Topic "Software caused connection abort"
Hello there,
i searched google and used the internal search plus the documentation but did not find any record, describing my problem. So here we go.
Since I've downloaded the newest WinSCP 4.0(i duno which version i used to use...) my connection get interrupted after a irregular period of time. It's like every 10 minutes. The errormessage: "Software caused connection abort " appears and ask me to reconnect, which is very annoying.
Does anybody here have got the same problems? I appreciate every help. Thank you.
Can you first check server's log to see why (if) it closes the connection?
