Topic "Problem with Desktop Shortcut"
Bhola
Laughing I have strange problem. I have created desktop icons for each connection. If I double click on this shortcut it does not connect and if I click on the actual session in winscp it connects? IS there any fix for this? As you all know this is very useful feature if you have about 10-15 connection- B Rolling Eyes
What does it mean "it does not connect"? Program does not start at all? Only login screen is displayed? Some error occurs? ...
Bhola
Thanks for prompr reply.
Yes, It bring up the small window for connecting to host and no error after. If I open winscp and double click on the same connetion it connects.
I try to capture the screen but can not do that. Also I have to kill that by going in task manager as it shows not responding. I am using windows 2000 pro. I have tried this on 3 machine and same thing happen.
B
Bhola
B
One more thing, I trid from dos window. I switch to the winscp2 folder and then I issue command winscp2 "name of the connection" and same thing. For some reason it does not connect form the desktop ICON.-B
Please post a log file.
Bhola
Here is a log file. I have cleared log before so it only show the last session. And for security reason I have replace IP address by xxx...Btw, this is a log using shortcut.
Log file
. WinSCP Version 2.3.0 (Build 146)
. Login time: Monday, June 30, 2003 9:10:57 AM
. Session name: ashah@xxx.xxx.xxx.xxx
. Host name: xxx.xxx.xxx.xxx (Port: 22)
. User name: ashah (Password: Yes, Key file: No)
. SSH Bugs: A,A,A,A,A,A,A,
. Proxy: HTTP
. HostName: proxy.xx.xxx.com (Port: xxx); Username: ; Passwd: No
. Shell: default, EOL: 0
. Clear aliases: Yes, Unset nat.vars: Yes
. Looking up host "xxx.xxx.xxx.xxx"
. Connecting to xxx.xxx.xxx.xxx port 22
. Server version: SSH-1.99-OpenSSH_3.5p1
. We claim version: SSH-2.0-PuTTY-Local: Apr 23 2003 11:38:40
. Using SSH protocol version 2"
Does the settings from the log file correspond to the settings of your session? Are you sure that you have stored session with name 'ashah@xxx.xxx.xxx.xxx'? When WinSCP parameter is in format aaa@bbb and aaa@bbb is not name of any stored session, it tries to connect to host bbb with username aaa and default settings.
Bhola
Yes the name of session is ashah@xxx.xxx (host name). This means ashah will connect to the xxx.xxx (host). In winscp windows, I have created this session and then have created desktop shortcut from there.
If I click on the actual session from winscp window it connect, but not from desktop shortcut. I have this problem on almost every computer I have winscp. One thing though, I have to use proxy to go out to Internet.-B
I'm sorry, but I've run out of ideas Sad If you find anything, please let me know.
Bhola
Now interestingly enough, I tried with SSH port forwarding using desktop icon and it worked. But when I am connecting to SSH srever using winscp by desktop icon it freeze. Do you think it is because of proxy settings? As the difference between both is direct connection is to specific host in against SSH prot forwarding is localhost.
I should try using a direct connection and see what happen.-B
It may be something with proxy. If it would work for your without proxy, let me know. I do not have any proxy to try myself.
Bhola
Ok, Now it worked with proxy or SSH port forwarding from the WinSCP window. If I use desktop ICON it work with port forwarding settings but not with proxy settings. Now my proxy is fine as you can see it worked with WinSCP window open and if I select this session. If I create a desktop ICON for this session it does not work-B
Please try latest release (3.2). Let me know what were the results like.
Gladys
Is the host name my e-mail address?
No. It address or name of the computer you are trying to connect to.
