Topic "WinSCP version 4.00 freezes during transfer"
TS
I can't reproduce this at will, but a few times now WinSCP has been in the middle of a file transfer/synchronization and it just stops responding. It's the type of thing where the program turns all white and doesn't redraw the screen; it's typically accompanied by the winscp process eating up 100% of a CPU, and the only thing I can do is kill it. It happens when talking to a Windows ssh server running sftp-3 (which may not be significant... it's just the server I transfer to/from the most). The client has frozen like this when running on an IBM Thinkpad running XP SP2, a Dell Inspiron running Vista, and an x64 2003 Server EE SP2, so it doesn't appear to be OS-specific. I've even had it happen once when ssh-ing to localhost, so it's not a network thing. I don't know what other information to give you. Do you have any suggestions for how I could get you some more useful debugging information?
yuki
WinSCP freezed during the file transfer.
The process for reproduction.
1.Modify the file on the server side(remote computer).
2.Try to save the modification
3.For the connection you need to input password to modify the file directly (not upload the modified file), the password entry window is come up and disappear.
In this situation, what you can do is just close winscp with task manager.
I have recently fixed similar problem. Maybe it is the same. It causeed WinSCP to hang just when transfer of file finished. Is it the same? Or do you experience the hanging in the middle of file transfer (of single file)?
I believe that this is unrelated problem, which was already reported. I'm going to fix it in the next release.
TS
I'm almost always transferring an entire directory at a time, or synchronizing. So somewhere in the middle of that, WinSCP freezes. I wouldn't really know whether it was at the end of a file or in the middle. So the answer to your question is quite possibly yes.
dleeling@...
I get the same behavior, usually after using "Compare directories" to highlight unsynchronized files and then dragging and dropping the files that are changed. Only killing the process using the TaskManager ends the program, which is typically pulling over 90% of the CPU resources at that point. I then removed 4.00 and returned to 3.8.2 build 330 and have had no problems. Glad to know I am not alone with this problem! Thanks for an otherwise superb transfer tool!
On this one subdirectory on linux under a tomcat web application WinSCP 4 freezes.
How can I help you with this?
gcstang
I've registered now.
Does it work with stable 3.8.2?
gcstang
Yes.
Yes.
Please post a log file.
prikryl wrote:
Yes.
This bug is happening to me too. Not sure if this helps, but this is the last of what the log file reported before hanging. As mentioned before, this was working perfectly in the last version 3.8.2:
. 2007-05-10 08:23:51.600 Copying 9 files/directories to remote directory "/tank/docs/Basonge/Cookies/"
. 2007-05-10 08:23:51.600   PrTime: Yes; PrRO: Yes; Rght: rw-r--r--; PrR: No (Yes); FnCs: N; RIC: 01; Resume: S (102400); CalcS: No; Mask: *.*
. 2007-05-10 08:23:51.600   TM: M; ClAr: No; ExclM(No):
. 2007-05-10 08:23:51.600   AscM: *.*html; *.htm; *.txt; *.php*; *.cgi; *.c; *.cpp; *.h; *.pas; *.bas; *.tex; *.pl; .htaccess; *.xtml; *.css; *.cfg; *.ini; *.sh; *.xml
. 2007-05-10 08:23:51.600 File: "C:\Documents and Settings\Basonge\Cookies\basonge@feeds.feedburner[1].txt"
. 2007-05-10 08:23:51.600 Copying "C:\Documents and Settings\Basonge\Cookies\basonge@feeds.feedburner[1].txt" to remote directory started.
. 2007-05-10 08:23:51.600 Ascii transfer mode selected.
. 2007-05-10 08:23:51.600 Opening remote file.
> 2007-05-10 08:23:51.600 Type: SSH_FXP_OPEN, Size: 83, Number: 8674307
< 2007-05-10 08:23:51.600 Type: SSH_FXP_HANDLE, Size: 13, Number: 8674307
> 2007-05-10 08:23:51.600 Type: SSH_FXP_WRITE, Size: 131, Number: 8674822
> 2007-05-10 08:23:51.600 Type: SSH_FXP_CLOSE, Size: 13, Number: 8675076
< 2007-05-10 08:23:51.600 Type: SSH_FXP_STATUS, Size: 24, Number: 8674822
< 2007-05-10 08:23:51.600 Status/error code: 0
> 2007-05-10 08:23:51.600 Type: SSH_FXP_SETSTAT, Size: 79, Number: 8674569
This is probably known issue while uploading that has been resolved already. The fix will be included into the next release. However gcstang reported problem when entering directory, which seems to be a different issue.
Valgarv
The freeze occurs when password dialog box opens on file transfer initiation during file editing.
After the last directory change I had to kill the application because it froze.
------------ LOG -------------------------
. 2007-05-19 12:23:29.000 --------------------------------------------------------------------------
. 2007-05-19 12:23:29.000 WinSCP Version 4.0.0 (Build 342) (OS 5.1.2600 Service Pack 2)
. 2007-05-19 12:23:29.000 Login time: Saturday, May 19, 2007 12:23:29 PM
. 2007-05-19 12:23:29.000 Session name: @eOneHartwellInternal
. 2007-05-19 12:23:29.000 Host name: 65.196.174.10 (Port: 22)
. 2007-05-19 12:23:29.000 User name: root (Password: No, Key file: No)
. 2007-05-19 12:23:29.000 Tunnel: No
. 2007-05-19 12:23:29.000 Transfer Protocol: SFTP (SCP)
. 2007-05-19 12:23:29.000 Ping type: -, Ping interval: 30 sec; Timeout: 15 sec
. 2007-05-19 12:23:29.000 Proxy: none
. 2007-05-19 12:23:29.000 SSH protocol version: 2; Compression: No
. 2007-05-19 12:23:29.000 Agent forwarding: No; TIS/CryptoCard: No; KI: Yes; GSSAPI: No
. 2007-05-19 12:23:29.000 Ciphers: aes,blowfish,3des,WARN,des; Ssh2DES: No
. 2007-05-19 12:23:29.000 SSH Bugs: -,-,-,-,-,-,-,-
. 2007-05-19 12:23:29.000 SFTP Bugs: -,-,-
. 2007-05-19 12:23:29.000 Return code variable: Autodetect; Lookup user groups: Yes
. 2007-05-19 12:23:29.000 Shell: default, EOL: 0
. 2007-05-19 12:23:29.000 Clear aliases: Yes, Unset nat.vars: Yes, Resolve symlinks: Yes
. 2007-05-19 12:23:29.000 Alias LS: No, Ign LS warn: Yes, Scp1 Comp: No
. 2007-05-19 12:23:29.000 Local directory: default, Remote directory: home, Update: No, Cache: Yes
. 2007-05-19 12:23:29.000 Cache directory changes: Yes, Permanent: Yes
. 2007-05-19 12:23:29.000 DST mode: 1
. 2007-05-19 12:23:29.046 Looking up host "65.196.174.10"
. 2007-05-19 12:23:29.046 Connecting to 65.196.174.10 port 22
. 2007-05-19 12:23:29.125 Selecting events 63 for socket 676
. 2007-05-19 12:23:29.125 Waiting for the server to continue with the initialisation
. 2007-05-19 12:23:29.125 Looking for incoming data
. 2007-05-19 12:23:29.125 Looking for network events
. 2007-05-19 12:23:29.125 Detected network event
. 2007-05-19 12:23:29.125 Enumerating network events for socket 676
. 2007-05-19 12:23:29.125 Enumerated 18 network events for socket 676
. 2007-05-19 12:23:29.125 Detected network write event on socket 676 with error 0
. 2007-05-19 12:23:29.125 Detected network connect event on socket 676 with error 0
. 2007-05-19 12:23:29.187 Detected network event
. 2007-05-19 12:23:29.187 Enumerating network events for socket 676
. 2007-05-19 12:23:29.187 Enumerated 1 network events for socket 676
. 2007-05-19 12:23:29.187 Detected network read event on socket 676 with error 0
. 2007-05-19 12:23:29.187 Server version: SSH-1.99-OpenSSH_3.9p1
. 2007-05-19 12:23:29.203 We claim version: SSH-2.0-WinSCP_release_4.0
. 2007-05-19 12:23:29.203 Using SSH protocol version 2
. 2007-05-19 12:23:29.203 Waiting for the server to continue with the initialisation
. 2007-05-19 12:23:29.203 Looking for incoming data
. 2007-05-19 12:23:29.203 Looking for network events
. 2007-05-19 12:23:29.265 Detected network event
. 2007-05-19 12:23:29.265 Enumerating network events for socket 676
. 2007-05-19 12:23:29.265 Enumerated 1 network events for socket 676
. 2007-05-19 12:23:29.265 Detected network read event on socket 676 with error 0
. 2007-05-19 12:23:29.265 Doing Diffie-Hellman group exchange
. 2007-05-19 12:23:29.265 Waiting for the server to continue with the initialisation
. 2007-05-19 12:23:29.265 Looking for incoming data
. 2007-05-19 12:23:29.265 Looking for network events
. 2007-05-19 12:23:29.453 Detected network event
. 2007-05-19 12:23:29.453 Enumerating network events for socket 676
. 2007-05-19 12:23:29.453 Enumerated 1 network events for socket 676
. 2007-05-19 12:23:29.453 Detected network read event on socket 676 with error 0
. 2007-05-19 12:23:29.453 Doing Diffie-Hellman key exchange
. 2007-05-19 12:23:29.656 Waiting for the server to continue with the initialisation
. 2007-05-19 12:23:29.656 Looking for incoming data
. 2007-05-19 12:23:29.656 Looking for network events
. 2007-05-19 12:23:29.765 Detected network event
. 2007-05-19 12:23:29.765 Enumerating network events for socket 676
. 2007-05-19 12:23:29.765 Enumerated 1 network events for socket 676
. 2007-05-19 12:23:29.765 Detected network read event on socket 676 with error 0
. 2007-05-19 12:23:29.875 Selecting events 63 for socket 676
. 2007-05-19 12:23:29.875 Host key fingerprint is:
. 2007-05-19 12:23:29.875 ssh-rsa 1024 ff:69:a3:16:b4:66:5a:be:73:bb:e1:c8:6f:75:3e:b7
. 2007-05-19 12:23:29.875 Initialised AES-256 client->server encryption
. 2007-05-19 12:23:29.875 Initialised HMAC-SHA1 client->server MAC algorithm
. 2007-05-19 12:23:29.875 Initialised AES-256 server->client encryption
. 2007-05-19 12:23:29.875 Initialised HMAC-SHA1 server->client MAC algorithm
. 2007-05-19 12:23:29.875 Waiting for the server to continue with the initialisation
. 2007-05-19 12:23:29.875 Looking for incoming data
. 2007-05-19 12:23:29.875 Looking for network events
. 2007-05-19 12:23:29.875 Detected network event
. 2007-05-19 12:23:29.875 Enumerating network events for socket 676
. 2007-05-19 12:23:29.875 Enumerated 2 network events for socket 676
. 2007-05-19 12:23:29.875 Detected network write event on socket 676 with error 0
. 2007-05-19 12:23:30.046 Detected network event
. 2007-05-19 12:23:30.046 Enumerating network events for socket 676
. 2007-05-19 12:23:30.046 Enumerated 1 network events for socket 676
. 2007-05-19 12:23:30.046 Detected network read event on socket 676 with error 0
! 2007-05-19 12:23:30.046 Using username "root".
. 2007-05-19 12:23:30.046 Waiting for the server to continue with the initialisation
. 2007-05-19 12:23:30.046 Looking for incoming data
. 2007-05-19 12:23:30.046 Looking for network events
. 2007-05-19 12:23:30.109 Detected network event
. 2007-05-19 12:23:30.109 Enumerating network events for socket 676
. 2007-05-19 12:23:30.109 Enumerated 1 network events for socket 676
. 2007-05-19 12:23:30.109 Detected network read event on socket 676 with error 0
. 2007-05-19 12:23:30.109 Pageant is running. Requesting keys.
