, Number: 6404
. 2007-02-14 10:34:07.740 Discarding reserved response
. 2007-02-14 10:34:07.740 Waiting for another 4 bytes
. 2007-02-14 10:34:07.740 Received 13 bytes
< 2007-02-14 10:34:07.740 Type: SSH_FXP_HANDLE, Size: 13, Number: 6667
> 2007-02-14 10:34:07.740 Type: SSH_FXP_READDIR, Size: 13, Number: 6924
. 2007-02-14 10:34:07.740 Sent 17 bytes
. 2007-02-14 10:34:07.750 Waiting for another 4 bytes
. 2007-02-14 10:35:07.757 Waiting for data timed out, asking user what to do.
. 2007-02-14 10:35:07.757 Asking user:
. 2007-02-14 10:35:07.757 Host has not answered for 60 seconds.
. 2007-02-14 10:35:07.757 Wait for another 60 seconds? Pressing 'Abort' button will close session. ()
. 2007-02-14 10:35:07.837 Session upkeep
. 2007-02-14 10:35:07.977 Session upkeep
. 2007-02-14 10:35:08.478 Session upkeep
. 2007-02-14 10:35:08.978 Session upkeep
. 2007-02-14 10:35:09.479 Session upkeep
. 2007-02-14 10:35:09.980 Session upkeep
. 2007-02-14 10:35:10.050 Attempt to close connection due to fatal exception:
* 2007-02-14 10:35:10.050 Terminated by user.
. 2007-02-14 10:35:10.050 Closing connection.
Can you list the directory with sftp on linux command line?
eques
Yes, I can.
Sorry. I have not idea what may go wrong. Have you tried to use SCP instead of SFTP?
eques
Yes, SCP allows me to list the directory.
Should I report this behavior to Simon since it occurs in PSFTP as well?
I'm not sure if it is worth it. I doubt it is PSFTP related. But you can try it.
