Guest Check for Updates 2007-05-11 20:05 Are there any plans to add a username/password field to the proxy configuration for checking if there are updates available? I must provide this to successfully authenticate and as a result the check for updates does not work for me. Cheers. Reply with quote
martin◆ Site Admin Joined: 2002-12-10 Posts: 40,602 Location: Prague, Czechia Re: Check for Updates 2007-05-12 There are no such plans yet. I may consider it :-) Reply with quote
Teka Guest 2007-05-12 17:30 Under windows, you have an api to make http call with internet explorer settings. Have see to functions: WinHttpOpen, WinHttpGetIEProxyConfigForCurrentUser :) Reply with quote
martin◆ Site Admin 2007-10-05 This feature has been implemented already. It will be included into the next major release. Reply with quote
