Topic "Turning off "Copy" dialog box when uploading"
abrooke
Is there any way to turn off the 'Copy' dialog box that appears when you press F5 to upload files? I've enabled all the 'auto' features I could find, but this dialog box still appears. I would basically like to upload files using my keyboard without being prompted further - similar to CuteFTP.
Thanks!
OK, I'll add the option.
jig
I choose not to show the copy dialog when pressing F5, I want change the preference, how do I go about it please?
kevej
The copy dialog box appears perfectly when I press F5. However, when a drag and drop is performed the copy dialog box disaapears.
Dissappears or does not appear at all?
If it does not appear at all, do you have Drag & drop operations selected on http://winscp.net/eng/docs/ui_pref_environment ?
The dialog box appears for an very quick instant and then disappears.
And what happens then? Is the main window responsive? Does file transfer start?