. 2007-05-19 12:23:30.109 Pageant has 2 SSH-2 keys
. 2007-05-19 12:23:30.109 Trying Pageant key #0
. 2007-05-19 12:23:30.109 Waiting for the server to continue with the initialisation
. 2007-05-19 12:23:30.109 Looking for incoming data
. 2007-05-19 12:23:30.109 Looking for network events
. 2007-05-19 12:23:30.234 Detected network event
. 2007-05-19 12:23:30.234 Enumerating network events for socket 676
. 2007-05-19 12:23:30.234 Enumerated 1 network events for socket 676
. 2007-05-19 12:23:30.234 Detected network read event on socket 676 with error 0
. 2007-05-19 12:23:30.234 Key refused
. 2007-05-19 12:23:30.234 Trying Pageant key #1
. 2007-05-19 12:23:30.234 Waiting for the server to continue with the initialisation
. 2007-05-19 12:23:30.234 Looking for incoming data
. 2007-05-19 12:23:30.234 Looking for network events
. 2007-05-19 12:23:30.312 Detected network event
. 2007-05-19 12:23:30.312 Enumerating network events for socket 676
. 2007-05-19 12:23:30.312 Enumerated 1 network events for socket 676
. 2007-05-19 12:23:30.312 Detected network read event on socket 676 with error 0
! 2007-05-19 12:23:30.312 Authenticating with public key "eone@Isabella" from agent
. 2007-05-19 12:23:30.390 Sending Pageant's response
. 2007-05-19 12:23:30.390 Waiting for the server to continue with the initialisation
. 2007-05-19 12:23:30.390 Looking for incoming data
. 2007-05-19 12:23:30.390 Looking for network events
. 2007-05-19 12:23:30.562 Detected network event
. 2007-05-19 12:23:30.562 Enumerating network events for socket 676
. 2007-05-19 12:23:30.562 Enumerated 1 network events for socket 676
. 2007-05-19 12:23:30.562 Detected network read event on socket 676 with error 0
. 2007-05-19 12:23:30.562 Access granted
. 2007-05-19 12:23:30.578 Waiting for the server to continue with the initialisation
. 2007-05-19 12:23:30.578 Looking for incoming data
. 2007-05-19 12:23:30.578 Looking for network events
. 2007-05-19 12:23:30.640 Detected network event
. 2007-05-19 12:23:30.640 Enumerating network events for socket 676
. 2007-05-19 12:23:30.640 Enumerated 1 network events for socket 676
. 2007-05-19 12:23:30.640 Detected network read event on socket 676 with error 0
. 2007-05-19 12:23:30.640 Opened channel for session
. 2007-05-19 12:23:30.640 Waiting for the server to continue with the initialisation
. 2007-05-19 12:23:30.640 Looking for incoming data
. 2007-05-19 12:23:30.640 Looking for network events
. 2007-05-19 12:23:30.703 Detected network event
. 2007-05-19 12:23:30.703 Enumerating network events for socket 676
. 2007-05-19 12:23:30.703 Enumerated 1 network events for socket 676
. 2007-05-19 12:23:30.703 Detected network read event on socket 676 with error 0
. 2007-05-19 12:23:30.703 Started a shell/command
. 2007-05-19 12:23:30.703 --------------------------------------------------------------------------
. 2007-05-19 12:23:30.703 Using SFTP protocol.
. 2007-05-19 12:23:30.703 Doing startup conversation with host.
> 2007-05-19 12:23:30.703 Type: SSH_FXP_INIT, Size: 5, Number: -1
> 2007-05-19 12:23:30.703 01,00,00,00,05,
. 2007-05-19 12:23:30.703 Sent 9 bytes
. 2007-05-19 12:23:30.703 There are 0 bytes remaining in the send buffer
. 2007-05-19 12:23:30.703 Looking for network events
. 2007-05-19 12:23:30.718 Timeout waiting for network events
. 2007-05-19 12:23:30.718 Waiting for another 4 bytes
. 2007-05-19 12:23:30.718 Looking for incoming data
. 2007-05-19 12:23:30.718 Looking for network events
. 2007-05-19 12:23:30.781 Detected network event
. 2007-05-19 12:23:30.781 Enumerating network events for socket 676
. 2007-05-19 12:23:30.781 Enumerated 1 network events for socket 676
. 2007-05-19 12:23:30.781 Detected network read event on socket 676 with error 0
. 2007-05-19 12:23:30.781 Received 9 bytes (0)
. 2007-05-19 12:23:30.781 Read 4 bytes (5 pending)
. 2007-05-19 12:23:30.781 Read 5 bytes (0 pending)
< 2007-05-19 12:23:30.781 Type: SSH_FXP_VERSION, Size: 5, Number: -1
< 2007-05-19 12:23:30.781 02,00,00,00,03,
. 2007-05-19 12:23:30.781 SFTP version 3 negotiated.
. 2007-05-19 12:23:30.781 We believe the server has signed timestamps bug
. 2007-05-19 12:23:30.781 We will use UTF-8 strings for status messages only
. 2007-05-19 12:23:30.781 Limiting packet size to OpenSSH sftp-server limit of 262148 bytes
. 2007-05-19 12:23:30.781 Getting current directory name.
. 2007-05-19 12:23:30.781 Getting real path for '.'
> 2007-05-19 12:23:30.781 Type: SSH_FXP_REALPATH, Size: 10, Number: 16
> 2007-05-19 12:23:30.781 10,00,00,00,10,00,00,00,01,2E,
. 2007-05-19 12:23:30.781 Sent 14 bytes
. 2007-05-19 12:23:30.781 There are 0 bytes remaining in the send buffer
. 2007-05-19 12:23:30.781 Looking for network events
. 2007-05-19 12:23:30.781 Timeout waiting for network events
. 2007-05-19 12:23:30.781 Waiting for another 4 bytes
. 2007-05-19 12:23:30.781 Looking for incoming data
. 2007-05-19 12:23:30.843 Detected network event
. 2007-05-19 12:23:30.843 Enumerating network events for socket 676
. 2007-05-19 12:23:30.843 Enumerated 1 network events for socket 676
. 2007-05-19 12:23:30.843 Detected network read event on socket 676 with error 0
. 2007-05-19 12:23:30.843 Received 35 bytes (0)
. 2007-05-19 12:23:30.843 Read 4 bytes (31 pending)
. 2007-05-19 12:23:30.843 Read 31 bytes (0 pending)
< 2007-05-19 12:23:30.843 Type: SSH_FXP_NAME, Size: 31, Number: 16
< 2007-05-19 12:23:30.843 68,00,00,00,10,00,00,00,01,00,00,00,05,2F,72,6F,6F,74,00,00,00,05,2F,72,6F,
< 2007-05-19 12:23:30.843 6F,74,00,00,00,00,
. 2007-05-19 12:23:30.843 Real path is '/root'
. 2007-05-19 12:23:30.843 Listing directory "/root".
> 2007-05-19 12:23:30.843 Type: SSH_FXP_OPENDIR, Size: 14, Number: 267
> 2007-05-19 12:23:30.843 0B,00,00,01,0B,00,00,00,05,2F,72,6F,6F,74,
. 2007-05-19 12:23:30.843 Sent 18 bytes
. 2007-05-19 12:23:30.843 There are 0 bytes remaining in the send buffer
. 2007-05-19 12:23:30.843 Looking for network events
. 2007-05-19 12:23:30.843 Timeout waiting for network events
. 2007-05-19 12:23:30.843 Waiting for another 4 bytes
. 2007-05-19 12:23:30.843 Looking for incoming data
. 2007-05-19 12:23:30.906 Detected network event
. 2007-05-19 12:23:30.906 Enumerating network events for socket 676
. 2007-05-19 12:23:30.906 Enumerated 1 network events for socket 676
. 2007-05-19 12:23:30.906 Detected network read event on socket 676 with error 0
. 2007-05-19 12:23:30.906 Received 17 bytes (0)
. 2007-05-19 12:23:30.906 Read 4 bytes (13 pending)
. 2007-05-19 12:23:30.906 Read 13 bytes (0 pending)
< 2007-05-19 12:23:30.906 Type: SSH_FXP_HANDLE, Size: 13, Number: 267
< 2007-05-19 12:23:30.906 66,00,00,01,0B,00,00,00,04,00,00,00,00,
> 2007-05-19 12:23:30.906 Type: SSH_FXP_READDIR, Size: 13, Number: 524
> 2007-05-19 12:23:30.906 0C,00,00,02,0C,00,00,00,04,00,00,00,00,
. 2007-05-19 12:23:30.906 Sent 17 bytes
. 2007-05-19 12:23:30.906 There are 0 bytes remaining in the send buffer
. 2007-05-19 12:23:30.906 Looking for network events
. 2007-05-19 12:23:30.906 Timeout waiting for network events
. 2007-05-19 12:23:30.906 Waiting for another 4 bytes
. 2007-05-19 12:23:30.906 Looking for incoming data
. 2007-05-19 12:23:31.000 Detected network event
. 2007-05-19 12:23:31.000 Enumerating network events for socket 676
. 2007-05-19 12:23:31.000 Enumerated 1 network events for socket 676
. 2007-05-19 12:23:31.000 Detected network read event on socket 676 with error 0
. 2007-05-19 12:23:31.000 Waiting for another 4 bytes
. 2007-05-19 12:23:31.000 Looking for incoming data
. 2007-05-19 12:23:31.000 Looking for network events
. 2007-05-19 12:23:31.015 Detected network event
. 2007-05-19 12:23:31.015 Enumerating network events for socket 676
. 2007-05-19 12:23:31.015 Enumerated 1 network events for socket 676
. 2007-05-19 12:23:31.015 Detected network read event on socket 676 with error 0
