Topic "Folder name problem"
thecavetroll
This problem has just started and we are baffled why.
We use the GUI side of WINSCP. When we try to create a folder, nothing happens, the folder is not created. When we then come out of WINSCP and go back in, there is a new folder in the level above, which is named after the parent folder + the new folder e.g.
we go into \code\temp and try to create a new folder called dave. We should then have a structure \code\temp\dave. However, the dave folder is not created, but when we go back into WINSCP there is a new folder called \code\tempdave
Does anyone know why this is happening??
TIA
Can you post a log file?
ahgood
[quote="prikryl"]Can you post a log file?[/quote]
. 2007-05-01 20:30:27.017 Creating directory "test".
. 2007-05-01 20:30:27.017 Canonifying: "test"
. 2007-05-01 20:30:27.017 Getting real path for '/www/tw/test'
> 2007-05-01 20:30:27.017 Type: SSH_FXP_REALPATH, Size: 87, Number: 284688
< 2007-05-01 20:30:27.027 Type: SSH_FXP_STATUS, Size: 24, Number: 284164
. 2007-05-01 20:30:27.027 Discarding reserved response
< 2007-05-01 20:30:27.488 Type: SSH_FXP_NAME, Size: 175, Number: 284688
. 2007-05-01 20:30:27.488 Real path is '/www/twtest'
. 2007-05-01 20:30:27.488 Canonified: "/www/twtest"
> 2007-05-01 20:30:27.488 Type: SSH_FXP_MKDIR, Size: 90, Number: 284430
< 2007-05-01 20:30:27.948 Type: SSH_FXP_STATUS, Size: 24, Number: 284430
< 2007-05-01 20:30:27.948 Status/error code: 0
> 2007-05-01 20:30:27.948 Type: SSH_FXP_SETSTAT, Size: 90, Number: 284937
< 2007-05-01 20:30:28.409 Type: SSH_FXP_STATUS, Size: 24, Number: 284937
< 2007-05-01 20:30:28.409 Status/error code: 0
. 2007-05-01 20:30:28.409 Listing directory "/www/tw".
> 2007-05-01 20:30:28.409 Type: SSH_FXP_OPENDIR, Size: 82, Number: 285195
< 2007-05-01 20:30:28.860 Type: SSH_FXP_HANDLE, Size: 13, Number: 285195
> 2007-05-01 20:30:28.860 Type: SSH_FXP_READDIR, Size: 13, Number: 285452
< 2007-05-01 20:30:29.370 Type: SSH_FXP_NAME, Size: 2527, Number: 285452
> 2007-05-01 20:30:29.370 Type: SSH_FXP_READDIR, Size: 13, Number: 285708
< 2007-05-01 20:30:29.831 Type: SSH_FXP_STATUS, Size: 28, Number: 285708
< 2007-05-01 20:30:29.831 Status/error code: 1
> 2007-05-01 20:30:29.831 Type: SSH_FXP_CLOSE, Size: 13, Number: 285956
. 2007-05-01 20:30:33.346 Getting current directory name.
. 2007-05-01 20:30:33.346 Listing directory "/www/tw".
> 2007-05-01 20:30:33.346 Type: SSH_FXP_OPENDIR, Size: 82, Number: 286219
< 2007-05-01 20:30:33.346 Type: SSH_FXP_STATUS, Size: 24, Number: 285956
. 2007-05-01 20:30:33.346 Discarding reserved response
< 2007-05-01 20:30:33.807 Type: SSH_FXP_HANDLE, Size: 13, Number: 286219
> 2007-05-01 20:30:33.807 Type: SSH_FXP_READDIR, Size: 13, Number: 286476
< 2007-05-01 20:30:34.317 Type: SSH_FXP_NAME, Size: 2527, Number: 286476
> 2007-05-01 20:30:34.317 Type: SSH_FXP_READDIR, Size: 13, Number: 286732
< 2007-05-01 20:30:34.768 Type: SSH_FXP_STATUS, Size: 28, Number: 286732
< 2007-05-01 20:30:34.768 Status/error code: 1
> 2007-05-01 20:30:34.778 Type: SSH_FXP_CLOSE, Size: 13, Number: 286980
. 2007-05-01 20:30:37.823 Cached directory change via ".." to "/www".
. 2007-05-01 20:30:37.823 Getting current directory name.
. 2007-05-01 20:30:37.863 Directory content loaded from cache.
. 2007-05-01 20:30:40.206 Getting current directory name.
. 2007-05-01 20:30:40.206 Listing directory "/www".
> 2007-05-01 20:30:40.206 Type: SSH_FXP_OPENDIR, Size: 79, Number: 287243
< 2007-05-01 20:30:40.206 Type: SSH_FXP_STATUS, Size: 24, Number: 286980
. 2007-05-01 20:30:40.206 Discarding reserved response
< 2007-05-01 20:30:40.667 Type: SSH_FXP_HANDLE, Size: 13, Number: 287243
> 2007-05-01 20:30:40.667 Type: SSH_FXP_READDIR, Size: 13, Number: 287500
< 2007-05-01 20:30:41.167 Type: SSH_FXP_NAME, Size: 2383, Number: 287500
> 2007-05-01 20:30:41.167 Type: SSH_FXP_READDIR, Size: 13, Number: 287756
< 2007-05-01 20:30:42.139 Type: SSH_FXP_STATUS, Size: 28, Number: 287756
< 2007-05-01 20:30:42.139 Status/error code: 1
> 2007-05-01 20:30:42.139 Type: SSH_FXP_CLOSE, Size: 13, Number: 288004
ahgood
This problem exist on 3.8.2, 4.0 beta/Windows XP. I've also tried several computer, the same problem.
Thanks!
This definitely looks like a server-side bug. What's your SSH/SFTP server?
ahgood
Can you find answer from log? I just know server platform is AIX.
. 2007-05-02 17:05:33.779 Looking up host "stage.xxx.com"
. 2007-05-02 17:05:34.129 Connecting to 9.185.69.131 port 22
. 2007-05-02 17:05:34.780 Server version: SSH-1.99-OpenSSH_3.7.1p2
. 2007-05-02 17:05:34.780 We claim version: SSH-2.0-WinSCP_release_4.0
. 2007-05-02 17:05:34.780 Using SSH protocol version 2
. 2007-05-02 17:05:35.101 Doing Diffie-Hellman group exchange
. 2007-05-02 17:05:35.762 Doing Diffie-Hellman key exchange
. 2007-05-02 17:05:37.174 Host key fingerprint is:
. 2007-05-02 17:05:37.174 ssh-rsa 1024 3f:d1:5f:05:f8:2f:f3:f1:72:a1:d9:33:c7:9c:8e:a2
. 2007-05-02 17:05:37.174 Initialised AES-256 client->server encryption
. 2007-05-02 17:05:37.174 Initialised HMAC-SHA1 client->server MAC algorithm
. 2007-05-02 17:05:37.174 Initialised AES-256 server->client encryption
. 2007-05-02 17:05:37.174 Initialised HMAC-SHA1 server->client MAC algorithm
Thanks!!
It looks like it's OpenSSH. Try to file a bug report on their site.
ahgood
Problem solved by changing host name, the previous host name should be a virtual host name.
FYI.
