Topic "winscp beta4 scripting broke?"
I've following script, that works perfectly with winscp3, but fails with winscp4 beta. As workaround I just downgraded back to version 3.
Script (winscp.txt):
# Automatically answer all prompts negatively not to stall
# the script on errors
option batch on
open myself@foo.bar.ee
cd /var/www/aaa/bbb/ccc
option transfer binary
put ddd.exe
close
command-line:
"C:\Program Files\WinSCP3\WinSCP.com" /console /script="winscp.txt"
output:
batch on
confirm off
Searching for host...
Connecting to host...
Authenticating...
Using username "myself".
Invalid access to memory
Authentication failed.
No session.
transfer binary
No session.
No session.
Do you use private key for authentication?