. 2007-05-19 12:23:31.015 Waiting for another 4 bytes
. 2007-05-19 12:23:31.015 Looking for incoming data
. 2007-05-19 12:23:31.015 Looking for network events
. 2007-05-19 12:23:31.093 Detected network event
. 2007-05-19 12:23:31.093 Enumerating network events for socket 676
. 2007-05-19 12:23:31.093 Enumerated 1 network events for socket 676
. 2007-05-19 12:23:31.093 Detected network read event on socket 676 with error 0
. 2007-05-19 12:23:31.093 Waiting for another 4 bytes
. 2007-05-19 12:23:31.093 Looking for incoming data
. 2007-05-19 12:23:31.093 Looking for network events
. 2007-05-19 12:23:31.109 Detected network event
. 2007-05-19 12:23:31.109 Enumerating network events for socket 676
. 2007-05-19 12:23:31.109 Enumerated 1 network events for socket 676
. 2007-05-19 12:23:31.109 Detected network read event on socket 676 with error 0
. 2007-05-19 12:23:31.109 Waiting for another 4 bytes
. 2007-05-19 12:23:31.109 Looking for incoming data
. 2007-05-19 12:23:31.109 Looking for network events
. 2007-05-19 12:23:31.109 Received 6662 bytes (0)
. 2007-05-19 12:23:31.109 Read 4 bytes (6658 pending)
. 2007-05-19 12:23:31.109 Read 6658 bytes (0 pending)
< 2007-05-19 12:23:31.109 Type: SSH_FXP_NAME, Size: 6658, Number: 524
< 2007-05-19 12:23:31.140 68,00,00,02,0C,00,00,00,39,00,00,00,02,2E,2E,00,00,00,3A,64,72,77,78,72,2D,
< 2007-05-19 12:23:31.140 78,72,2D,78,20,20,20,32,35,20,72,6F,6F,74,20,20,20,20,20,72,6F,6F,74,20,20,
< 2007-05-19 12:23:31.140 20,20,20,20,20,20,20,34,30,39,36,20,41,70,72,20,32,32,20,31,37,3A,34,39,20,
< 2007-05-19 12:23:31.140 2E,2E,00,00,00,0F,00,00,00,00,00,00,10,00,00,00,00,00,00,00,00,00,00,00,41,
< 2007-05-19 12:23:31.140 ED,46,2D,80,C0,46,2B,E6,8F,00,00,00,0A,6F,75,74,70,75,74,2E,6C,6F,67,00,00,
< 2007-05-19 12:23:31.140 00,42,2D,72,77,2D,72,2D,2D,72,2D,2D,20,20,20,20,31,20,72,6F,6F,74,20,20,20,
< 2007-05-19 12:23:31.140 20,20,72,6F,6F,74,20,20,20,20,20,20,20,20,38,39,31,36,35,20,4D,61,79,20,31,
< 2007-05-19 12:23:31.140 38,20,31,33,3A,30,31,20,6F,75,74,70,75,74,2E,6C,6F,67,00,00,00,0F,00,00,00,
< 2007-05-19 12:23:31.140 00,00,01,5C,4D,00,00,00,00,00,00,00,00,00,00,81,A4,45,9B,ED,D7,46,4D,E9,EB,
< 2007-05-19 12:23:31.140 00,00,00,0E,2E,67,73,74,72,65,61,6D,65,72,2D,30,2E,38,00,00,00,46,64,72,77,
< 2007-05-19 12:23:31.140 78,72,2D,78,72,2D,78,20,20,20,20,32,20,72,6F,6F,74,20,20,20,20,20,72,6F,6F,
< 2007-05-19 12:23:31.140 74,20,20,20,20,20,20,20,20,20,34,30,39,36,20,4E,6F,76,20,32,39,20,31,31,3A,
< 2007-05-19 12:23:31.140 35,33,20,2E,67,73,74,72,65,61,6D,65,72,2D,30,2E,38,00,00,00,0F,00,00,00,00,
< 2007-05-19 12:23:31.140 00,00,10,00,00,00,00,00,00,00,00,00,00,00,41,ED,46,2D,80,CA,45,6D,C9,16,00,
< 2007-05-19 12:23:31.140 00,00,07,44,65,73,6B,74,6F,70,00,00,00,3F,64,72,77,78,72,2D,78,72,2D,78,20,
< 2007-05-19 12:23:31.140 20,20,20,32,20,72,6F,6F,74,20,20,20,20,20,72,6F,6F,74,20,20,20,20,20,20,20,
< 2007-05-19 12:23:31.140 20,20,34,30,39,36,20,44,65,63,20,31,32,20,31,31,3A,35,32,20,44,65,73,6B,74,
< 2007-05-19 12:23:31.140 6F,70,00,00,00,0F,00,00,00,00,00,00,10,00,00,00,00,00,00,00,00,00,00,00,41,
< 2007-05-19 12:23:31.140 ED,46,2D,80,CA,45,7E,EC,41,00,00,00,0C,6F,73,70,5F,4F,52,49,47,2E,74,67,7A,
< 2007-05-19 12:23:31.140 00,00,00,45,2D,72,77,2D,72,2D,2D,72,2D,2D,20,20,20,20,31,20,72,6F,6F,74,20,
< 2007-05-19 12:23:31.140 20,20,20,20,72,6F,6F,74,20,20,20,20,20,31,35,37,37,34,36,36,35,39,20,4D,61,
< 2007-05-19 12:23:31.140 72,20,20,31,20,31,35,3A,35,36,20,6F,73,70,5F,4F,52,49,47,2E,74,67,7A,00,00,
< 2007-05-19 12:23:31.140 00,0F,00,00,00,00,09,67,05,E3,00,00,00,00,00,00,00,00,00,00,81,A4,45,E7,4B,
< 2007-05-19 12:23:31.140 E5,45,E7,4C,0D,00,00,00,11,2E,67,74,6B,72,63,2D,31,2E,32,2D,67,6E,6F,6D,65,
< 2007-05-19 12:23:31.140 32,00,00,00,49,2D,72,77,2D,72,2D,2D,72,2D,2D,20,20,20,20,31,20,72,6F,6F,74,
< 2007-05-19 12:23:31.140 20,20,20,20,20,72,6F,6F,74,20,20,20,20,20,20,20,20,20,20,31,33,30,20,44,65,
< 2007-05-19 12:23:31.140 63,20,31,32,20,31,30,3A,31,39,20,2E,67,74,6B,72,63,2D,31,2E,32,2D,67,6E,6F,
< 2007-05-19 12:23:31.140 6D,65,32,00,00,00,0F,00,00,00,00,00,00,00,82,00,00,00,00,00,00,00,00,00,00,
< 2007-05-19 12:23:31.140 81,A4,46,2C,CC,35,45,7E,D6,7C,00,00,00,0B,2E,58,61,75,74,68,6F,72,69,74,79,
< 2007-05-19 12:23:31.140 00,00,00,43,2D,72,77,2D,2D,2D,2D,2D,2D,2D,20,20,20,20,31,20,72,6F,6F,74,20,
< 2007-05-19 12:23:31.140 20,20,20,20,72,6F,6F,74,20,20,20,20,20,20,20,20,20,20,31,32,30,20,41,70,72,
< 2007-05-19 12:23:31.140 20,32,33,20,31,30,3A,30,39,20,2E,58,61,75,74,68,6F,72,69,74,79,00,00,00,0F,
< 2007-05-19 12:23:31.140 00,00,00,00,00,00,00,78,00,00,00,00,00,00,00,00,00,00,81,80,46,4B,30,68,46,
< 2007-05-19 12:23:31.140 2C,CC,0C,00,00,00,07,2E,62,61,73,68,72,63,00,00,00,3F,2D,72,77,2D,72,2D,2D,
< 2007-05-19 12:23:31.140 72,2D,2D,20,20,20,20,31,20,72,6F,6F,74,20,20,20,20,20,72,6F,6F,74,20,20,20,
< 2007-05-19 12:23:31.140 20,20,20,20,20,20,20,31,37,36,20,53,65,70,20,32,32,20,20,32,30,30,34,20,2E,
< 2007-05-19 12:23:31.140 62,61,73,68,72,63,00,00,00,0F,00,00,00,00,00,00,00,B0,00,00,00,00,00,00,00,
< 2007-05-19 12:23:31.140 00,00,00,81,A4,46,4F,3E,57,41,52,4B,0E,00,00,00,06,2E,67,63,6F,6E,66,00,00,
< 2007-05-19 12:23:31.140 00,3E,64,72,77,78,2D,2D,2D,2D,2D,2D,20,20,20,20,34,20,72,6F,6F,74,20,20,20,
< 2007-05-19 12:23:31.140 20,20,72,6F,6F,74,20,20,20,20,20,20,20,20,20,34,30,39,36,20,4D,61,79,20,31,
< 2007-05-19 12:23:31.140 36,20,31,31,3A,30,39,20,2E,67,63,6F,6E,66,00,00,00,0F,00,00,00,00,00,00,10,
< 2007-05-19 12:23:31.140 00,00,00,00,00,00,00,00,00,00,00,41,C0,46,4B,2C,CC,46,4B,2C,CC,00,00,00,07,
< 2007-05-19 12:23:31.140 6F,73,70,2E,74,67,7A,00,00,00,41,2D,72,77,2D,72,2D,2D,72,2D,2D,20,20,20,20,
< 2007-05-19 12:23:31.140 31,20,72,6F,6F,74,20,20,20,20,20,72,6F,6F,74,20,20,20,20,20,31,33,30,39,36,
< 2007-05-19 12:23:31.140 32,39,30,35,39,20,4D,61,72,20,20,31,20,31,35,3A,32,36,20,6F,73,70,2E,74,67,
< 2007-05-19 12:23:31.140 7A,00,00,00,0F,00,00,00,00,4E,0F,5A,83,00,00,00,00,00,00,00,00,00,00,81,A4,
< 2007-05-19 12:23:31.140 45,E7,4D,38,45,E7,44,EE,00,00,00,0D,2E,62,61,73,68,5F,68,69,73,74,6F,72,79,
< 2007-05-19 12:23:31.140 00,00,00,45,2D,72,77,2D,2D,2D,2D,2D,2D,2D,20,20,20,20,31,20,72,6F,6F,74,20,
< 2007-05-19 12:23:31.140 20,20,20,20,72,6F,6F,74,20,20,20,20,20,20,20,20,31,37,34,33,34,20,4D,61,79,
< 2007-05-19 12:23:31.140 20,31,38,20,31,37,3A,31,34,20,2E,62,61,73,68,5F,68,69,73,74,6F,72,79,00,00,
< 2007-05-19 12:23:31.140 00,0F,00,00,00,00,00,00,44,1A,00,00,00,00,00,00,00,00,00,00,81,80,46,4F,3C,
< 2007-05-19 12:23:31.140 86,46,4E,25,34,00,00,00,08,2E,76,69,6D,69,6E,66,6F,00,00,00,40,2D,72,77,2D,
< 2007-05-19 12:23:31.140 2D,2D,2D,2D,2D,2D,20,20,20,20,31,20,72,6F,6F,74,20,20,20,20,20,72,6F,6F,74,
< 2007-05-19 12:23:31.140 20,20,20,20,20,20,20,20,31,31,34,32,32,20,41,70,72,20,20,34,20,31,34,3A,31,
< 2007-05-19 12:23:31.140 39,20,2E,76,69,6D,69,6E,66,6F,00,00,00,0F,00,00,00,00,00,00,2C,9E,00,00,00,
< 2007-05-19 12:23:31.140 00,00,00,00,00,00,00,81,80,46,2C,CC,35,46,13,FA,4D,00,00,00,01,2E,00,00,00,
< 2007-05-19 12:23:31.140 39,64,72,77,78,72,2D,78,2D,2D,2D,20,20,20,32,34,20,72,6F,6F,74,20,20,20,20,
< 2007-05-19 12:23:31.140 20,72,6F,6F,74,20,20,20,20,20,20,20,20,20,34,30,39,36,20,41,70,72,20,32,33,
< 2007-05-19 12:23:31.140 20,31,30,3A,30,39,20,2E,00,00,00,0F,00,00,00,00,00,00,10,00,00,00,00,00,00,
< 2007-05-19 12:23:31.140 00,00,00,00,00,41,E8,46,4F,3E,57,46,2C,CC,0D,00,00,00,16,65,6F,6E,65,61,64,
< 2007-05-19 12:23:31.140 6D,69,6E,69,73,74,72,61,74,69,6F,6E,2E,74,67,7A,00,00,00,4E,2D,72,77,2D,72,
< 2007-05-19 12:23:31.140 2D,2D,72,2D,2D,20,20,20,20,31,20,72,6F,6F,74,20,20,20,20,20,72,6F,6F,74,20,
< 2007-05-19 12:23:31.140 20,20,20,20,32,30,36,35,33,32,31,35,20,4A,61,6E,20,32,39,20,30,37,3A,35,33,
< 2007-05-19 12:23:31.140 20,65,6F,6E,65,61,64,6D,69,6E,69,73,74,72,61,74,69,6F,6E,2E,74,67,7A,00,00,
