Topic "4.0 beta - "Remember session password and pass it to PuTTY""
ernolf
Settings -> Integration -> "Remember session password and pass it to PuTTY" does not work. In 3.8.2 it did.
chears,
ernolf
This is know problem. Thanks.
andrys
When will you fix this bug?
It is solved already. The fix will be part of the next release, within one or two weeks.
Michal
I had to return to old good 3.8.2. If this is already resolved, where can I download it?
One more question: Both, v4 and 3.8.2. have the same bug - there is a difference when you push Alt+F6 and when you do it via "Files > Edit link". Is this fixed as well?
Thanks.
Michal
Solved, but not released yet Smile
It was intended that it should do something bit different. But I see that it does not what was intended. Thanks Smile
