Topic "No answer from the remote host"
I think I've read al posts but I have not found a solution. I'm a "really end-user" so excuse me.
I'm tryng to connect to a ReadHat 9 server (positioned on the DMZ port of a firewall), from a Windows network (by our internal proxy).
I get a "time out" message: non response from the remote host after 15 seconds.
I'have verified on the server and it seems all is working fine.
It's possibile that I forget something in the server configuration ? (iptables, configuration files, user privileges) or there is a problem in the connection ?
Thanks for your help !!!!
Here is the log file:
. WinSCP Version 2.3.0 (Build 146)
. Login time: martede 24 giugno 2003 14.47.08
. Session name: myusername@212.***.**.**
. Host name: 212.**.**.** (Port: 22)
. User name: myusername (Password: Yes, Key file: No)
. SSH Bugs: A,A,A,A,A,A,A,
. Proxy: SOCKS
. HostName: (Port: 80); Username: myusername; Passwd: Yes
. SOCKS Version: 4
. Shell: default, EOL: 0
. Clear aliases: Yes, Unset nat.vars: Yes
The log file is not complete. Also make sure that you're using bash shell.
