Topic "New User - need help with a script"
smcelhe
I installed WinSCP.....Created a Session called PDCH.
I can connect to the site with the connection and "get" the file I need.
Now....I want to create a batch file to do it.
Here is what I have:
cd \
cd Program Files\WinSCP\
winscp.com PDCH
get PDCH1
When I run the batch file....the command window opens....Winscp connects to the site....and stops....
The command window is open....I can type dir and see the file...I get get the file....if I type get PDCH1....
Why don't the commands on the batch file work?
Any info would be appreciated.
Thanks Shwan
You need to store the commands for WinSCP to separate file. Please see example in documentation.