< 2007-05-19 12:23:31.140 00,0F,00,00,00,00,01,3B,24,9F,00,00,00,00,00,00,00,00,00,00,81,A4,45,BD,FD,
< 2007-05-19 12:23:31.140 2A,45,BD,FC,64,00,00,00,11,2E,72,68,6E,2D,61,70,70,6C,65,74,2E,63,61,63,68,
< 2007-05-19 12:23:31.140 65,00,00,00,49,2D,72,77,2D,72,2D,2D,72,2D,2D,20,20,20,20,31,20,72,6F,6F,74,
< 2007-05-19 12:23:31.140 20,20,20,20,20,72,6F,6F,74,20,20,20,20,20,20,20,34,31,39,35,37,36,20,41,70,
< 2007-05-19 12:23:31.140 72,20,31,36,20,31,35,3A,30,36,20,2E,72,68,6E,2D,61,70,70,6C,65,74,2E,63,61,
< 2007-05-19 12:23:31.140 63,68,65,00,00,00,0F,00,00,00,00,00,06,66,F8,00,00,00,00,00,00,00,00,00,00,
< 2007-05-19 12:23:31.140 81,A4,46,2C,CC,35,46,23,D7,53,00,00,00,0B,69,6E,73,74,61,6C,6C,2E,6C,6F,67,
< 2007-05-19 12:23:31.140 00,00,00,43,2D,72,77,2D,72,2D,2D,72,2D,2D,20,20,20,20,31,20,72,6F,6F,74,20,
< 2007-05-19 12:23:31.140 20,20,20,20,72,6F,6F,74,20,20,20,20,20,20,20,20,34,39,32,32,34,20,4E,6F,76,
< 2007-05-19 12:23:31.140 20,32,39,20,31,31,3A,35,38,20,69,6E,73,74,61,6C,6C,2E,6C,6F,67,00,00,00,0F,
< 2007-05-19 12:23:31.140 00,00,00,00,00,00,C0,48,00,00,00,00,00,00,00,00,00,00,81,A4,45,6D,C8,85,45,
< 2007-05-19 12:23:31.140 6D,CA,30,00,00,00,06,2E,54,72,61,73,68,00,00,00,3E,64,72,77,78,2D,2D,2D,2D,
< 2007-05-19 12:23:31.140 2D,2D,20,20,20,20,32,20,72,6F,6F,74,20,20,20,20,20,72,6F,6F,74,20,20,20,20,
< 2007-05-19 12:23:31.140 20,20,20,20,20,34,30,39,36,20,44,65,63,20,31,32,20,31,31,3A,33,36,20,2E,54,
< 2007-05-19 12:23:31.140 72,61,73,68,00,00,00,0F,00,00,00,00,00,00,10,00,00,00,00,00,00,00,00,00,00,
< 2007-05-19 12:23:31.140 00,41,C0,46,2D,80,CA,45,7E,E8,B8,00,00,00,0F,61,6E,61,63,6F,6E,64,61,2D,6B,
< 2007-05-19 12:23:31.140 73,2E,63,66,67,00,00,00,47,2D,72,77,2D,72,2D,2D,72,2D,2D,20,20,20,20,31,20,
< 2007-05-19 12:23:31.140 72,6F,6F,74,20,20,20,20,20,72,6F,6F,74,20,20,20,20,20,20,20,20,20,32,30,32,
< 2007-05-19 12:23:31.140 31,20,4E,6F,76,20,32,39,20,31,31,3A,35,38,20,61,6E,61,63,6F,6E,64,61,2D,6B,
< 2007-05-19 12:23:31.140 73,2E,63,66,67,00,00,00,0F,00,00,00,00,00,00,07,E5,00,00,00,00,00,00,00,00,
< 2007-05-19 12:23:31.140 00,00,81,A4,46,2C,CC,35,45,6D,CA,34,00,00,00,09,2E,6D,65,74,61,63,69,74,79,
< 2007-05-19 12:23:31.140 00,00,00,41,64,72,77,78,2D,2D,2D,2D,2D,2D,20,20,20,20,33,20,72,6F,6F,74,20,
< 2007-05-19 12:23:31.140 20,20,20,20,72,6F,6F,74,20,20,20,20,20,20,20,20,20,34,30,39,36,20,44,65,63,
< 2007-05-19 12:23:31.140 20,31,32,20,31,30,3A,31,39,20,2E,6D,65,74,61,63,69,74,79,00,00,00,0F,00,00,
< 2007-05-19 12:23:31.140 00,00,00,00,10,00,00,00,00,00,00,00,00,00,00,00,41,C0,46,2D,80,CA,45,7E,D6,
< 2007-05-19 12:23:31.140 7F,00,00,00,0E,2E,6D,79,73,71,6C,5F,68,69,73,74,6F,72,79,00,00,00,46,2D,72,
< 2007-05-19 12:23:31.140 77,2D,2D,2D,2D,2D,2D,2D,20,20,20,20,31,20,72,6F,6F,74,20,20,20,20,20,72,6F,
< 2007-05-19 12:23:31.140 6F,74,20,20,20,20,20,20,20,20,20,33,39,38,36,20,4D,61,72,20,32,38,20,30,36,
< 2007-05-19 12:23:31.140 3A,34,36,20,2E,6D,79,73,71,6C,5F,68,69,73,74,6F,72,79,00,00,00,0F,00,00,00,
< 2007-05-19 12:23:31.140 00,00,00,0F,92,00,00,00,00,00,00,00,00,00,00,81,80,46,2C,CC,35,46,0A,55,88,
< 2007-05-19 12:23:31.140 00,00,00,06,2E,67,74,6B,72,63,00,00,00,3E,2D,72,77,2D,72,2D,2D,72,2D,2D,20,
< 2007-05-19 12:23:31.140 20,20,20,31,20,72,6F,6F,74,20,20,20,20,20,72,6F,6F,74,20,20,20,20,20,20,20,
< 2007-05-19 12:23:31.140 20,20,20,31,32,30,20,41,75,67,20,20,35,20,20,32,30,30,35,20,2E,67,74,6B,72,
< 2007-05-19 12:23:31.140 63,00,00,00,0F,00,00,00,00,00,00,00,78,00,00,00,00,00,00,00,00,00,00,81,A4,
< 2007-05-19 12:23:31.140 42,F3,A8,8B,42,F3,A8,8B,00,00,00,0C,6D,79,73,71,6C,69,6E,73,74,61,6C,6C,00,
< 2007-05-19 12:23:31.140 00,00,44,64,72,77,78,72,2D,78,72,2D,78,20,20,20,20,32,20,72,6F,6F,74,20,20,
< 2007-05-19 12:23:31.140 20,20,20,72,6F,6F,74,20,20,20,20,20,20,20,20,20,34,30,39,36,20,44,65,63,20,
< 2007-05-19 12:23:31.140 32,37,20,31,31,3A,33,33,20,6D,79,73,71,6C,69,6E,73,74,61,6C,6C,00,00,00,0F,
< 2007-05-19 12:23:31.140 00,00,00,00,00,00,10,00,00,00,00,00,00,00,00,00,00,00,41,ED,46,2D,80,CA,45,
< 2007-05-19 12:23:31.140 92,AE,56,00,00,00,04,2E,6B,64,65,00,00,00,3C,64,72,77,78,2D,2D,2D,2D,2D,2D,
< 2007-05-19 12:23:31.140 20,20,20,20,33,20,72,6F,6F,74,20,20,20,20,20,72,6F,6F,74,20,20,20,20,20,20,
< 2007-05-19 12:23:31.140 20,20,20,34,30,39,36,20,41,70,72,20,31,37,20,30,38,3A,31,38,20,2E,6B,64,65,
< 2007-05-19 12:23:31.140 00,00,00,0F,00,00,00,00,00,00,10,00,00,00,00,00,00,00,00,00,00,00,41,C0,46,
< 2007-05-19 12:23:31.140 2D,80,CA,46,24,C9,37,00,00,00,0D,2E,49,43,45,61,75,74,68,6F,72,69,74,79,00,
< 2007-05-19 12:23:31.140 00,00,45,2D,72,77,2D,2D,2D,2D,2D,2D,2D,20,20,20,20,31,20,72,6F,6F,74,20,20,
< 2007-05-19 12:23:31.140 20,20,20,72,6F,6F,74,20,20,20,20,20,20,20,20,20,20,35,31,39,20,41,70,72,20,
< 2007-05-19 12:23:31.140 32,33,20,31,30,3A,30,39,20,2E,49,43,45,61,75,74,68,6F,72,69,74,79,00,00,00,
< 2007-05-19 12:23:31.140 0F,00,00,00,00,00,00,02,07,00,00,00,00,00,00,00,00,00,00,81,80,46,2C,CC,35,
< 2007-05-19 12:23:31.140 46,2C,CC,0D,00,00,00,09,2E,65,73,64,5F,61,75,74,68,00,00,00,41,2D,72,77,2D,
< 2007-05-19 12:23:31.140 20,20,20,20,20,20,20,20,20,20,20,31,36,20,41,70,72,20,31,36,20,31,35,3A,30,
< 2007-05-19 12:23:31.140 31,20,2E,65,73,64,5F,61,75,74,68,00,00,00,0F,00,00,00,00,00,00,00,10,00,00,
< 2007-05-19 12:23:31.140 00,00,00,00,00,00,00,00,81,80,46,2C,CC,35,46,23,D6,25,00,00,00,08,2E,6D,61,
< 2007-05-19 12:23:31.140 69,6C,63,61,70,00,00,00,40,2D,72,77,2D,72,2D,2D,72,2D,2D,20,20,20,20,31,20,
< 2007-05-19 12:23:31.140 72,6F,6F,74,20,20,20,20,20,72,6F,6F,74,20,20,20,20,20,20,20,20,20,20,20,38,
< 2007-05-19 12:23:31.140 39,20,44,65,63,20,32,37,20,30,37,3A,31,34,20,2E,6D,61,69,6C,63,61,70,00,00,
< 2007-05-19 12:23:31.140 00,0F,00,00,00,00,00,00,00,59,00,00,00,00,00,00,00,00,00,00,81,A4,46,2C,CC,
< 2007-05-19 12:23:31.140 35,45,92,71,CD,00,00,00,03,72,61,72,00,00,00,3B,64,72,77,78,72,2D,78,72,2D,
< 2007-05-19 12:23:31.140 78,20,20,20,20,32,20,72,6F,6F,74,20,20,20,20,20,72,6F,6F,74,20,20,20,20,20,
< 2007-05-19 12:23:31.140 20,20,20,20,34,30,39,36,20,41,75,67,20,20,34,20,20,32,30,30,36,20,72,61,72,
< 2007-05-19 12:23:31.140 00,00,00,0F,00,00,00,00,00,00,10,00,00,00,00,00,00,00,00,00,00,00,41,ED,46,
< 2007-05-19 12:23:31.140 2D,80,CA,44,D3,94,61,00,00,00,08,74,6F,64,65,70,6C,6F,79,00,00,00,40,64,72,
< 2007-05-19 12:23:31.140 77,78,72,2D,78,72,2D,78,20,20,20,20,32,20,72,6F,6F,74,20,20,20,20,20,72,6F,
< 2007-05-19 12:23:31.140 6F,74,20,20,20,20,20,20,20,20,20,34,30,39,36,20,41,70,72,20,31,38,20,32,31,
< 2007-05-19 12:23:31.140 3A,32,37,20,74,6F,64,65,70,6C,6F,79,00,00,00,0F,00,00,00,00,00,00,10,00,00,
< 2007-05-19 12:23:31.140 00,00,00,00,00,00,00,00,00,41,ED,46,2D,80,CA,46,26,D3,93,00,00,00,1A,64,3A,
< 2007-05-19 12:23:31.156 5C,74,6F,6D,63,61,74,5C,6C,6F,67,73,5C,64,62,74,72,61,63,65,2E,6C,6F,67,00,
< 2007-05-19 12:23:31.156 00,00,52,2D,72,77,2D,72,2D,2D,72,2D,2D,20,20,20,20,31,20,72,6F,6F,74,20,20,
< 2007-05-19 12:23:31.156 20,20,20,72,6F,6F,74,20,20,20,20,20,20,20,20,20,20,20,20,30,20,4A,61,6E,20,
< 2007-05-19 12:23:31.156 20,33,20,31,31,3A,35,34,20,64,3A,5C,74,6F,6D,63,61,74,5C,6C,6F,67,73,5C,64,
< 2007-05-19 12:23:31.156 62,74,72,61,63,65,2E,6C,6F,67,00,00,00,0F,00,00,00,00,00,00,00,00,00,00,00,
< 2007-05-19 12:23:31.156 00,00,00,00,00,00,00,81,A4,45,9B,ED,D7,45,9B,ED,D7,00,00,00,0E,2E,72,65,63,
< 2007-05-19 12:23:31.156 65,6E,74,6C,79,2D,75,73,65,64,00,00,00,46,2D,72,77,2D,2D,2D,2D,2D,2D,2D,20,
< 2007-05-19 12:23:31.156 20,20,20,31,20,72,6F,6F,74,20,20,20,20,20,72,6F,6F,74,20,20,20,20,20,20,20,
< 2007-05-19 12:23:31.156 20,20,20,34,38,34,20,46,65,62,20,20,36,20,31,36,3A,31,30,20,2E,72,65,63,65,
< 2007-05-19 12:23:31.156 6E,74,6C,79,2D,75,73,65,64,00,00,00,0F,00,00,00,00,00,00,01,E4,00,00,00,00,
< 2007-05-19 12:23:31.156 00,00,00,00,00,00,81,80,46,2C,CC,35,45,C8,FC,DB,00,00,00,08,2E,6D,6F,7A,69,
