Topic "SVN Icon Highlighting"
highonsnow
Hi there..
This application is absolutely brilliant. I want to suggest that possibly allowing the system wide icon highlighting for SVN affected folders would be of huge benefit to everyone using Versioning software.
In windows explorer, the icons of folders and files change, according to changes/edit etc.. It would be great if these icons (folder and file icons) could be reflected through the local file browser in WinSCP.
Comments and suggestions please.
Keep up the great work.
Peter
Sorry, I think that this is quite complicated to implement, so it does not have a high priority for me.
highonsnow
surely it's a case of hooking the win32 icons?
That's what WinSCP does. It does not help, it is more complicated.
highonsnow
Ok no problem. Hopefully it'll appear some time in the future, it'd be a useful visual feature to have.
Thanks.
Peter
SVN user
I think that with SVN being very popular now this feature would be a great addition.
Keep up the good work!
Agent
Dear prikryl
I fully agree.
Having the Icons that are showing repository status, would be of huge benefit to everyone using Versioning software.
I personally using TortoiseSVN and Im really missing this feature very much.
Is there any estimated time for the Tracker Bug 176 to get fixed?
Apart from that I would like to say that I can not life without WinSCP anymore.
Keep up the good work.
Regards Agent
I do not plan this yet. Sorry.
