Topic "keepuptodate"
I see that keepuptodate works for many users so I have hope. I can successfully use scripts to syncronize, get files, put files, but keepuptodate does not. When it is running, it notes that it has detected a change but that change is not reflected in the remote server.
So if I create a script to synchronize followed by keepuptodate; then I copy files to the local Server. Keepuptodate tells me that it detected a change. but if I stop the script and restart it .... that is when the file gets copied. I am rather confused. I assume that I am missing something special. Hopefully somebody has heard this before. Thanks for your help
It looks like I can get keepuptodate to work as long as I am not trying to include or exclude directorys or via a filemask but synchronize seems to work either way.
What file mask are you using?