< 2007-05-19 12:23:31.156 6C,6C,61,00,00,00,40,64,72,77,78,72,2D,78,72,2D,78,20,20,20,20,33,20,72,6F,
< 2007-05-19 12:23:31.156 6F,74,20,20,20,20,20,72,6F,6F,74,20,20,20,20,20,20,20,20,20,34,30,39,36,20,
< 2007-05-19 12:23:31.156 44,65,63,20,31,32,20,31,30,3A,32,33,20,2E,6D,6F,7A,69,6C,6C,61,00,00,00,0F,
< 2007-05-19 12:23:31.156 00,00,00,00,00,00,10,00,00,00,00,00,00,00,00,00,00,00,41,ED,46,2D,80,CA,45,
< 2007-05-19 12:23:31.156 7E,D7,92,00,00,00,07,6E,65,77,2E,74,67,7A,00,00,00,3F,2D,72,77,2D,72,2D,2D,
< 2007-05-19 12:23:31.156 72,2D,2D,20,20,20,20,31,20,72,6F,6F,74,20,20,20,20,20,72,6F,6F,74,20,20,20,
< 2007-05-19 12:23:31.156 20,20,20,37,31,31,31,38,39,37,20,41,70,72,20,32,31,20,31,33,3A,30,34,20,6E,
< 2007-05-19 12:23:31.156 65,77,2E,74,67,7A,00,00,00,0F,00,00,00,00,00,6C,84,D9,00,00,00,00,00,00,00,
< 2007-05-19 12:23:31.156 00,00,00,81,A4,46,2A,52,51,46,2A,52,19,00,00,00,0B,2E,74,68,75,6D,62,6E,61,
< 2007-05-19 12:23:31.156 69,6C,73,00,00,00,43,64,72,77,78,2D,2D,2D,2D,2D,2D,20,20,20,20,33,20,72,6F,
< 2007-05-19 12:23:31.156 44,65,63,20,31,32,20,31,31,3A,33,38,20,2E,74,68,75,6D,62,6E,61,69,6C,73,00,
< 2007-05-19 12:23:31.156 00,00,0F,00,00,00,00,00,00,10,00,00,00,00,00,00,00,00,00,00,00,41,C0,46,2D,
< 2007-05-19 12:23:31.156 80,CA,45,7E,E9,22,00,00,00,09,2E,6E,61,75,74,69,6C,75,73,00,00,00,41,64,72,
< 2007-05-19 12:23:31.156 77,78,72,2D,78,72,2D,78,20,20,20,20,33,20,72,6F,6F,74,20,20,20,20,20,72,6F,
< 2007-05-19 12:23:31.156 6F,74,20,20,20,20,20,20,20,20,20,34,30,39,36,20,44,65,63,20,31,32,20,31,30,
< 2007-05-19 12:23:31.156 3A,31,39,20,2E,6E,61,75,74,69,6C,75,73,00,00,00,0F,00,00,00,00,00,00,10,00,
< 2007-05-19 12:23:31.156 00,00,00,00,00,00,00,00,00,00,41,ED,46,2D,80,CA,45,7E,D6,7F,00,00,00,15,72,
< 2007-05-19 12:23:31.156 61,72,6C,69,6E,75,78,2D,33,2E,36,2E,30,2E,74,61,72,2E,67,7A,00,00,00,4D,2D,
< 2007-05-19 12:23:31.156 72,77,2D,72,2D,2D,72,2D,2D,20,20,20,20,31,20,72,6F,6F,74,20,20,20,20,20,72,
< 2007-05-19 12:23:31.156 6F,6F,74,20,20,20,20,20,20,20,37,35,32,39,39,37,20,41,75,67,20,31,36,20,20,
< 2007-05-19 12:23:31.156 32,30,30,36,20,72,61,72,6C,69,6E,75,78,2D,33,2E,36,2E,30,2E,74,61,72,2E,67,
< 2007-05-19 12:23:31.156 7A,00,00,00,0F,00,00,00,00,00,0B,7D,65,00,00,00,00,00,00,00,00,00,00,81,A4,
< 2007-05-19 12:23:31.156 45,E7,50,38,44,E3,84,44,00,00,00,0D,2E,62,61,73,68,5F,70,72,6F,66,69,6C,65,
< 2007-05-19 12:23:31.156 00,00,00,45,2D,72,77,2D,72,2D,2D,72,2D,2D,20,20,20,20,31,20,72,6F,6F,74,20,
< 2007-05-19 12:23:31.156 20,20,20,20,72,6F,6F,74,20,20,20,20,20,20,20,20,20,20,31,39,31,20,53,65,70,
< 2007-05-19 12:23:31.156 20,32,32,20,20,32,30,30,34,20,2E,62,61,73,68,5F,70,72,6F,66,69,6C,65,00,00,
< 2007-05-19 12:23:31.156 00,0F,00,00,00,00,00,00,00,BF,00,00,00,00,00,00,00,00,00,00,81,A4,46,4F,3C,
< 2007-05-19 12:23:31.156 86,41,52,4B,0E,00,00,00,0B,2E,6D,69,6D,65,2E,74,79,70,65,73,00,00,00,43,2D,
< 2007-05-19 12:23:31.156 6F,6F,74,20,20,20,20,20,20,20,20,20,20,32,33,30,20,44,65,63,20,32,37,20,30,
< 2007-05-19 12:23:31.156 37,3A,31,34,20,2E,6D,69,6D,65,2E,74,79,70,65,73,00,00,00,0F,00,00,00,00,00,
< 2007-05-19 12:23:31.156 00,00,E6,00,00,00,00,00,00,00,00,00,00,81,A4,46,2C,CC,35,45,92,71,CD,00,00,
< 2007-05-19 12:23:31.156 00,0C,2E,62,61,73,68,5F,6C,6F,67,6F,75,74,00,00,00,44,2D,72,77,2D,72,2D,2D,
< 2007-05-19 12:23:31.156 20,20,20,20,20,20,20,20,32,34,20,53,65,70,20,32,32,20,20,32,30,30,34,20,2E,
< 2007-05-19 12:23:31.156 62,61,73,68,5F,6C,6F,67,6F,75,74,00,00,00,0F,00,00,00,00,00,00,00,18,00,00,
< 2007-05-19 12:23:31.156 00,00,00,00,00,00,00,00,81,A4,46,4E,25,33,41,52,4B,0E,00,00,00,07,2E,67,63,
< 2007-05-19 12:23:31.156 6F,6E,66,64,00,00,00,3F,64,72,77,78,2D,2D,2D,2D,2D,2D,20,20,20,20,32,20,72,
< 2007-05-19 12:23:31.156 6F,6F,74,20,20,20,20,20,72,6F,6F,74,20,20,20,20,20,20,20,20,20,34,30,39,36,
< 2007-05-19 12:23:31.156 20,4D,61,79,20,31,36,20,31,31,3A,32,35,20,2E,67,63,6F,6E,66,64,00,00,00,0F,
< 2007-05-19 12:23:31.156 00,00,00,00,00,00,10,00,00,00,00,00,00,00,00,00,00,00,41,C0,46,2D,80,CA,46,
< 2007-05-19 12:23:31.156 4B,30,8C,00,00,00,0F,2E,67,6E,6F,6D,65,32,5F,70,72,69,76,61,74,65,00,00,00,
< 2007-05-19 12:23:31.156 47,64,72,77,78,2D,2D,2D,2D,2D,2D,20,20,20,20,32,20,72,6F,6F,74,20,20,20,20,
< 2007-05-19 12:23:31.156 20,72,6F,6F,74,20,20,20,20,20,20,20,20,20,34,30,39,36,20,4E,6F,76,20,32,39,
< 2007-05-19 12:23:31.156 20,31,31,3A,35,33,20,2E,67,6E,6F,6D,65,32,5F,70,72,69,76,61,74,65,00,00,00,
< 2007-05-19 12:23:31.156 0F,00,00,00,00,00,00,10,00,00,00,00,00,00,00,00,00,00,00,41,C0,46,2D,80,CA,
< 2007-05-19 12:23:31.156 45,6D,C9,1C,00,00,00,06,2E,63,73,68,72,63,00,00,00,3E,2D,72,77,2D,72,2D,2D,
< 2007-05-19 12:23:31.156 20,20,20,20,20,20,20,31,30,30,20,53,65,70,20,32,32,20,20,32,30,30,34,20,2E,
< 2007-05-19 12:23:31.156 63,73,68,72,63,00,00,00,0F,00,00,00,00,00,00,00,64,00,00,00,00,00,00,00,00,
< 2007-05-19 12:23:31.156 00,00,81,A4,46,2C,CC,35,41,52,4B,0E,00,00,00,05,2E,6D,63,6F,70,00,00,00,3D,
< 2007-05-19 12:23:31.156 64,72,77,78,72,2D,78,72,2D,78,20,20,20,20,33,20,72,6F,6F,74,20,20,20,20,20,
< 2007-05-19 12:23:31.156 72,6F,6F,74,20,20,20,20,20,20,20,20,20,34,30,39,36,20,46,65,62,20,20,36,20,
< 2007-05-19 12:23:31.156 31,35,3A,34,32,20,2E,6D,63,6F,70,00,00,00,0F,00,00,00,00,00,00,10,00,00,00,
< 2007-05-19 12:23:31.156 00,00,00,00,00,00,00,00,41,ED,46,2D,80,CA,45,C8,F6,41,00,00,00,07,2E,74,63,
< 2007-05-19 12:23:31.156 73,68,72,63,00,00,00,3F,2D,72,77,2D,72,2D,2D,72,2D,2D,20,20,20,20,31,20,72,
< 2007-05-19 12:23:31.156 6F,6F,74,20,20,20,20,20,72,6F,6F,74,20,20,20,20,20,20,20,20,20,20,31,30,32,
< 2007-05-19 12:23:31.156 20,53,65,70,20,32,32,20,20,32,30,30,34,20,2E,74,63,73,68,72,63,00,00,00,0F,
< 2007-05-19 12:23:31.156 00,00,00,00,00,00,00,66,00,00,00,00,00,00,00,00,00,00,81,A4,46,2C,CC,35,41,
< 2007-05-19 12:23:31.156 52,4B,0E,00,00,00,05,2E,64,6D,72,63,00,00,00,3D,2D,72,77,2D,2D,2D,2D,2D,2D,
< 2007-05-19 12:23:31.156 2D,20,20,20,20,31,20,72,6F,6F,74,20,20,20,20,20,72,6F,6F,74,20,20,20,20,20,
< 2007-05-19 12:23:31.156 20,20,20,20,20,20,32,36,20,44,65,63,20,31,32,20,31,30,3A,31,39,20,2E,64,6D,
< 2007-05-19 12:23:31.156 72,63,00,00,00,0F,00,00,00,00,00,00,00,1A,00,00,00,00,00,00,00,00,00,00,81,
< 2007-05-19 12:23:31.156 80,46,2C,CC,35,45,7E,D6,7A,00,00,00,12,69,6E,73,74,61,6C,6C,2E,6C,6F,67,2E,
< 2007-05-19 12:23:31.156 73,79,73,6C,6F,67,00,00,00,4A,2D,72,77,2D,72,2D,2D,72,2D,2D,20,20,20,20,31,
< 2007-05-19 12:23:31.156 20,72,6F,6F,74,20,20,20,20,20,72,6F,6F,74,20,20,20,20,20,20,20,20,20,36,31,
< 2007-05-19 12:23:31.156 32,31,20,4E,6F,76,20,32,39,20,31,31,3A,35,38,20,69,6E,73,74,61,6C,6C,2E,6C,
< 2007-05-19 12:23:31.156 6F,67,2E,73,79,73,6C,6F,67,00,00,00,0F,00,00,00,00,00,00,17,E9,00,00,00,00,
< 2007-05-19 12:23:31.156 00,00,00,00,00,00,81,A4,46,2C,CC,35,45,6D,CA,2E,00,00,00,10,2E,72,68,6E,2D,
< 2007-05-19 12:23:31.156 61,70,70,6C,65,74,2E,63,6F,6E,66,00,00,00,48,2D,72,77,2D,2D,2D,2D,2D,2D,2D,
< 2007-05-19 12:23:31.156 20,20,20,20,31,20,72,6F,6F,74,20,20,20,20,20,72,6F,6F,74,20,20,20,20,20,20,
< 2007-05-19 12:23:31.156 20,20,20,20,35,35,37,20,4D,61,79,20,31,31,20,31,30,3A,34,38,20,2E,72,68,6E,
< 2007-05-19 12:23:31.156 2D,61,70,70,6C,65,74,2E,63,6F,6E,66,00,00,00,0F,00,00,00,00,00,00,02,2D,00,
< 2007-05-19 12:23:31.156 00,00,00,00,00,00,00,00,00,81,80,46,2C,CC,35,46,44,90,30,00,00,00,07,2E,65,
< 2007-05-19 12:23:31.156 6C,69,6E,6B,73,00,00,00,3F,64,72,77,78,2D,2D,2D,2D,2D,2D,20,20,20,20,32,20,
< 2007-05-19 12:23:31.156 72,6F,6F,74,20,20,20,20,20,72,6F,6F,74,20,20,20,20,20,20,20,20,20,34,30,39,
< 2007-05-19 12:23:31.156 36,20,4A,61,6E,20,32,36,20,31,37,3A,33,33,20,2E,65,6C,69,6E,6B,73,00,00,00,
< 2007-05-19 12:23:31.156 45,BA,8F,DD,00,00,00,06,2E,67,6E,6F,6D,65,00,00,00,3E,64,72,77,78,2D,2D,2D,
< 2007-05-19 12:23:31.156 2D,2D,2D,20,20,20,20,35,20,72,6F,6F,74,20,20,20,20,20,72,6F,6F,74,20,20,20,
