Topic "Commandline and Timeouts"
I sucsessfully use WinSCP in scripting mode to sync a bunch of directorys from my Webserver to the locval windows installation.
There is only one problem left I cannot solve.
I don't know why, but sometimes the script breaks with the message "Waited 15 seconds for answer from server (rety) or (arbort)".
Is there a way to tell the script to retry?
As far as I can tell this accours once in a while when using winscp "normaly" and it works fine if i tell it to rety.
Though its a Bach script with no interaction I need to let the script do the retry.
Can anybody help please?
During what operation to you get the timeout? As temporary workaround, it should help to set longer timeout.
