Topic "Appending files using scripts"
RAH
i found in the Topic "Appending files" that it is not possible to append files,
if i am using scripts. The topic is now 2 years old, it seems that there is
still no solution.
Perhaps there is a solution, but i am not able to see it.
Thanks for help.
Kind Regards
Rah
You may try to use appropriate server-side command using "call" command.
aamalama
I am trying to SFTP a file to my server using the put command. There are instances were the file may already exist on the sever and would need to be appended to however i am unable to get past the following prompt asking.....
Remote file 'text.txt' already exists. Overwrite?
New: 12 bytes, 8/9/2007 8:45:04 AM
Existing: 44 bytes, 8/9/2007 8:45:04 AM
(Y)es, (N)o, (C)ancel, A(p)pend, New na(m)e, Ne(w)er only, N(o) to All, Yes to (
A)ll:
How do I get the script to enter a "p" at the prompt so that the file is appended to?
Automatic appending from script is not supported.