< 2007-05-19 12:23:31.156 20,20,20,20,20,20,34,30,39,36,20,44,65,63,20,31,32,20,31,31,3A,34,37,20,2E,
< 2007-05-19 12:23:31.156 67,6E,6F,6D,65,00,00,00,0F,00,00,00,00,00,00,10,00,00,00,00,00,00,00,00,00,
< 2007-05-19 12:23:31.156 00,00,41,C0,46,2D,80,CA,45,7E,EB,29,00,00,00,07,2E,67,6E,6F,6D,65,32,00,00,
< 2007-05-19 12:23:31.156 00,3F,64,72,77,78,2D,2D,2D,2D,2D,2D,20,20,20,20,37,20,72,6F,6F,74,20,20,20,
< 2007-05-19 12:23:31.156 20,20,72,6F,6F,74,20,20,20,20,20,20,20,20,20,34,30,39,36,20,41,70,72,20,31,
< 2007-05-19 12:23:31.156 37,20,30,38,3A,32,30,20,2E,67,6E,6F,6D,65,32,00,00,00,0F,00,00,00,00,00,00,
< 2007-05-19 12:23:31.156 10,00,00,00,00,00,00,00,00,00,00,00,41,C0,46,2D,80,CA,46,24,C9,9D,00,00,00,
< 2007-05-19 12:23:31.156 08,2E,65,67,67,63,75,70,73,00,00,00,40,64,72,77,78,72,2D,78,2D,2D,2D,20,20,
< 2007-05-19 12:23:31.156 20,20,32,20,72,6F,6F,74,20,20,20,20,20,72,6F,6F,74,20,20,20,20,20,20,20,20,
< 2007-05-19 12:23:31.156 20,34,30,39,36,20,44,65,63,20,31,32,20,31,30,3A,31,39,20,2E,65,67,67,63,75,
< 2007-05-19 12:23:31.156 70,73,00,00,00,0F,00,00,00,00,00,00,10,00,00,00,00,00,00,00,00,00,00,00,41,
< 2007-05-19 12:23:31.156 E8,46,2D,80,CA,45,7E,D6,7E,00,00,00,12,30,33,30,31,32,30,30,37,68,77,2E,73,
< 2007-05-19 12:23:31.156 71,6C,2E,74,67,7A,00,00,00,4A,2D,72,77,2D,72,2D,2D,72,2D,2D,20,20,20,20,31,
< 2007-05-19 12:23:31.156 20,72,6F,6F,74,20,20,20,20,20,72,6F,6F,74,20,20,20,20,20,38,36,39,34,32,34,
< 2007-05-19 12:23:31.156 37,38,20,4D,61,72,20,20,31,20,31,32,3A,34,30,20,30,33,30,31,32,30,30,37,68,
< 2007-05-19 12:23:31.156 77,2E,73,71,6C,2E,74,67,7A,00,00,00,0F,00,00,00,00,05,2E,A3,0E,00,00,00,00,
< 2007-05-19 12:23:31.156 00,00,00,00,00,00,81,A4,45,E7,46,33,45,E7,1E,19,00,00,00,04,2E,73,73,68,00,
< 2007-05-19 12:23:31.156 00,00,3C,64,72,77,78,72,2D,78,72,2D,78,20,20,20,20,32,20,72,6F,6F,74,20,20,
< 2007-05-19 12:23:31.156 20,20,20,72,6F,6F,74,20,20,20,20,20,20,20,20,20,34,30,39,36,20,4D,61,72,20,
< 2007-05-19 12:23:31.156 20,31,20,31,32,3A,31,37,20,2E,73,73,68,00,00,00,0F,00,00,00,00,00,00,10,00,
< 2007-05-19 12:23:31.156 00,00,00,00,00,00,00,00,00,00,41,ED,46,2D,80,CA,45,E7,18,CD,00,00,00,07,2E,
< 2007-05-19 12:23:31.156 6D,63,6F,70,72,63,00,00,00,3F,2D,72,77,2D,2D,2D,2D,2D,2D,2D,20,20,20,20,31,
< 2007-05-19 12:23:31.156 20,72,6F,6F,74,20,20,20,20,20,72,6F,6F,74,20,20,20,20,20,20,20,20,20,20,20,
< 2007-05-19 12:23:31.156 33,31,20,41,70,72,20,20,34,20,31,34,3A,34,36,20,2E,6D,63,6F,70,72,63,00,00,
< 2007-05-19 12:23:31.156 00,0F,00,00,00,00,00,00,00,1F,00,00,00,00,00,00,00,00,00,00,81,80,46,2C,CC,
< 2007-05-19 12:23:31.156 35,46,14,00,AB,00,00,00,0E,2E,66,6F,6E,74,73,2E,63,61,63,68,65,2D,31,00,00,
< 2007-05-19 12:23:31.156 00,46,2D,72,77,2D,72,2D,2D,72,2D,2D,20,20,20,20,31,20,72,6F,6F,74,20,20,20,
< 2007-05-19 12:23:31.156 20,20,72,6F,6F,74,20,20,20,20,20,20,20,20,20,20,20,20,30,20,44,65,63,20,31,
< 2007-05-19 12:23:31.156 32,20,31,36,3A,31,31,20,2E,66,6F,6E,74,73,2E,63,61,63,68,65,2D,31,00,00,00,
< 2007-05-19 12:23:31.156 0F,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,81,A4,46,4B,30,69,
< 2007-05-19 12:23:31.156 45,7F,28,F8,00,00,00,03,2E,71,74,00,00,00,3B,64,72,77,78,72,2D,78,72,2D,78,
< 2007-05-19 12:23:31.156 20,20,20,20,32,20,72,6F,6F,74,20,20,20,20,20,72,6F,6F,74,20,20,20,20,20,20,
< 2007-05-19 12:23:31.156 20,20,20,34,30,39,36,20,44,65,63,20,31,32,20,31,31,3A,30,33,20,2E,71,74,00,
< 2007-05-19 12:23:31.156 00,00,0F,00,00,00,00,00,00,10,00,00,00,00,00,00,00,00,00,00,00,41,ED,46,2D,
< 2007-05-19 12:23:31.156 80,CA,45,7E,E0,CB,00,00,00,17,30,33,30,31,32,30,30,37,68,77,5F,4F,52,49,47,
< 2007-05-19 12:23:31.156 2E,73,71,6C,2E,74,67,7A,00,00,00,4F,2D,72,77,2D,72,2D,2D,72,2D,2D,20,20,20,
< 2007-05-19 12:23:31.156 20,31,20,72,6F,6F,74,20,20,20,20,20,72,6F,6F,74,20,20,20,20,20,37,36,39,35,
< 2007-05-19 12:23:31.156 34,38,37,31,20,4D,61,72,20,20,31,20,31,35,3A,35,34,20,30,33,30,31,32,30,30,
< 2007-05-19 12:23:31.156 37,68,77,5F,4F,52,49,47,2E,73,71,6C,2E,74,67,7A,00,00,00,0F,00,00,00,00,04,
< 2007-05-19 12:23:31.156 96,3C,F7,00,00,00,00,00,00,00,00,00,00,81,A4,45,E7,4B,7B,45,E7,4B,99,00,00,
< 2007-05-19 12:23:31.156 00,07,2E,63,6F,6E,66,69,67,00,00,00,3F,64,72,77,78,72,2D,78,72,2D,78,20,20,
< 2007-05-19 12:23:31.156 20,20,33,20,72,6F,6F,74,20,20,20,20,20,72,6F,6F,74,20,20,20,20,20,20,20,20,
< 2007-05-19 12:23:31.156 20,34,30,39,36,20,44,65,63,20,31,32,20,31,30,3A,31,39,20,2E,63,6F,6E,66,69,
< 2007-05-19 12:23:31.156 67,00,00,00,0F,00,00,00,00,00,00,10,00,00,00,00,00,00,00,00,00,00,00,41,ED,
< 2007-05-19 12:23:31.156 46,2D,80,CA,45,7E,D6,7E,
> 2007-05-19 12:23:31.156 Type: SSH_FXP_READDIR, Size: 13, Number: 780
> 2007-05-19 12:23:31.156 0C,00,00,03,0C,00,00,00,04,00,00,00,00,
. 2007-05-19 12:23:31.156 Sent 17 bytes
. 2007-05-19 12:23:31.156 There are 0 bytes remaining in the send buffer
. 2007-05-19 12:23:31.156 Looking for network events
. 2007-05-19 12:23:31.156 Timeout waiting for network events
. 2007-05-19 12:23:31.156 Ignored suspicious file 'd:\tomcat\logs\dbtrace.log'
. 2007-05-19 12:23:31.156 Waiting for another 4 bytes
. 2007-05-19 12:23:31.156 Looking for incoming data
. 2007-05-19 12:23:31.218 Detected network event
. 2007-05-19 12:23:31.218 Enumerating network events for socket 676
. 2007-05-19 12:23:31.218 Enumerated 1 network events for socket 676
. 2007-05-19 12:23:31.218 Detected network read event on socket 676 with error 0
. 2007-05-19 12:23:31.218 Received 32 bytes (0)
. 2007-05-19 12:23:31.218 Read 4 bytes (28 pending)
. 2007-05-19 12:23:31.218 Read 28 bytes (0 pending)
< 2007-05-19 12:23:31.218 Type: SSH_FXP_STATUS, Size: 28, Number: 780
< 2007-05-19 12:23:31.218 65,00,00,03,0C,00,00,00,01,00,00,00,0B,45,6E,64,20,6F,66,20,66,69,6C,65,00,
< 2007-05-19 12:23:31.218 00,00,00,
< 2007-05-19 12:23:31.218 Status/error code: 1
> 2007-05-19 12:23:31.218 Type: SSH_FXP_CLOSE, Size: 13, Number: 1028
> 2007-05-19 12:23:31.218 04,00,00,04,04,00,00,00,04,00,00,00,00,
. 2007-05-19 12:23:31.218 Sent 17 bytes
. 2007-05-19 12:23:31.218 There are 0 bytes remaining in the send buffer
. 2007-05-19 12:23:31.218 Looking for network events
. 2007-05-19 12:23:31.218 Timeout waiting for network events
. 2007-05-19 12:23:31.218 Startup conversation with host finished.
. 2007-05-19 12:23:32.031 Session upkeep
. 2007-05-19 12:23:32.031 Looking for network events
. 2007-05-19 12:23:32.031 Detected network event
. 2007-05-19 12:23:32.031 Enumerating network events for socket 676
. 2007-05-19 12:23:32.031 Enumerated 1 network events for socket 676
. 2007-05-19 12:23:32.031 Detected network read event on socket 676 with error 0
. 2007-05-19 12:23:32.031 Received 28 bytes (0)
. 2007-05-19 12:23:32.531 Session upkeep
. 2007-05-19 12:23:32.531 Looking for network events
. 2007-05-19 12:23:32.531 Timeout waiting for network events
. 2007-05-19 12:23:33.031 Session upkeep
. 2007-05-19 12:23:33.031 Looking for network events
. 2007-05-19 12:23:33.031 Timeout waiting for network events
. 2007-05-19 12:23:33.531 Session upkeep
. 2007-05-19 12:23:33.531 Looking for network events
. 2007-05-19 12:23:33.531 Timeout waiting for network events
. 2007-05-19 12:23:34.031 Session upkeep
. 2007-05-19 12:23:34.031 Looking for network events
. 2007-05-19 12:23:34.031 Timeout waiting for network events
. 2007-05-19 12:23:34.546 Session upkeep
. 2007-05-19 12:23:34.546 Looking for network events
. 2007-05-19 12:23:34.546 Timeout waiting for network events
. 2007-05-19 12:23:35.046 Session upkeep
. 2007-05-19 12:23:35.046 Looking for network events
. 2007-05-19 12:23:35.046 Timeout waiting for network events
. 2007-05-19 12:23:35.546 Cached directory change via "/usr/local" to "/usr/local".
. 2007-05-19 12:23:35.546 Getting current directory name.
. 2007-05-19 12:23:35.562 Listing directory "/usr/local".
