Topic "FTP using HTTP/80 proxy auth failure"
phirewheel
Hi - using winscp400 (build342) for FTP proxy-aware client and running into auth issues on HTTP/80 proxy. Ethereal traces reveal client is sending embedded username credentials and following username with : (colon) character but then leaving out the embedded password from the proxy settings page. The "test" session page has ftp.microsoft.com port 21 and anonymous user/pass filled in and FTP protocol selected. The associated proxy tab has proxy type HTTP radio button selected, proxy-ip addr, port number 80, username for proxy auth, and password for proxy-auth filled in. The proxy immediately responds with error message 407 proxy-auth required. However, the same settings on an SFTP session work perfectly - ethereal trace this time reveals client sends username:password in clear to proxy from embedded proxy-auth username/password credentials settings page. Basically seems the FTP portion is leaving out the proxy-auth password. Can someone help confirm these results? -phirewheel
Thanks for your report. I have already fixed that. The fix will be included into the next release.
The issue has been resolved already. The fix will be included into the next release.
