Topic "Doing differential copy of files from remote location"
heyyunus
How do i do differential copy of files from remote location to my location without the SYNCRONIZE option.??
I dont want to pull all the files from the remote location to my location everyday. I would like to have only the new and modified files get copied and others should just get skipped. But i dont want to use the Syncronize option
Please suggest.
thanks Very Happy
So what do you want to use?
kallep
I want almost the same thing. Can you use GET with any option, in order to only get it to MOVE files from the remote directory? In other words make a COPY and then DELETE.
You can delete the file explicitly after the download succeeds.