> 2007-05-19 12:23:35.562 Type: SSH_FXP_OPENDIR, Size: 19, Number: 1291
> 2007-05-19 12:23:35.562 0B,00,00,05,0B,00,00,00,0A,2F,75,73,72,2F,6C,6F,63,61,6C,
. 2007-05-19 12:23:35.562 Sent 23 bytes
. 2007-05-19 12:23:35.562 There are 0 bytes remaining in the send buffer
. 2007-05-19 12:23:35.562 Looking for network events
. 2007-05-19 12:23:35.562 Timeout waiting for network events
. 2007-05-19 12:23:35.562 Read 4 bytes (24 pending)
. 2007-05-19 12:23:35.562 Read 24 bytes (0 pending)
< 2007-05-19 12:23:35.562 Type: SSH_FXP_STATUS, Size: 24, Number: 1028
< 2007-05-19 12:23:35.562 65,00,00,04,04,00,00,00,00,00,00,00,07,53,75,63,63,65,73,73,00,00,00,00,
. 2007-05-19 12:23:35.562 Discarding reserved response
. 2007-05-19 12:23:35.562 Waiting for another 4 bytes
. 2007-05-19 12:23:35.562 Looking for incoming data
. 2007-05-19 12:23:35.625 Detected network event
. 2007-05-19 12:23:35.625 Enumerating network events for socket 676
. 2007-05-19 12:23:35.625 Enumerated 1 network events for socket 676
. 2007-05-19 12:23:35.625 Detected network read event on socket 676 with error 0
. 2007-05-19 12:23:35.625 Received 17 bytes (0)
. 2007-05-19 12:23:35.625 Read 4 bytes (13 pending)
. 2007-05-19 12:23:35.625 Read 13 bytes (0 pending)
< 2007-05-19 12:23:35.625 Type: SSH_FXP_HANDLE, Size: 13, Number: 1291
< 2007-05-19 12:23:35.625 66,00,00,05,0B,00,00,00,04,00,00,00,00,
> 2007-05-19 12:23:35.625 Type: SSH_FXP_READDIR, Size: 13, Number: 1548
> 2007-05-19 12:23:35.625 0C,00,00,06,0C,00,00,00,04,00,00,00,00,
. 2007-05-19 12:23:35.625 Sent 17 bytes
. 2007-05-19 12:23:35.625 There are 0 bytes remaining in the send buffer
. 2007-05-19 12:23:35.625 Looking for network events
. 2007-05-19 12:23:35.625 Timeout waiting for network events
. 2007-05-19 12:23:35.625 Waiting for another 4 bytes
. 2007-05-19 12:23:35.625 Looking for incoming data
. 2007-05-19 12:23:35.703 Detected network event
. 2007-05-19 12:23:35.703 Enumerating network events for socket 676
. 2007-05-19 12:23:35.703 Enumerated 1 network events for socket 676
. 2007-05-19 12:23:35.703 Detected network read event on socket 676 with error 0
. 2007-05-19 12:23:35.703 Waiting for another 4 bytes
. 2007-05-19 12:23:35.703 Looking for incoming data
. 2007-05-19 12:23:35.703 Looking for network events
. 2007-05-19 12:23:35.718 Detected network event
. 2007-05-19 12:23:35.718 Enumerating network events for socket 676
. 2007-05-19 12:23:35.718 Enumerated 1 network events for socket 676
. 2007-05-19 12:23:35.718 Detected network read event on socket 676 with error 0
. 2007-05-19 12:23:35.718 Received 1733 bytes (0)
. 2007-05-19 12:23:35.718 Read 4 bytes (1729 pending)
. 2007-05-19 12:23:35.718 Read 1729 bytes (0 pending)
< 2007-05-19 12:23:35.718 Type: SSH_FXP_NAME, Size: 1729, Number: 1548
< 2007-05-19 12:23:35.718 68,00,00,06,0C,00,00,00,10,00,00,00,02,2E,2E,00,00,00,3A,64,72,77,78,72,77,
< 2007-05-19 12:23:35.718 78,72,77,78,20,20,20,31,35,20,72,6F,6F,74,20,20,20,20,20,75,73,65,72,73,20,
< 2007-05-19 12:23:35.718 20,20,20,20,20,20,20,34,30,39,36,20,41,70,72,20,31,37,20,30,38,3A,33,32,20,
< 2007-05-19 12:23:35.718 2E,2E,00,00,00,0F,00,00,00,00,00,00,10,00,00,00,00,00,00,00,00,64,00,00,41,
< 2007-05-19 12:23:35.718 FF,46,2D,80,D5,46,24,CC,68,00,00,00,03,6C,69,62,00,00,00,3B,64,72,77,78,72,
< 2007-05-19 12:23:35.718 2D,78,72,2D,78,20,20,20,20,32,20,72,6F,6F,74,20,20,20,20,20,72,6F,6F,74,20,
< 2007-05-19 12:23:35.718 20,20,20,20,20,20,20,20,34,30,39,36,20,41,75,67,20,31,32,20,20,32,30,30,34,
< 2007-05-19 12:23:35.718 20,6C,69,62,00,00,00,0F,00,00,00,00,00,00,10,00,00,00,00,00,00,00,00,00,00,
< 2007-05-19 12:23:35.718 00,41,ED,46,2D,80,FF,41,1B,A2,92,00,00,00,14,61,70,61,63,68,65,2D,74,6F,6D,
< 2007-05-19 12:23:35.718 63,61,74,2D,35,2E,35,2E,32,30,00,00,00,4C,64,72,77,78,72,2D,78,72,2D,78,20,
< 2007-05-19 12:23:35.718 20,20,31,31,20,72,6F,6F,74,20,20,20,20,20,72,6F,6F,74,20,20,20,20,20,20,20,
< 2007-05-19 12:23:35.718 20,20,34,30,39,36,20,4D,61,72,20,20,31,20,31,36,3A,32,31,20,61,70,61,63,68,
< 2007-05-19 12:23:35.718 65,2D,74,6F,6D,63,61,74,2D,35,2E,35,2E,32,30,00,00,00,0F,00,00,00,00,00,00,
< 2007-05-19 12:23:35.718 10,00,00,00,00,00,00,00,00,00,00,00,41,ED,46,4F,3C,F1,45,E7,51,F1,00,00,00,
< 2007-05-19 12:23:35.718 0B,6A,64,6B,31,2E,35,2E,30,5F,31,30,00,00,00,43,64,72,77,78,72,2D,78,72,2D,
< 2007-05-19 12:23:35.718 78,20,20,20,20,39,20,72,6F,6F,74,20,20,20,20,20,72,6F,6F,74,20,20,20,20,20,
< 2007-05-19 12:23:35.718 20,20,20,20,34,30,39,36,20,41,70,72,20,20,34,20,31,34,3A,32,32,20,6A,64,6B,
< 2007-05-19 12:23:35.718 31,2E,35,2E,30,5F,31,30,00,00,00,0F,00,00,00,00,00,00,10,00,00,00,00,00,00,
< 2007-05-19 12:23:35.718 00,00,00,00,00,41,ED,46,2D,80,FE,46,13,FB,0C,00,00,00,07,6C,69,62,65,78,65,
< 2007-05-19 12:23:35.718 63,00,00,00,3F,64,72,77,78,72,2D,78,72,2D,78,20,20,20,20,32,20,72,6F,6F,74,
< 2007-05-19 12:23:35.718 20,20,20,20,20,72,6F,6F,74,20,20,20,20,20,20,20,20,20,34,30,39,36,20,41,75,
< 2007-05-19 12:23:35.718 67,20,31,32,20,20,32,30,30,34,20,6C,69,62,65,78,65,63,00,00,00,0F,00,00,00,
< 2007-05-19 12:23:35.718 00,00,00,10,00,00,00,00,00,00,00,00,00,00,00,41,ED,46,2D,80,FF,41,1B,A2,92,
< 2007-05-19 12:23:35.718 00,00,00,05,73,68,61,72,65,00,00,00,3D,64,72,77,78,72,2D,78,72,2D,78,20,20,
< 2007-05-19 12:23:35.718 20,20,34,20,72,6F,6F,74,20,20,20,20,20,72,6F,6F,74,20,20,20,20,20,20,20,20,
< 2007-05-19 12:23:35.718 20,34,30,39,36,20,4E,6F,76,20,32,39,20,31,31,3A,35,31,20,73,68,61,72,65,00,
< 2007-05-19 12:23:35.718 00,00,0F,00,00,00,00,00,00,10,00,00,00,00,00,00,00,00,00,00,00,41,ED,46,2D,
< 2007-05-19 12:23:35.718 80,FF,45,6D,C8,98,00,00,00,07,69,6E,63,6C,75,64,65,00,00,00,3F,64,72,77,78,
< 2007-05-19 12:23:35.718 72,2D,78,72,2D,78,20,20,20,20,32,20,72,6F,6F,74,20,20,20,20,20,72,6F,6F,74,
< 2007-05-19 12:23:35.718 20,20,20,20,20,20,20,20,20,34,30,39,36,20,41,75,67,20,31,32,20,20,32,30,30,
< 2007-05-19 12:23:35.718 34,20,69,6E,63,6C,75,64,65,00,00,00,0F,00,00,00,00,00,00,10,00,00,00,00,00,
< 2007-05-19 12:23:35.718 00,00,00,00,00,00,41,ED,46,2D,80,FE,41,1B,A2,92,00,00,00,08,79,6F,73,65,6D,
< 2007-05-19 12:23:35.718 69,74,65,00,00,00,40,64,72,77,78,72,2D,78,72,2D,78,20,20,20,20,33,20,72,6F,
< 2007-05-19 12:23:35.718 6F,74,20,20,20,20,20,72,6F,6F,74,20,20,20,20,20,20,20,20,20,34,30,39,36,20,
< 2007-05-19 12:23:35.718 44,65,63,20,31,32,20,31,31,3A,34,30,20,79,6F,73,65,6D,69,74,65,00,00,00,0F,
< 2007-05-19 12:23:35.718 00,00,00,00,00,00,10,00,00,00,00,00,00,00,00,00,00,00,41,ED,46,2D,80,FF,45,
< 2007-05-19 12:23:35.718 7E,E9,A0,00,00,00,03,65,74,63,00,00,00,3B,64,72,77,78,72,2D,78,72,2D,78,20,
< 2007-05-19 12:23:35.718 20,20,20,32,20,72,6F,6F,74,20,20,20,20,20,72,6F,6F,74,20,20,20,20,20,20,20,
< 2007-05-19 12:23:35.718 20,20,34,30,39,36,20,41,75,67,20,31,32,20,20,32,30,30,34,20,65,74,63,00,00,
< 2007-05-19 12:23:35.718 00,0F,00,00,00,00,00,00,10,00,00,00,00,00,00,00,00,00,00,00,41,ED,46,2D,80,
< 2007-05-19 12:23:35.718 FE,41,1B,A2,92,00,00,00,01,2E,00,00,00,39,64,72,77,78,72,2D,78,72,2D,78,20,
< 2007-05-19 12:23:35.718 20,20,31,34,20,72,6F,6F,74,20,20,20,20,20,72,6F,6F,74,20,20,20,20,20,20,20,
< 2007-05-19 12:23:35.718 20,20,34,30,39,36,20,44,65,63,20,32,37,20,30,37,3A,32,31,20,2E,00,00,00,0F,
< 2007-05-19 12:23:35.718 00,00,00,00,00,00,10,00,00,00,00,00,00,00,00,00,00,00,41,ED,46,4F,3E,5C,45,
< 2007-05-19 12:23:35.718 92,73,6A,00,00,00,05,67,61,6D,65,73,00,00,00,3D,64,72,77,78,72,2D,78,72,2D,
< 2007-05-19 12:23:35.718 78,20,20,20,20,32,20,72,6F,6F,74,20,20,20,20,20,72,6F,6F,74,20,20,20,20,20,
< 2007-05-19 12:23:35.718 20,20,20,20,34,30,39,36,20,41,75,67,20,31,32,20,20,32,30,30,34,20,67,61,6D,
< 2007-05-19 12:23:35.718 65,73,00,00,00,0F,00,00,00,00,00,00,10,00,00,00,00,00,00,00,00,00,00,00,41,
< 2007-05-19 12:23:35.718 ED,46,2D,80,FE,41,1B,A2,92,00,00,00,04,73,62,69,6E,00,00,00,3C,64,72,77,78,
< 2007-05-19 12:23:35.718 34,20,73,62,69,6E,00,00,00,0F,00,00,00,00,00,00,10,00,00,00,00,00,00,00,00,
< 2007-05-19 12:23:35.718 00,00,00,41,ED,46,2D,80,FF,41,1B,A2,92,00,00,00,04,6A,61,76,61,00,00,00,3C,
< 2007-05-19 12:23:35.718 6C,72,77,78,72,77,78,72,77,78,20,20,20,20,31,20,72,6F,6F,74,20,20,20,20,20,
< 2007-05-19 12:23:35.718 72,6F,6F,74,20,20,20,20,20,20,20,20,20,20,20,31,31,20,44,65,63,20,32,37,20,
< 2007-05-19 12:23:35.718 30,37,3A,31,35,20,6A,61,76,61,00,00,00,0F,00,00,00,00,00,00,00,0B,00,00,00,
< 2007-05-19 12:23:35.718 00,00,00,00,00,00,00,A1,FF,46,4F,3C,E9,45,92,71,D5,00,00,00,06,74,6F,6D,63,
< 2007-05-19 12:23:35.718 61,74,00,00,00,3E,6C,72,77,78,72,77,78,72,77,78,20,20,20,20,31,20,72,6F,6F,
< 2007-05-19 12:23:35.718 74,20,20,20,20,20,72,6F,6F,74,20,20,20,20,20,20,20,20,20,20,20,32,30,20,44,
< 2007-05-19 12:23:35.718 65,63,20,32,37,20,30,37,3A,32,31,20,74,6F,6D,63,61,74,00,00,00,0F,00,00,00,
< 2007-05-19 12:23:35.718 00,00,00,00,14,00,00,00,00,00,00,00,00,00,00,A1,FF,46,4F,3E,56,45,92,73,6A,
< 2007-05-19 12:23:35.718 00,00,00,03,73,72,63,00,00,00,3B,64,72,77,78,72,2D,78,72,2D,78,20,20,20,20,
< 2007-05-19 12:23:35.718 32,20,72,6F,6F,74,20,20,20,20,20,72,6F,6F,74,20,20,20,20,20,20,20,20,20,34,
< 2007-05-19 12:23:35.718 30,39,36,20,41,75,67,20,31,32,20,20,32,30,30,34,20,73,72,63,00,00,00,0F,00,
< 2007-05-19 12:23:35.718 00,00,00,00,00,10,00,00,00,00,00,00,00,00,00,00,00,41,ED,46,2D,80,FF,41,1B,
< 2007-05-19 12:23:35.718 A2,92,00,00,00,03,62,69,6E,00,00,00,3B,64,72,77,78,72,77,78,72,77,78,20,20,
< 2007-05-19 12:23:35.718 20,20,33,20,72,6F,6F,74,20,20,20,20,20,72,6F,6F,74,20,20,20,20,20,20,20,20,
< 2007-05-19 12:23:35.718 20,34,30,39,36,20,4D,61,72,20,20,31,20,31,36,3A,31,34,20,62,69,6E,00,00,00,
< 2007-05-19 12:23:35.718 0F,00,00,00,00,00,00,10,00,00,00,00,00,00,00,00,00,00,00,41,FF,46,2D,80,FE,
< 2007-05-19 12:23:35.718 45,E7,50,56,
> 2007-05-19 12:23:35.718 Type: SSH_FXP_READDIR, Size: 13, Number: 1804
> 2007-05-19 12:23:35.718 0C,00,00,07,0C,00,00,00,04,00,00,00,00,
. 2007-05-19 12:23:35.718 Sent 17 bytes
. 2007-05-19 12:23:35.718 There are 0 bytes remaining in the send buffer
. 2007-05-19 12:23:35.718 Looking for network events
. 2007-05-19 12:23:35.718 Timeout waiting for network events
. 2007-05-19 12:23:35.718 Reading symlink "java".
