Topic "Invalid Port Number"
gybrush
I have a problem wenn i klick the putty symbol in winscp.
I havent the Standard Port 22 for ssh/scp i use a xxxxx port (5 numbers)
I have only 1 login in winscp after deinstall and new install.
I have reinstall to remove this problem but it dont works
Sad
guybrush
when i connect direct with putty this works fine!
but winscp is logged in the router and havent problems, only when i will start putty with click on the putty icon in winscp.
i have select on:
Remember session password and pass it to PUTTY
When i turn this option off i came without any problems in the server. Only when winscp must remember the passwort give this problem.
What version of PuTTY are you using? Are there some special characters in your password?
miszczo
It seems to be path problem. My putty was in "C:\Program Files\putty" directory, changing location to c:\putty solved problem :/
genamo
if your putty installation is inside "Program Files" directory, you can use the environment variable
%PROGRAMFILES%\putty\putty.exe
s_speaker
I had the same problem and found the solution by upgrading Putty to version 0.60
Easy as pie.
i myself have now ran into this issue. and it don't matter if i put putty C:\Putty\putty.exe or %PROGRAMFILES%\PuTTY\putty.exe. it honestly does not matter where i put it. same stupid error over and over, and yet just this morning i was in WinSCP and Putty and killing my bopm and restarting it just fine and dandy, and now all of a sudden its "internal error invalid port number" over and over - and i have tried a lot of things i found about this issue all over the internet.
who knows maybe someone out there MIGHT have a solution to this issue.
Running Windows 7 in case anyone wonders about the OS.
Crosspost.
