Topic "Buttons in the login dialog"
Oliver
you should rearrage the buttons in your login dialog.
The "Login" button should be more left, becuase it's the most positive function.
And the buttons "Save", "Help", "About", "Languages" should be in the right, under "Load", "Delete" etc, because they're only helpers and "more negative".
Best regards,
Oliver
I think that it is good idea to swap Save and Login, otherwise I would keep it as it is.
