Topic "How to prevent changing of modification timestamp"
wyo
I'm using WinSCP to copy files to my webserver directories (unix server). Yet I've added a new folder and files into a folder. This containing folder changes then its modification timestamp but I though that's not the way how Unix handles timestamps on folders. Is this a problem of WinSCP?
Since Unix seems to have no fixed creation timestamp is there a workaround to keep or restore the timestamp? Somehow to achieve a fixed creation timestamp?
O. Wyss
When does the timestamp change? Do you mean creation or modification timestamp?
wyo
Modification timestamp. When I add a new folder, the containing folder gets a new modification timestamp.
O. Wyss
I did few tests and obviously at least on linux, the modification timestamp of directory behaves as you describe. When new subfolder is created, timestamp of parent directory is updated to current time.
wyo
prikryl wrote:
I did few tests ...
I can be mistaken but I think the containing folder should not change. Anyway is there a command to set the timestamp to a specified value?
O. Wyss
o_o
O. Wyss
If you want to change the timestamp on Linux, consider using the touch command. For e.g.
# touch myfile.txt
changes the timestamp of myfile.txt to the current time. For more information either do a man for touch, or look at the [url="http://en.wikipedia.org/wiki/Touch_(Unix)"]Wikipedia Article[/url] at the bottom of which some examples are given.
wyo
o_o wrote:
O. Wyss
Sorry I asked to know if WinSCP could change the timestamp anyhow. Else it might be a nice enhancement.
O. Wyss
WinSCP does not support that. Neither I consider it useful for large enough audience. Sorry Sad
