Topic "Keepuptodate"
zombi
My script is as follows:
open user@example.com
synchronize local c:/rails /var/rails
option synchdelete
keepuptodate c:\rails /var/rails
The synchonrization works. However when I change a file in c:\rails all that keepuptodate reports is it detected a change. It says it twice for each change I make, but never actually transfers the file.
If you perform synchronization again after change, would the file be uploaded?
mshaffer
I am using basic FTP. Just like the previous user, Keep Up To Date 'detects' a change, but doesn't upload it.
I then manually run SYNC and get (no differences found). There is definitely a difference in the two files, so I manually have to upload (not fun).
The server time is ahead of my local time, but your docs don't make it very clear on how to manually set an offset (local time is 8:25 a.m., server time is 10:25 a.m.)
I have tried this functionality on two different machines/servers.
An older version of WinSCP did this fine (using SFTP protocol). Maybe I will have to downgrade.
monte
{x:
Timezone offset is not implemented for FTP yet.
This has been implemented already. It will be included into the next major release.
