Keep Remote Directory up to Date - Can't Restore
tm2000
California USA
1st and foremost - GREAT WORK!!!!!
Using 4.00 with XP sp2 connecting with SCP and Commander View.
When I click on the Icon, Keep Remote Directory up to Date, then Minimize.. I can't get it back up (restore) unless I use the Windows Task Manager (CTRL-ALT-DELETE) and then select WinSCP, Switch To..
Love the FTP Access.. So great!!! Keep up the fantastic work and Donation is coming to you shortly!
Re: Keep Remote Directory up to Date - Can't Restore
What happens when you click on the taskbar button? Or do you have minimization to tray area enabled? Did you have the same problem with version 3.8.2?