> 2007-05-19 12:23:35.718 Type: SSH_FXP_READLINK, Size: 24, Number: 2067
> 2007-05-19 12:23:35.718 13,00,00,08,13,00,00,00,0F,2F,75,73,72,2F,6C,6F,63,61,6C,2F,6A,61,76,61,
. 2007-05-19 12:23:35.718 Sent 28 bytes
> 2007-05-19 12:23:35.718 Type: SSH_FXP_STAT, Size: 24, Number: 2321
> 2007-05-19 12:23:35.718 11,00,00,09,11,00,00,00,0F,2F,75,73,72,2F,6C,6F,63,61,6C,2F,6A,61,76,61,
. 2007-05-19 12:23:35.718 Waiting for another 4 bytes
. 2007-05-19 12:23:35.718 Looking for incoming data
. 2007-05-19 12:23:35.781 Detected network event
. 2007-05-19 12:23:35.781 Enumerating network events for socket 676
. 2007-05-19 12:23:35.781 Enumerated 1 network events for socket 676
. 2007-05-19 12:23:35.781 Detected network read event on socket 676 with error 0
. 2007-05-19 12:23:35.781 Received 32 bytes (0)
. 2007-05-19 12:23:35.781 Read 4 bytes (28 pending)
. 2007-05-19 12:23:35.781 Read 28 bytes (0 pending)
< 2007-05-19 12:23:35.781 Type: SSH_FXP_STATUS, Size: 28, Number: 1804
< 2007-05-19 12:23:35.781 65,00,00,07,0C,00,00,00,01,00,00,00,0B,45,6E,64,20,6F,66,20,66,69,6C,65,00,
< 2007-05-19 12:23:35.781 00,00,00,
. 2007-05-19 12:23:35.781 Storing reserved response
. 2007-05-19 12:23:35.781 Waiting for another 4 bytes
. 2007-05-19 12:23:35.781 Looking for incoming data
. 2007-05-19 12:23:35.781 Looking for network events
. 2007-05-19 12:23:35.859 Detected network event
. 2007-05-19 12:23:35.859 Enumerating network events for socket 676
. 2007-05-19 12:23:35.859 Enumerated 1 network events for socket 676
. 2007-05-19 12:23:35.859 Detected network read event on socket 676 with error 0
. 2007-05-19 12:23:35.859 Received 88 bytes (0)
. 2007-05-19 12:23:35.859 Read 4 bytes (84 pending)
. 2007-05-19 12:23:35.859 Read 43 bytes (41 pending)
< 2007-05-19 12:23:35.859 Type: SSH_FXP_NAME, Size: 43, Number: 2067
< 2007-05-19 12:23:35.859 68,00,00,08,13,00,00,00,01,00,00,00,0B,6A,64,6B,31,2E,35,2E,30,5F,31,30,00,
< 2007-05-19 12:23:35.859 00,00,0B,6A,64,6B,31,2E,35,2E,30,5F,31,30,00,00,00,00,
. 2007-05-19 12:23:35.859 Read 4 bytes (37 pending)
. 2007-05-19 12:23:35.859 Read 37 bytes (0 pending)
< 2007-05-19 12:23:35.859 Type: SSH_FXP_ATTRS, Size: 37, Number: 2321
< 2007-05-19 12:23:35.859 69,00,00,09,11,00,00,00,0F,00,00,00,00,00,00,10,00,00,00,00,00,00,00,00,00,
< 2007-05-19 12:23:35.859 00,00,41,ED,46,2D,80,FE,46,13,FB,0C,
. 2007-05-19 12:23:35.859 Reading symlink "tomcat".
> 2007-05-19 12:23:35.859 Type: SSH_FXP_READLINK, Size: 26, Number: 2579
> 2007-05-19 12:23:35.859 13,00,00,0A,13,00,00,00,11,2F,75,73,72,2F,6C,6F,63,61,6C,2F,74,6F,6D,63,61,
> 2007-05-19 12:23:35.859 74,
. 2007-05-19 12:23:35.859 Sent 30 bytes
. 2007-05-19 12:23:35.859 There are 0 bytes remaining in the send buffer
. 2007-05-19 12:23:35.859 Looking for network events
. 2007-05-19 12:23:35.859 Timeout waiting for network events
> 2007-05-19 12:23:35.859 Type: SSH_FXP_STAT, Size: 26, Number: 2833
> 2007-05-19 12:23:35.859 11,00,00,0B,11,00,00,00,11,2F,75,73,72,2F,6C,6F,63,61,6C,2F,74,6F,6D,63,61,
. 2007-05-19 12:23:35.859 Waiting for another 4 bytes
. 2007-05-19 12:23:35.859 Looking for incoming data
. 2007-05-19 12:23:35.921 Detected network event
. 2007-05-19 12:23:35.921 Enumerating network events for socket 676
. 2007-05-19 12:23:35.921 Enumerated 1 network events for socket 676
. 2007-05-19 12:23:35.921 Detected network read event on socket 676 with error 0
. 2007-05-19 12:23:35.921 Received 65 bytes (0)
. 2007-05-19 12:23:35.921 Read 4 bytes (61 pending)
. 2007-05-19 12:23:35.921 Read 61 bytes (0 pending)
< 2007-05-19 12:23:35.921 Type: SSH_FXP_NAME, Size: 61, Number: 2579
< 2007-05-19 12:23:35.921 68,00,00,0A,13,00,00,00,01,00,00,00,14,61,70,61,63,68,65,2D,74,6F,6D,63,61,
< 2007-05-19 12:23:35.921 74,2D,35,2E,35,2E,32,30,00,00,00,14,61,70,61,63,68,65,2D,74,6F,6D,63,61,74,
< 2007-05-19 12:23:35.921 2D,35,2E,35,2E,32,30,00,00,00,00,
. 2007-05-19 12:23:35.921 Waiting for another 4 bytes
. 2007-05-19 12:23:35.921 Looking for incoming data
. 2007-05-19 12:23:35.921 Looking for network events
. 2007-05-19 12:23:35.984 Detected network event
. 2007-05-19 12:23:35.984 Enumerating network events for socket 676
. 2007-05-19 12:23:35.984 Enumerated 1 network events for socket 676
. 2007-05-19 12:23:35.984 Detected network read event on socket 676 with error 0
. 2007-05-19 12:23:35.984 Received 41 bytes (0)
. 2007-05-19 12:23:35.984 Read 4 bytes (37 pending)
. 2007-05-19 12:23:35.984 Read 37 bytes (0 pending)
< 2007-05-19 12:23:35.984 Type: SSH_FXP_ATTRS, Size: 37, Number: 2833
< 2007-05-19 12:23:35.984 69,00,00,0B,11,00,00,00,0F,00,00,00,00,00,00,10,00,00,00,00,00,00,00,00,00,
< 2007-05-19 12:23:35.984 00,00,41,ED,46,4F,3C,F1,45,E7,51,F1,
< 2007-05-19 12:23:35.984 Status/error code: 1
> 2007-05-19 12:23:35.984 Type: SSH_FXP_CLOSE, Size: 13, Number: 3076
> 2007-05-19 12:23:35.984 04,00,00,0C,04,00,00,00,04,00,00,00,00,
. 2007-05-19 12:23:35.984 Sent 17 bytes
. 2007-05-19 12:23:35.984 There are 0 bytes remaining in the send buffer
. 2007-05-19 12:23:35.984 Looking for network events
. 2007-05-19 12:23:35.984 Timeout waiting for network events
. 2007-05-19 12:23:36.015 Session upkeep
. 2007-05-19 12:23:36.015 Looking for network events
. 2007-05-19 12:23:36.015 Timeout waiting for network events
. 2007-05-19 12:23:36.046 Session upkeep
. 2007-05-19 12:23:36.046 Looking for network events
. 2007-05-19 12:23:36.046 Timeout waiting for network events
. 2007-05-19 12:23:36.546 Session upkeep
. 2007-05-19 12:23:36.546 Looking for network events
. 2007-05-19 12:23:36.546 Detected network event
. 2007-05-19 12:23:36.546 Enumerating network events for socket 676
. 2007-05-19 12:23:36.546 Enumerated 1 network events for socket 676
. 2007-05-19 12:23:36.546 Detected network read event on socket 676 with error 0
. 2007-05-19 12:23:36.546 Received 28 bytes (0)
. 2007-05-19 12:23:37.046 Session upkeep
. 2007-05-19 12:23:37.046 Loo
gezi
I also just encountered the problem of a freeze when entering a directory. In my case it's reproducible: entering /usr/lib on my suse 10.2 the moment I either click on the 'lib' in the left or double click in the right pane (when my current dire is /usr) I get a freeze that I get out only by killing winscp. I encountered the error first with 3.8.2 and upgraded to see if this might have been handled, but I still get the same freeze on the same dir.
I turned on loggin to debug2 and got a pretty big log file - too big to post here, so I put it on the web and you can get it from there:
http://cadforge.com/files/
hope this helps to track that down.
Cheers
Gezi
gezi
No new info, just registered and signed in so that I can get notification when there is a reply.
Gezi
In both cases it seems that server fails to answer one of the requests WinSCP issues. However in such case WinSCP should display timeout message. I guess it does not. Any chance of getting test account on either of servers?
gezi
I have some more interesting information: the problem is related to either the name of the directory /usr/lib or something inside that's common to redhat FC2 and opensuse 10.? because I have two server with these OSes and both show the same behavior - the freeze on entering /usr/lib
Yes, you can have a test login - send me an email <removed> and I give you the login info.
Cheers
Gunter
Sent.
gcstang
Sorry I can't this is a client server.
If it helps they are using RHEL 4
gcstang
Just FYI Error still occurs in 4.0.1 beta on RHE 4
gcstang
Same error on 4.0.2, just locks up, would you like my log file?
Do you prefer I email it to you or post it in the forum?
Can you try to disable symlink resolving first (see directories tab of login dialog)?
Loaded my saved session and unchecked symlink resolving under directories in advanced mode, but still locks up. However the symlinks now have no folder image but they still are accessible.
OK, so please mail me the log file.
gcstang
Where is your email address you would like it sent to?
See my profile.
gcstang
prikryl wrote:
See my profile.
Sent.
gcstang
Previous log was sent on 6/8 did you need a new one?
The folder is a symbolic link that is being accessed.
After double clicking on that link I get into the correct location but then winscp just locks up.
No thanks. It is still on the TODO list.
gcstang
Ok, thank you.
gcstang
I'm sure you're busy but do you have any updates on this issue?
Thank you,
Sorry Sad
mcrsnap
I too experienced a freeze while downloading from server to workstation. In tracing the winscp log file the transfer stops when it encounters a symlink. This problem is reproducible. I have d/l'd the latest winscp to no avail. Just checking to see if anyone has a way around this?
mcrsnap
Please post or mail me a log file.
Hi Guys,
I had an issue where I couldn't scroll down a directory listing from a remote server. WINSCP would freeze up when I got to P.
It turns out that there was a file called PRN.html in the directory. PRN is a reserved name in windows and cannot be used. (try creating a file called PRN.txt on your computer.
Anyway, removing PRN.html on the remote Unix machine resolved the issue.
I thought this may be related to problems others were having.
Cheers,
Tristan(dot)Alexander@rea-group.com
Thanks. This issue has been added to tracker.
