Topic "No root login"
shahidr100
Hi
I frequently need to download and upload files to and from a Linux Server.
Root login is disabled at Linux server so I have to login as a normal user and then go to super user to come to root. After that I do a WinSCP session and transfer files. This whole process is bit cumbersome.
Isnt there any method in WinSCP through which I can do it at one go and I do not have to log in to linux server first to allow root login and then login thru winscp.
Thank you
How do you allow WinSCP to login as root?
shahidr100
To allow root login to WinSCP, first i login to the linux server as a normal user using putty. Then I do a super user. Edit the sshd_config file to allow root login. Then I restart the sshd daemon. Then i log off from Putty. Now I log in as root using Winscp.
Shahid
Please read FAQ.
shahidr100
prikryl wrote:
Please read FAQ.
Thanks for your reply, however, the method specified in faq is not working. I tried it couple of times. I am allowed to sudo from command line easily.
Please help.
shahidr100
shahidr100 wrote:
prikryl wrote:
Please read FAQ.
Please help.
Its working now. Actually I didnt select "SCP" as a protocol that is why it was not working.
Thank you so much.
I logged in to my internet server with putty and did the super user thing, but when I start WinSPC on my client I still have no permissions. How did you manage to get the permissions ?
Regards,
Frank
shahidr100 wrote:
Hi
Thank you
Have you read the mentioned FAQ?
I configured my system exactly according to your suggestions prikryl, spent hours, but my connection still times out when I get to 'sudo su'. I am a programmer/developer and admin on several servers, but could not figure this out. Would you mind, just for us lowly mortals, kindly put together a DETAILED step-by-step instruction that is more specific than the very vague FAQ you always refer to?
THANKS!!!
Zsolt
Sorry, I'm not an unix expert. I do not know how to help you further. Maybe someone else...
Ok, so you enter the shell command in WinSCP, make sure that you can 'sudo su' without being prompted for a root password, you start a WinSCP session by logging in through a non-priviliged account... and then what?
Thanks.
Zsolt
Nothing. That's it. You should be logged in as a root.
