Topic "Timed out or Unable to Connect"
Altari
I've been running FileZilla for a while, and the FireFox FTP plugin for a short bit. Both of them will connect, but won't hold a connection.
I installed winscp, and now, on all my domains, it either says it timed out, or it was unable to connect to the host, or that the server unexpectedly closed the connection. All my settings are correct, I assume, since they work on other FTP clients. My firewalls are shut off, as well.
How can I fix this?
What protocol do you use? Note that WinSCP is not a FTP client. Yet... Smile
