Topic "Private key file"
clueless
Hi, what program does the private key file have to be stored in or does it have to be in a specific location in Windows? I am trying to use a private key file I have saved as .txt is this the correct syntax:
ssh-rsa "AAAAB3NzaC1yc2EAAAABIwAAAIEAph3S2eZXk4ftBi+1/CkMaqah/GsBs4FP
VuJNqy67xbDQ/3zL0jA+2idXJ5DM4wneh9D4HouENFVu5INs3UAOglI/oejxiqeqPRyM2Wcu5LtszherRp2bpOXiHY4P
oqGLbZ471it3mklV/G2B9MxjaSvZUfys/1GyxKy3XSkQYK0="
WInScp is not recognizing the file
also do I just make a vi with this on the corresponding host?
TS
clueless wrote:
Hi, what program does the private key file have to be stored in or does it have to be in a specific location in Windows?...
That is in OpenSSH format. WinSCP uses PuTTY, so the private key needs to be in the format PuTTY expects - a .ppk file. You can convert an OpenSSH format to a *.ppk using puttygen available at:
http://www.chiark.greenend.org.uk/~sgtatham/putty/download.html
If that really was your private key you just posted, you've essentially given your password to the entire internet so you should obviously throw that one away and make a new one (which, by the way, puttygen can also do).
